standard sized SAK tools on 58mm frame
gb Offline Raukodur
on: July 09, 2014, 02:09:19 AM
Some of the modders here have put some standard sized 91/93mm SAK implements on 58mm frames.
Would it be possible to get a list of implements with which this is possible, with or without minor/major modding.
The thinking behind it is a minichamp which punches well above its weight.
ca Offline Syph007
  • SAK Surgeon
Re: standard sized SAK tools on 58mm frame
Reply #1 on: July 09, 2014, 02:20:18 AM
So far Ive only done the awl, BUT, Im working on putting a standard SAK small blade.  I was also challenged to fit a 91mm combo tool on there, so we'll see if I can make that work.  I dont think Ive seen a 58mm that could open a can.
Any of the tools from the backside of a 91 would be easist for sure.  The awl or chisel for example.  The rest need pretty heavy re-working, but building a 58 with tools it shouldnt have, its kind of fun to think of.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
Reply #2 on: July 09, 2014, 02:23:40 AM
I remember one guy trying to put 91mm pliers in a 58mm frame. :ahhh
Wonder who that was. :P
ca Offline Syph007
  • SAK Surgeon
Reply #3 on: July 09, 2014, 02:30:52 AM
I reworked that so many times.  ANd I do have them fitting now, BUT, some tools that open arent useable... so its not quite ready for prime time.
gb Offline Raukodur
Reply #4 on: July 09, 2014, 04:48:37 AM
Excellent.
The small blade was what I was most interested in, because when you have that and the awl, you are already onto a winner, and then anything else on top of that is extra.
Some tools of the 58mm would do, without needing replacement, e.g. the scissors, nail file/screwdriver, philips combo tool.
The trick would be keeping it slim enough to be a keyring tool still, i.e. limiting what you decide to put on.
The thought of the pliers on there is very interesting.
Edit: a thought; given the width of the 58mm frame seems similar to the 91/93mm frames, could the large blade be made shorter and put on there? So it would need to have its front half (with the tip) snapped off, and end reprofiled, but would it be possible given the space/liner, etc.?
« Last Edit: July 09, 2014, 05:06:34 AM by Raukodur »
ca Offline Syph007
  • SAK Surgeon
Reply #5 on: July 09, 2014, 04:05:08 PM
Yep I think if re-profiled to a sheepsfoot style that could work.  It would be a nice sturdy blade.
gb Offline Raukodur
Reply #6 on: July 09, 2014, 09:22:38 PM
So what is the current list of tools:
Small tools (from 58mm SAKs):
  • scissors
  • philips combo tool
  • nail file / screwdriver
Large tools (from 91/93mm SAKs):
  • small knife
  • modified large knife
  • awl
  • combo tool
  • can opener
Anything I've missed?
mx Offline Chaka
Reply #7 on: July 11, 2014, 04:25:57 PM
I've used the awl and the chisel on 58mm.
us Offline ironraven
Reply #8 on: July 12, 2014, 04:54:11 AM
Say a small blade and a combo tool opposite eachother... need a custom spring but it would be super cool if it worked.
us Offline mrog
Reply #9 on: October 28, 2014, 11:13:08 PM
That would be life changing. Wish I had sweet skills.
"The man who does not read has no advantage over the man who cannot read."
Offline Tjzm1993
Reply #10 on: January 16, 2018, 01:14:06 AM
Personally I would rather suffer with my fingernail than use a combo tool. To me, specifically the bottle opener tool is truly necessary at the core of what represents a SAK in my mind. When i think of a SAK i think of that bottle opener.
The combo tool is dull for opening cans, looks like a poorly redesigned bottle opener, is at an angle making regular screws difficult, and is just ever so slightly too wide to fit normal phillips screws properly. But hey, you still won, you shaved yourself that whole 1.5mm combining the openers and losing your backup blade.
So, finalized version of my $.02: if you're gonna add a combo tool to a 58mm SAK, do yourself a favor and add the bottle opener tool instead, but keep the 58mm phillips combo tool there too.
Also, not that you're any more likely to use it than when it's on a 91mm, but the hook should fit the 58mm body as easily as the awl - 90% sure it wouldn't poke past the end. Perhaps it could see some use filed down to a lockpick or something wild like that.
« Last Edit: January 16, 2018, 01:18:20 AM by Tjzm1993 »
