“Footprint's” Owners club
on: April 30, 2014, 08:37:10 PM
Lets see your examples of this robust tool
Re: “Footprint's” Owners club
Reply #1 on: April 30, 2014, 08:39:51 PM
Here's some nice pictures from MultiMat  :salute:
I got myself a 'Tony Special' a couple weekends ago. I could not believe it when I stumbled on it in a pile of rusty old cack  :o 8). I looked at it & thought 'that looks like one of those Footprints Tony talks about'  immediately I looked to see if it had it's original factory adjustment bolt & sure enough it did  8) 8).
I asked 'how much for the old footprint'? I am sure the fella had absolutely no idea what a 'Footprint' was  :D :D but when I showed him the rusty old thing he said 'five bucks' , Done  8) :D.
I know a certain cantankerous bath tape that may be meeting Mr.Footprint  :D
It took quite a bit of work to get the rust off the old thing ,various sized wire wheels & then a good vinegar bath , Tony style  ;) :D. It was surprising how quickly the rust would reappear on the Footprint after I had cleaned it  :o , old fellas must of oiled their tools quite frequently  :think: :think:
I did some Googling & Footprint is still a ongoing concern & still based in Sheffield UK  8) here is there website http://www.footprint-tools.co.uk/index_home.htm, I read some sellers listing the wrench as having only a 12 month warranty ??? :think: :think:. The website lists the handle end as being a screw driver ;
looks more like a pry bar to me  :think: >:D :D :D
us Offline Yadda
Reply #2 on: May 01, 2014, 06:58:06 PM
« Last Edit: May 01, 2014, 07:00:08 PM by Yadda »
de Offline lowtech
Reply #3 on: May 03, 2014, 04:45:06 PM
Thanks to Sparky, I can happily join this Club!
Thanks, pal!
Reply #4 on: May 03, 2014, 09:07:43 PM
Thanks to Sparky I can join also.    :)
* footprint 001.JPG (Filesize: 103.09 KB)
* footprint 007.JPG (Filesize: 101.96 KB)
Reply #5 on: May 03, 2014, 09:11:37 PM
They look very tidy David  :tu:
I think I will have to post 'my footprints user rules' later  :D
Reply #6 on: May 04, 2014, 01:53:51 AM
Well  I guess I had better use them as a hammer    :o  and put a 4' cheater pipe on the end of it for some added leverage.  :ahhh   Then post some more pics.   :D    :D
Reply #7 on: May 04, 2014, 08:10:48 PM
Thats what Stilsons are for David  :tu:
Reply #8 on: May 04, 2014, 08:27:44 PM
Footprint grips have an amazing history they go back to 1875  :o
The firm
http://footprint-tools.co.uk/index.php?route=information/information&information_id=4
The wrench
http://footprint-tools.co.uk/Plumbers-Tools
For those that have never used them before heres my beginners guide to using them  :)
Only do the screw up finger tight
They are great for doing conduit! (threaded rod, rounded off nuts an bolts etc)
They tend to bugger up the surface of whatever you use them on so for example you wouldn't use them on a set of bathroom taps  :dwts:
They only work in one direction
The 'screwdriver' is great for opening tins of paint
Don't squeeze them like pliers, just hook them on and push with the heel of your hand
The harder you push the harder they grip
Reply #9 on: May 04, 2014, 08:32:01 PM
Bob did a very nice review sometime back  :salute:
Having never seen a Footprint on this side of the pond before (nor has anyone else around here for that matter) I was quite pleased when one magically showed up in the post this week! :cheers:
It is indeed a stoutly built tool. :salute: The folded metal handle is made from very thick steel plate, and the plier/wrench head is forged. I cannot imagine what it would take to damage one. The teeth are rather aggressive, and sharp. Mine is used, but it is in exceptionally good condition.  The only iron pipe I could locate here at the house was the handrailing I built for the kid's play fort. I didn't put much pressure on the handle of the Footprint and it was already grabbing on tight to the pipe. And the harder I pushed on the handle, the tighter it bit in. There's no question it is a professional grade tool.
FOOTPRINT
SHEFFIELD ENGLAND :)
Reply #10 on: May 04, 2014, 10:15:22 PM
Thanks for the users guide and history. They really are a clever tool.   :tu:    :)
Reply #11 on: May 04, 2014, 10:40:30 PM
The 'guide' was aimed at the newer owners David not us older hands Mate  ;)
I was very suprised at how long they have been around  :o (I only found that history link today)
Reply #12 on: May 04, 2014, 11:25:37 PM
I got to find one of those smaller ones some day. there were some on the bay a while back and forgot about them and they were gone. Got to pay better attension. Tony it was iteresting to me in the history at the 1875 point it said pipe-tongs or wrench. Having used chain tongs on pipe in the oilfield it finally soaked through my thick skull the working principle of this wrench. How much more handy than a chain-tong.    :)
Reply #13 on: May 05, 2014, 06:11:36 AM
Thanks again for mine Tony! :cheers: I did not realize there were so many variations! :o Did the design change that much over the years, or are all those intended to do different jobs, or...? ???
Reply #14 on: May 05, 2014, 08:42:08 AM
Did you see how many of mine are missing the original screw  ::)
I think they have only changed as they improved the jaws over the years  :think:
The top had a wider flat jaw added and the bottom triangular jaw was made up to match the top
A You can see the older bottom jaw has a triangle shape
B Newer jaws are square
C Newer top jaw is wider
Reply #15 on: May 05, 2014, 08:52:02 AM
That's very interesting to see the change's over the years.  :tu:
Reply #16 on: May 05, 2014, 09:09:51 AM
Changes for the better I think,
they went from being very good for pipe work then added being able to grip the heads of bolts on flanges etc
Reply #17 on: May 06, 2014, 02:52:05 AM
The difference between the A and the B bottom jaw must have been a pain in the butt on the shop floor. They had to add that whole bottom block and rivet it into place, then cut teeth into the whole sandwich at once.
Great for the end users like us, but I'll bet the guy in charge of production was grousing :D
us Offline Yadda
Reply #18 on: July 03, 2014, 07:46:46 PM
I joined this club this week. Thanks to the wonderful enablers that kept posting pictures here and there with these odd wrenches. Mine has the original triangular jaw.
Picture to be posted this evening when I get home. Baby Footprint about 5.5 inches when fully closed.
The original screw is gone :(
Does anyone sell a decent replacement screw for these tools?
Reply #20 on: July 03, 2014, 10:04:23 PM
Welcome to the club Phil  :salute:
Not that I know of and I think the thread has changed on them over the years  :think:
Reply #21 on: July 04, 2014, 05:28:44 AM
I think I need a small & a medium 'Footy' to go with my biggie  :think: :D :D
Reply #22 on: July 04, 2014, 08:30:29 AM
I'm sure we can work something out Matt  ;)
Reply #23 on: July 04, 2014, 09:46:19 AM
Found an older Footprint with the narrower jaw.
Reply #24 on: July 04, 2014, 09:13:24 PM
You found them wandering free in the wild, in the USA?
They traveled a long way from home  :o
gb Offline Cupboard
Reply #25 on: July 04, 2014, 09:51:24 PM
I hadn't realised the rusty bit of metal in my cupboard that looked useful for something was an actual thing!
Of course seeing as it's rusty it had to be sparky ;)
The screwdriver is twisted and it must be missing the original screw.
My head is a bit of a mix of the above too, it's "A" shaped but has the filler of "B".
Someone gave me an old tool kit for something I was doing last year, I couldn't see this being any use in that but it did look like something that would be useful to keep. So I did.
Reply #26 on: July 04, 2014, 09:59:49 PM
Welcome to the club Mate  :salute:
Yours will come-in-handy one day  :tu:
gb Offline Cupboard
Reply #27 on: July 04, 2014, 10:18:13 PM
I've just bought a new thumb adjusting 12" for the princely sum of £20.
That will be going to work with me.
Reply #28 on: July 04, 2014, 10:47:22 PM
 :gimme:
You know we need pictures of the new pair please
gb Offline Cupboard
Reply #29 on: July 04, 2014, 11:45:13 PM
if you want one, these are the cheapest I found on the intertubes:
https://www.cromwell.co.uk/FOO5204612C
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
