Show off your Sak mod's!
Re: Show off your Sak mod's!
Reply #5910 on: November 27, 2022, 02:40:15 PM
NICE !
Quick questions: Dragonfly blade without modification? Could you explain your process?
I love it!
+1
Awlso, why the combo tool instead of the bottle opener?
us Offline trouthunter
  • The missing village idiot.
Reply #5911 on: November 28, 2022, 06:47:17 AM
+1
Sure.  I noted that I saw a 91mm Spydernox being built, don’t remover where, and they made no modification to the blade at all.  They did how ever modify the spring to accommodate the Dragonfly.  I prefer the the Combo Tool.  Hindsight sight saws I should used a small blade vs. the can opener.
be Offline bismouth
Reply #5912 on: November 29, 2022, 08:40:53 PM
can you explain the process of puting the dragonfly blade?
Modifying the spring OK but for the pivot diameter?
Reply #5913 on: November 30, 2022, 07:46:08 PM
Sure for the pivot, I peened in a piece of brass in the Spyderco blade pivot and then drilled a 2.2mm hole for the pivot.
us Offline pa_strunk
  • MAJ/APA
Reply #5914 on: November 30, 2022, 08:42:31 PM
Millions of SAKs and swiss army like knives get sold cheap on eBay and secondary markets due to broken scissor springs or scales. I put a Victorinox spring on this Syracuse #381 made in Poland sometime in the early 60’s.  If you choose to do this it only takes about 30 minutes of dremel work to have an “improved” SAK with fully functional scissors.  Also added a better nail nick. They did not know a lot about leverage in 60’s apparently.
Reply #5915 on: December 11, 2022, 11:34:52 PM
New custom painted scales.  I could not fine 84MM Plus scale let along 84MM Plus scales in the right shade of blue.  So I made some.
* 2022-12-11_16-31-53.jpg (Filesize: 163.86 KB)
* 2022-12-11_16-33-08.jpg (Filesize: 149.37 KB)
Reply #5916 on: December 12, 2022, 12:22:05 AM
Nice blue!
us Offline Enginears
Reply #5917 on: December 12, 2022, 01:05:17 AM
Looks cool. What kind of paint and what kind of surface prep did you use?
Reply #5918 on: December 12, 2022, 04:00:11 AM
Just standard spray paint with a matte polyurethane clear coat.  Surface preparation was simple sanding and washing.
Offline Helvetica Bold
Reply #5919 on: December 13, 2022, 07:31:43 PM
Was very unlikely to find one of these so modded a divot tool to make this Spartan golfer out of a sheet of 1.5mm 403 stainless. Looks pretty convincing not sure how bend resistant 403 is/will be but unless I hit a large stone I’m sure it’ll be fine.
Meant to take photos of fitting up but forgot in a flurry of activity but you can see the template I made by scaling one of the photos on SAK wiki and tracing around with Adobe illustrator pen tool. For the pivot end I just traced around a pen blade….
Reply #5920 on: December 18, 2022, 04:41:44 PM
Looks good! Keep us posted on the durability of the 403.
Here is a 3 layer I put together last night. I call it the camp and climb. Basically a climber with a blade swap.  Added an extra liner for the woodsaw/small blade - now it fits like a charm.
Reply #5921 on: December 18, 2022, 11:34:53 PM
Looks like you managed to get good clearance on the saw there. 3 layer huntsman - pretty snazzy!
  • MAJ/APA
Reply #5922 on: December 31, 2022, 04:36:43 PM
Last mod of 2022, always bugged me how Wenger was in some ways much more innovative than Victorinox. One particular model took me forever to find. The Wenger Double Blade SAK. Finally found one  on eBay, but was disappointed in the tool set so I finally made a Victorinox 84 mm Double Blade.
Reply #5923 on: January 01, 2023, 01:00:31 AM
Very cool. Looks like a very useful and pocketable knife. The scales are amazing  :drool:
jp Offline proletenstahl
Reply #5924 on: January 01, 2023, 11:56:51 AM
That's great! I was unaware of the Wenger Double Blade until you mentioned it. It looks like it's four layers, but your three-layer setup is even better.
za Offline Max Stone
Reply #5925 on: January 07, 2023, 09:36:29 PM
My first attempt at an 84mm build using 91mm scissors - the Golfer. Had some very old European stag horn that's was earmarked for the bin during a clean-out. Dates from around the 1930's shot by my grandfather somewhere in Austria. Glad I could repurpose them. I took some photos so will look at doing a separate thread on the build process.
* IMG_2782.jpg (Filesize: 80.83 KB)
* IMG_2845_small.jpg (Filesize: 137.14 KB)
Reply #5926 on: January 07, 2023, 11:30:10 PM
Very nice Max, I love how you went with two exposed pins only. The separate thread has been great so far as well.
Reply #5927 on: January 08, 2023, 12:34:16 AM
Thank you Enginears   :hatsoff:
Offline samek
Reply #5928 on: January 14, 2023, 02:07:28 PM
The third member of my polished stainless steel family: Climber
Reply #5929 on: January 14, 2023, 02:40:18 PM
Nice set,,
Reply #5930 on: January 19, 2023, 02:55:19 PM
Some lovely mods there - the antler and polished steel both look amazing even though they are about as different as they could be! I’ve just finished a cadet X done the ‘easy’ way with Delemont scissors - like it but have also got a 84mm huntsman small underway which I am attempting with modded 91mm scissors and spring. Not seen that model done on here (although that’s not to say it hasn’t been!) and I think it’ll be a little cracker if it turns out ok. Have had to make some of the liners from brass so a more difficult mod all round than this one…hopefully not to much so for my limited skill set and tool set!!!  :rofl:
Reply #5931 on: January 21, 2023, 05:20:47 PM
Nice Alox mod HB 👍
I must say it’s more about the perseverance and patience than the skills and tools!
Reply #5932 on: January 22, 2023, 04:26:25 AM
Beautiful work Samek, excellent looking peening.
YAlso very nice HB, and great color too. I have a set of these scissors and a spare recruit spring kicking around. I have just been wresting with making a salesman, sportsman x, cadet x, or golfer with a phillips. Too many options so I might just buy more wenger scissors.
Reply #5933 on: January 23, 2023, 08:46:53 AM
All of those would be worthy very usage…only problem I’d have would be pulling apart the recruit (one of my favourites) in the first place…but I’ve said that about multiple compacts previously too!!
es Offline zdec68
Reply #5934 on: January 24, 2023, 12:15:45 AM
magnificent mod, a beautiful sak.
Congratulations
00 Offline SAKTaschenmesser
Reply #5935 on: January 28, 2023, 03:22:56 PM
Just a test, 84mm Walker with saddle leather scale with burnished sides. The colour and warmth of leather makes this very tactile.
The test piece was made by a leather worker in the UK, just from a photograph, no liner or plastic scale to use as a pattern. Pretty good fit. Leather is same thickness as Victorinox scale.
* IMG_0836.jpg (Filesize: 194.78 KB)
Offline bdpf79
  • New User
Reply #5936 on: February 04, 2023, 10:22:17 PM
Hey guys,
I though I would just show my very first 2 SAK mods.
I wanted 2 knives:
1) A thin one that could be used for urban EDC and that would be the most versatile for the basic stuff I do
2) Another a bit thicker (but still carryable) that would have the basic stuff I need everyday at home but also for basic outdoor stuff like being in the woods, picnics, etc…
So for the first one I opted for the Junior Mechanic
It has a main blade, the combo tool that acts as a flat head screw driver, the Philips screw driver, and then the pliers that are useful to pick up small items my hands can’t reach.
It also has Swiss Bianco titanium plus scales with pen, toothpick, tweezers and pin.
I anodized them blue with satin on the flats.
For the 2nd one, I started from the Explorer that has the nice inline Philips screw driver.
Replaced the main blade with the serrated one from the serrated Spartan
Replaced the hook with the one with the diamond file from the Compact.
Added a saw.
Added the TortoiseGear FireAnt kit
It has Titanium scales from Aliexpress with toothpick and tweezers.
I stonewashed the scales, anodized them bronze with satin on the flats.
All in all, I took my time, did everything slowly but surely and everything turned out great and I am very happy with both.
Started from
Compact
Serrated Spartan
Explorer
Deluxe Tinker
Hiker
Ended up with
Custom Mechanic Jr
Custom Explorer
And then
Spartan
Climber
Super Tinker
That I can use as gifts
All the parts have been used, nothing was wasted ;)
Fun fact: other than the toothpick and tweezers, there is not a single duplicate tool between both Customs ;)
Reply #5937 on: February 04, 2023, 10:49:47 PM
Excellent work, they look great :like:
Reply #5938 on: February 04, 2023, 11:24:45 PM
Fantastic looking mods. Well thought out tool load on each of those. I’d be happy carrying them any day. :salute:
se Offline kottskrapa
Reply #5939 on: February 05, 2023, 07:23:54 AM
Nice work! Looks not only useful but the finish are nice too
March Goal: $300.00
Due Date: Mar 31
Total Receipts: $166.50
PayPal Fees: $9.54
Net Balance: $156.96
Below Goal: $143.04
52%
March Donations
