Show off your Sak mod's!
wales Offline hiraethus
  • I brake for cake
Re: Show off your Sak mod's!
Reply #5190 on: June 14, 2018, 06:18:21 PM
For just the phillips/magnifier in a single layer, no.  If you're putting the phillips opposite the can opener/cap lifter pair then you need 2 x opener layer springs.
pt Offline FInixNOver
Reply #5191 on: June 14, 2018, 07:16:01 PM
My configuration will be the following:
Layer 1 - Blade and Awl
Layer 2 - Scissors
Layer 3 - Magnifying glass and Phillips driver
Layer 4 - Cap lifter and Electrician blade
Sent from my Mi A1 using Tapatalk
Reply #5192 on: June 14, 2018, 10:58:04 PM
Remember that you will have to drill out the tool pivots to fit the thicker alox rivets. :ahhh
Reply #5193 on: June 15, 2018, 12:19:10 AM
Already have ordered carbide drill bits for that.
ca Offline Syph007
  • SAK Surgeon
Reply #5194 on: June 15, 2018, 01:34:01 AM
Mag glass will sit really high if you dont make a small recess in the spring for it to fit into.  You dont have to do it, but it fits so much better that way.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
Reply #5195 on: June 15, 2018, 01:50:23 AM
That's actually a great tip!! I'll keep that in mind.  :cheers: :like: :like:
Reply #5196 on: June 20, 2018, 10:18:56 PM
Mail call today.
Received the donor Explorer for the mag/phillips layer and the pivots and screws from KnifeKits.
Taking into account what I've read in the past, I was quite surprised to see that the pivot's tolerances we spot on.
Now I have another question... Would it be acceptable to use 3.2mm (0.126in) drill bits, which are available in my local hardware store, to enlarge the tool/backspring holes, or will I be better off with the 0.125in drill bits that I've already ordered?
About the Explorer SAK, there's an engraving in the main blade "Arnaud B."
Does this mean anything to anyone, or can I go ahead and disassemble it?
Reply #5197 on: July 31, 2018, 07:36:02 PM
Finally received the carbide drill bits.
After receiving the wrong product from one seller and placing a new order to a different seller, here they are and I'll be able to resume the pivots/screws conversion!
Sent from my Redmi Note 5
fr Offline m47mu74nt
Reply #5198 on: August 13, 2018, 11:53:23 AM
Wenger Compact Motorist (original plan was to make a Wenger Trail Guide...)
Reply #5199 on: August 13, 2018, 03:06:18 PM
That's a cracker mate.  :tu:
Reply #5200 on: August 13, 2018, 03:44:21 PM
Almost forgot to post this here.
First attempt at torx conversion with my latest 58mm mod.
They pair up quite nicely...
wales Offline magentus
  • mmmmm SAKrelicious
Reply #5201 on: August 13, 2018, 03:58:43 PM
Oooooo, they're lovely!  :cheers:
Reply #5202 on: August 13, 2018, 08:11:43 PM
Nice ones !!
nl Offline Ron Who
  • I'm blue!
Reply #5203 on: August 13, 2018, 09:06:30 PM
One that Magentus made for me -- the Green Hornet.
Layer 1 - Large blade (plain edge), small blade, fluted corkscrew
Layer 2 - Woodsaw
Layer 3 - Large blade (serrated edge), combo tool
On the back of the third layer Mags fitted an awl. It is recessed too deep to be accessible, but it puts a nice tension on the spring.
Mags kindly added the green plus scales and the lanyard as a bonus. Thanks!
« Last Edit: August 13, 2018, 09:08:25 PM by Ron Who »
Reply #5204 on: August 13, 2018, 09:15:58 PM
:like: :tu:
Reply #5205 on: August 13, 2018, 09:24:34 PM
Wenger "Trail Guide" (Compact Motorist from my post above minus the wrench layer) and a kinda Nomad (similar load-out of the 'real' Nomad, but in a different order -my bad- and a nail file instead of the small blade)
Reply #5206 on: August 13, 2018, 09:30:08 PM
Layer 2 - Woodsaw
Nice mod!
Reply #5207 on: August 13, 2018, 10:25:35 PM
GREAT mods everywhere. :dd:
id Offline jaya_man
Reply #5208 on: August 14, 2018, 01:10:36 PM
+1
Awesome mods... :like:
Reply #5209 on: August 14, 2018, 03:20:44 PM
+1
You meant awlsome, right?! :poke:
id Offline jaya_man
Reply #5210 on: August 14, 2018, 03:53:37 PM
Reply #5211 on: August 14, 2018, 04:23:03 PM
+1
Stop rubbing salt in the wound, after awl, my W TrailGuide mod lacks one  :oops:
Reply #5212 on: August 14, 2018, 09:04:15 PM
+1
You've got one... It's just not accessible at awl!! :ROFL:
Reply #5213 on: August 14, 2018, 10:11:17 PM
+1
Ron has one he can't use, and I have none  :pok:
Looks like you didn't read at awl!
Reply #5214 on: August 14, 2018, 10:42:51 PM
+1
:facepalm: :facepalm:
You're absolutely right!
So many SAK mod greatness :ahhh
It's awl so confusing :think:
Reply #5215 on: August 17, 2018, 09:31:42 AM
NO awl family grown up :
Wenger Trail Guide
Victorinox Trail Guide +
Reply #5216 on: August 25, 2018, 07:24:15 PM
I wasn't happy with the metal file position on the Wenger Trail Guide.. it was time for an upgrade : the Trail Guide Evo S  :think:  :climber:
Offline Lonewoodzman
Reply #5217 on: September 05, 2018, 04:52:58 AM
Modified my can opener to also serve as a mini gouge.
Reply #5218 on: September 05, 2018, 08:15:22 AM
Nicely done.  :like:
Reply #5219 on: September 05, 2018, 08:40:02 AM
Nicely done.  :like:
Thanks. Just finished modding the small blade into a sloyd style blade for finer cuts.
