Exposed Flushed Rivets
au Offline archerwin
on: September 03, 2014, 12:22:43 AM
It's common in much older (1950's) SAKs and some mods that I see here.
How do you execute one? Do you make a counter bore on the scale and then peen the brass to fit tightly and then sand flush? Is that the right way to do it?
What scale materials are possible to use for this method? Wood - what kinds? Cellidor scales - only the solid ones?
thanks
ca Offline Syph007
  • SAK Surgeon
Re: Exposed Flushed Rivets
Reply #1 on: September 03, 2014, 03:43:37 AM
Ya you'd need solid scales for sure.  It might be possible to fill modern scales with epoxy for strength and use those though.  Not something Ive tried.
Using a new material would be best though then you can countersink the holes.  Peen away then surface sand the hole scale and make it nice and flush.   :tu:
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
de Offline crackout
Reply #2 on: September 03, 2014, 11:04:44 AM
So, the shield on these old Vics was inserted after the peening/riveting?
Or was it just thicker and sanded like the rest of scale?
Say my name.
us Offline GigaHz
Reply #3 on: September 03, 2014, 02:22:54 PM
I did one with the new type hollow scales. I just inserted the the brass bushing into the scale before drilling out the other side.
ca Offline Syph007
  • SAK Surgeon
Reply #4 on: September 03, 2014, 03:43:20 PM
Ah good to know that works.  :tu:
au Offline PTRSAK
Reply #5 on: September 03, 2014, 10:48:42 PM
I've used that method too.
Reply #6 on: September 15, 2014, 02:39:16 PM
Thanks for your help. I've completed my project.
This is it my 91mm in Queensland Black Walnut with exposed flushed rivets together with my other 91mm in Tasmanian Oak scale.
ca Offline derekmac
  • Little to the right...
Reply #7 on: September 15, 2014, 02:49:38 PM
Those look great!
Sent from my Nokia Lumia 1020 using Tapatalk
Offline DECO665
Reply #8 on: October 04, 2014, 04:11:00 PM
If you wanted to do exposed flush rivets on a wood-scaled Vic is it necessary to stabilize the wood with a wood hardener first? I feel as though it can't hurt, right?
Any experience?
au Offline PTRSAK
Reply #9 on: October 04, 2014, 11:45:17 PM
It depends on the natural hardness of the wood.
Some hard dense woods don't need anything done to them, but softer woods with a more open structure can benefit from at least some superglue in the holes that the pins will go through.
One problem to watch out for is that the glue will make the wood react differently to any finish you plan to apply. e.g. oil won't soak into the wood if it's already been saturated with glue.
Total Receipts: $56.34
PayPal Fees: $2.74
Net Balance: $53.60
Below Goal: $246.40
18%
