I made a PSK knife from a broken folder. What do you think?
TCC256 · 10 · 1414
Offline TCC256
I had an old Frost Cutlery knife laying around, that had a broken lock on it, and decided to do something creative with it.
This is similar to the knife I started with.
It was a very easy project. I took the knife apart, to get to the blade. I used a rough file to file down the last half inch or so of edge, and wrapped paracord for a handle. It has 440C steel, and actually takes a decent edge. What do you guys think?
I have done this with a few other cheap broken folders, if you guys would like to see those as well.
« Last Edit: August 06, 2014, 02:46:38 AM by TCC256 »
Re: I made a PSK knife from a broken folder. What do you think?
Reply #1 on: August 06, 2014, 02:39:33 AM
Your link doesn't work. I would like to see the others you made.  :)
Offline TCC256
Reply #2 on: August 06, 2014, 02:47:18 AM
Fixed. Thanks for letting me know. I'm writing up a post about the others now. :)
Reply #3 on: August 06, 2014, 03:48:24 AM
I think that is a clever re-purposing of an otherwise broken tool.  I would be concerned about two things in actual use, however:
  • How comfortable is the "handle", even with the paracord wrap?
  • Given the way the whole thing tapers toward the point, I would be worried my fingers might slip down onto the sharp portion of the blade.
Reply #4 on: August 06, 2014, 09:00:55 AM
Thats a great idea  :salute: ive got 2 larger sized folders that have broke locks so ill give this ago  :cheers:
Offline TCC256
Reply #5 on: August 07, 2014, 05:24:49 AM
I was worried about using it safely myself. I ended the paracord wrap in a fixed loop, that my pinky and ring finger fit into perfectly. This pretty much keeps my hand from moving forward by too much.
ca Offline jzmtl
Reply #6 on: August 07, 2014, 06:57:01 AM
I think a better way to go at it would be grinding down the hollow ground portion under wrap, so you have a physical barrier to keep your fingers safe. Then if you so desire it would be easy to make a small hardwood handle. Looks like the pivot is still intact, so you can even put a pin through it.
br Offline Santos
  • Product of 83
Reply #7 on: August 12, 2014, 03:14:45 PM
- Terry Pratchett
Reply #8 on: August 12, 2014, 03:20:07 PM
reminds me of this
http://bushcraftusa.com/forum/showthread.php/76531-Broken-Knife-Mod
That's a neat mod too. Have you joined Santos? I have been lurking there for a while and checking things out there.
That's us mobile.
br Offline Santos
  • Product of 83
Reply #9 on: August 12, 2014, 04:24:31 PM
i think i am a member dont log in
- Terry Pratchett
