You've got me thinking of building my own toolbox complete with those foam drawer inserts with cutouts for each tool, so I can quickly and easily account for all my tools. I don't see a reason why one of those cutouts couldn't be Leatherman shaped though. Especially for working with safety wire and cotter pins, I find Leatherman-style pliers superior to basically any other purpose-built pliers. Long as it gets counted among all the wrenches and sockets, it shouldn't present a FOD risk, no more than a regular set of pliers does.The FOD factor might eliminate tools that have removable screw driver bits from the shopping list. Fixed drivers don't tend to fall out.
Can't find them anywhere.
And now for kirk13, with this edition of "What your internal autocorrect says about you."
I need my eyes tested.I keep seeing 'The Great Hangover Test Thread'
Sweet Odins gonads, get a load of those price tags! There ain't nothing about a metal tube, a button and an LED that costs $64. I could have a light custom cast in solid silver for less than that.
If anyone knows of a pocket clip that fits a 19mm diameter cylinder, let me know. It would fix two of the above issues and make this a passable light.
Several weeks ago, I got myself a job as an aircraft mechanic's apprentice. This means that I'm getting paid to go to school, and I'd like to take this opportunity to invite my college loan officer choke on her own lies. It also means I work with tools a lot, and a great context in which to talk about multitools.With airplanes, you use the "right" tool for the job. This pretty much means don't use pliers to turn nuts and bolts if you can help it. Thing is, I find that a Leatherman sometimes IS the right tool for the job, particularly with safety wire.But *which* Leatherman should I use? I've been using my Skeletool, but frankly I'm getting tired of moving all of my EDC stuff from my street clothes to my work clothes every time I get to work, so I'm thinking of dedicating a tool to work. I'll try out the ones I have for hangar duty before I make any purchases. Each tool will get its own post. So stick around, this should be fun. I'll probably be on a similar hunt for a work flashlight.
Having wrenched on airplanes myself in the past, I would have to recommend the Rebar. Safety wire can be a real turd, I only ever used dedicated safety wire pliers with the ratchet on them. I pretty much carried them in my back pocket. But this is in the days before I really knew a lot about multitools, in fact, I got my first modern leatherman at that job, a Juice S2. The juice wasn't much for safety wire, but the Rebar's super grippy plier head and bombproof replaceable wire cutters make it ideal. I use mine for cutting really hard alloy steel strings every day, and not a single dent. As for cotter pins, Rebar wins again. I find my rebar is almost as effective than my snap on duckbill pliers(every mechanic should have a set) when it comes to pulling out a tricky cotter pin. Congrats on the apprenticeship, I wish I had finished mine out. I went a different (set of) route(s) and wound up as a Machinist, and finally a Shop Foreman. I miss wrenching though, it was pretty darn cool. What Aircraft are you working on? I mainly worked on Twin Otters, single engine pipers, and a few Cessna 180's.
Everytime I see this thread I click on it thinking people are attacking coat hangers with mts and am then quickly dissapointed and saddened greatly.
