A mini laser pointer opposite the Phillips to drive you cat crazy at a moment's notice!!!
The Cybertools don't interest you?
Can opener and bottle opener, Syph007-style!
How about a removable flint / fire steel for a wilderness Sak .Sak's rule !
I've thought alot on this too, and what I would do is the full length long phillips like on the 111mm SAKs. It would fold down and under the shorter larger head phillips. I often need small head phillips and longer is better for small screws that are often recessed.
Quote from: Syph007 on June 28, 2014, 11:59:55 PMI've thought alot on this too, and what I would do is the full length long phillips like on the 111mm SAKs. It would fold down and under the shorter larger head phillips. I often need small head phillips and longer is better for small screws that are often recessed.I'd love to have that hidden underneath the scissors on the 91mm. Imagine a Camper WITH a Phillips while keeping the corkscrew. As for the dual openers across phillips layer, I think the 91mm frame might be too short, and if they made a phillips that would fit, it would be a bit too stubby. Maybe a T6 or T8 driver. Or a fold out 1/4 bit driver.
Quote from: enki_ck on June 29, 2014, 03:48:36 AMQuote from: Syph007 on June 28, 2014, 11:59:55 PMI've thought alot on this too, and what I would do is the full length long phillips like on the 111mm SAKs. It would fold down and under the shorter larger head phillips. I often need small head phillips and longer is better for small screws that are often recessed.I'd love to have that hidden underneath the scissors on the 91mm. Imagine a Camper WITH a Phillips while keeping the corkscrew. As for the dual openers across phillips layer, I think the 91mm frame might be too short, and if they made a phillips that would fit, it would be a bit too stubby. Maybe a T6 or T8 driver. Or a fold out 1/4 bit driver.There is no room under the scissors on a 91mm due to the backtools taking up that room. On a 93mm though there is enough room to put one.
Quote from: Syph007 on June 29, 2014, 03:54:17 AMQuote from: enki_ck on June 29, 2014, 03:48:36 AMQuote from: Syph007 on June 28, 2014, 11:59:55 PMI've thought alot on this too, and what I would do is the full length long phillips like on the 111mm SAKs. It would fold down and under the shorter larger head phillips. I often need small head phillips and longer is better for small screws that are often recessed.I'd love to have that hidden underneath the scissors on the 91mm. Imagine a Camper WITH a Phillips while keeping the corkscrew. As for the dual openers across phillips layer, I think the 91mm frame might be too short, and if they made a phillips that would fit, it would be a bit too stubby. Maybe a T6 or T8 driver. Or a fold out 1/4 bit driver.There is no room under the scissors on a 91mm due to the backtools taking up that room. On a 93mm though there is enough room to put one.Weekend project?
Quote from: SAK Guy on June 28, 2014, 06:18:53 PMA mini laser pointer opposite the Phillips to drive you cat crazy at a moment's notice!!! Winner winner chicken dinner.....Sak's rule !
Quote from: enki_ck on June 29, 2014, 03:48:36 AMQuote from: Syph007 on June 28, 2014, 11:59:55 PMI've thought alot on this too, and what I would do is the full length long phillips like on the 111mm SAKs. It would fold down and under the shorter larger head phillips. I often need small head phillips and longer is better for small screws that are often recessed.I'd love to have that hidden underneath the scissors on the 91mm. Imagine a Camper WITH a Phillips while keeping the corkscrew. As for the dual openers across phillips layer, I think the 91mm frame might be too short, and if they made a phillips that would fit, it would be a bit too stubby. Maybe a T6 or T8 driver. Or a fold out 1/4 bit driver.Maybe a bit driver like the Wenger Pocketgrips have? Just stick the bit in the SAK's end?
