Speaking of which guys... I just got this. Do you think anything can be done to it (broken both blades, broken scissors spring, broken liner...)or is it bound for the trash bin? It is a Victoria Climber with Pat Pend Can Opener so I would have like to fix it, but I'm afraid the damage is too great...(Image removed from quote.)
@ archerwin. What do you usually sharpen your SAKs with?
I used to use my sharpmaker stones but got one of these for a few dollars and its great to get the shape back and then hand polish with Micro-Mesh .Dont have a pic of mine but its a bit more decrotive than this one with some nice brass details and I am allowed it on my desk as its an antique , I have a few magnets stuck on it which catch a good chunk of the dust.(Image removed from quote.)I have tried with a dremmel but I did not get on with it with the hand crank you are pretty much in complete control
Oh and work from the spine down to get the tip back
Quote from: jaydar on July 28, 2014, 02:18:54 PMOh and work from the spine down to get the tip backThat!^I've inherited a knife or two over the years with chipped points. I use a mill smooth file, (6 or 8 inch) and make smooth strokes down the spine towards the tip. With a little bit of practice, you will end up with a spear point again. Just go slow, and every few strokes, stop and look at how the angle is coming. You won't be able to replicate the Victorinox spear point, but it will be more of a Wenger spear point. And that ain't a bad way to go!
Quote from: cbl51 on July 28, 2014, 04:19:02 PMQuote from: jaydar on July 28, 2014, 02:18:54 PMOh and work from the spine down to get the tip backThat!^I've inherited a knife or two over the years with chipped points. I use a mill smooth file, (6 or 8 inch) and make smooth strokes down the spine towards the tip. With a little bit of practice, you will end up with a spear point again. Just go slow, and every few strokes, stop and look at how the angle is coming. You won't be able to replicate the Victorinox spear point, but it will be more of a Wenger spear point. And that ain't a bad way to go! I have followed the same process with success. In addition to this, I use a Sharpie marker to draw a new outline on the blade and color where metal needs to be removed. That helps me to get the shape as close to original as possible.Sent from my iPad using Tapatalk
@ Corwyn. Take more pics, showing the blades closed and broken liner.
