Just modded one of my 84MM to have a single blade scalpel.
More pics of the parts? Please!!
I will have put some work into that. This was a bit of hodgepodge of modified extra parts.
hi all,just finished modding my beloved mini champ so i wanted to brag about it . i'm not done yet (scales need some minor tweaks and i plan to acid etch the tools but i don't have the acid yet).so, here's the list of mods:m1.8 screws instead of pivots (had to widen the holes on all tools and springs a bit)custom designed 3D printed scales: front side has the compartments for both the tweezers and toothpick and additional one for a pin/needle, back side has penremoved the ruler/flat screwdriver and cuticle pushernail file modified to have the flat screwdriver instead of nail cleaner (i plan to also mark the ruler on the back side)future plans involve darkening the tools with acid, maybe adding some small magnifier, improving the scales design (pen doesn't move as easy as on the original, toothpick is a bit loose) and maybe ordering a 3D print in metal from shapeways (this is printed in PLA and works pretty good as i carried a "testing" PLA scale for last three months and haven't had any issues with wear). i'm also thinking of removing small blade and citrus peeler (to basically get a manager SAK) as i have a small scalpel on the keychain for precise cuts but i just love that small blade.
[ Quoting of attachment images from other messages is not allowed ] I realised I wanted a Climber Deluxe (with a nail file) so I made one and also ended up with a pointy bladed DofE (RIP Your Highness)
hi all,just finished modding my beloved mini champ so i wanted to brag about it . I'm not done yet (scales need some minor tweaks and i plan to acid etch the tools but i don't have the acid yet)...........
Only if you get the chance, taking it apart or get any other good opportunities
Here is what it took to make the mod. I wasn't willing to take it apart so I did my best with what I had on hand.
Thank you for posting this. Do you think there’d be any issue with using the pivot point on the standard 91mm knife as a template instead of the bottle/can opener? Maybe there isn’t enough material to start with?
And since I'm in 3-layer mood, here's a 91mm clone of Syph's great invention of the driver layer.
Super like this one, any additional work to get the phillips in place of the can opener or is it just a drop-in?
Hello, new here and trying to post. I am new to modding, this is one of my 2 layers. Small blade and saw on one layer and an integrated pocket clip. I am in the process of making some leather scales for it. [ Quoting of attachment images from other messages is not allowed ]
