Juice problem
WH867 · 12 · 2248
us Offline WH867
Juice problem
on: June 09, 2008, 07:30:44 PM
I just got this Juice Pro off of ebay. Its in nice shape except the backspring is missing on the file.  If I send this in to leatherman do you think they would fix it or replace it?  I would rather keep it as it is than have them send me a XE6 as a replacement.
Dennis
gb Offline Roadie
  • Hello...is this thing on?
Re: Juice problem
Reply #1 on: June 09, 2008, 07:34:31 PM
I would have thought they would be able to repair it, if you put a note in with it asking them not to replace it with an XE6 i'm sure they will abide by your wishes :)
Offline cryptrick
Re: Juice problem
Reply #2 on: June 09, 2008, 08:40:34 PM
My guess would be that they would replace the tool because it is riveted and it isn't gonna be a straight swap with a spare they have. You will just need to tell them that you will need the Juice Pro replacing with a Pro or have the problem fixed. You should be OK then.
Re: Juice problem
Reply #3 on: June 09, 2008, 09:34:26 PM
I would suggest contacting Leatherman's Customer Service department to be sure.  They are usually quite accommodating, or at least as much as they can be.  I can't speak for them mind you, but it's well worth a phone call at least:
http://www.leatherman.com/customer-service/default.asp
Offline raptor
Re: Juice problem
Reply #4 on: June 10, 2008, 11:48:09 AM
 backspring is missing ? how this happened
Re: Juice problem
Reply #5 on: June 10, 2008, 03:33:03 PM
It very likely broke and fell out.  Backsprings are held in under tension between the implement and the rivets- if they break, there is no tension and they are free (in many cases) to fall out.
us Offline WH867
Re: Juice problem
Reply #6 on: June 10, 2008, 07:48:52 PM
update ,   I talked to a Very nice lady at leatherman. She said   "to the best of my knowledge that she thought they still had some Pros available. But to be sure and add a note to call before they replaced it with a XE6".  So it sounds good so far.
I am also going to send my original MT back to gerber. Will mail both items at the same time.  So I can compare LM and Gerbers service.
« Last Edit: June 10, 2008, 07:55:11 PM by WH867 »
Dennis
Re: Juice problem
Reply #7 on: June 11, 2008, 04:04:30 AM
Hope it goes well for you WH. :)
us Offline WH867
Re: Juice problem
Reply #8 on: June 27, 2008, 04:11:21 AM
My Juice problem has been solved.  I got it back today.   It's either my old one or a used one of equal condition other than not broke.  If it is my old one they did a great job. You wouldnt even know it had been worked on.   I'm very pleased with it. :D
I sent the juice and a Gerber MT in at the same time. Both companys recieved them on the 16th.  I recieved both tools back within 10 days.  I think that is very good.
Dennis
us Offline Smitty44
Re: Juice problem
Reply #9 on: June 27, 2008, 06:00:18 AM
Good to hear that you got good service out of both LM & Gerber,thanks for the follow up!!
Re: Juice problem
Reply #10 on: June 27, 2008, 04:54:33 PM
That's good to hear.  :)  10 day turn around is pretty impressive.
Offline Leatherman123
Re: Juice problem
Reply #11 on: June 27, 2008, 09:42:01 PM
Yeah, I sent Vic a Cybertool 34 and a SwissChamp Wednesday, and they are already being repaired! I'll probably get them on Tuesday!
B
