Multitool.org
Got Lube? Is it Super? 1331
Global Moderator Absolute Zombie Club Posts: 20,652
« on: September 11, 2014, 05:19:23 PM »
I've been wanting to try this stuff out after reading about it and CPF rating it well.  At $7 a tube for the grease I figured it would last a very long time given the amount needed to lube threads so I got it.
I cleaned the threads on my lights with a simple mirco fiber and very light isopropyl alcohol.  The threads were feeling a bit gritty on some of my most used lights.
I applied a very light dab of the Super Lube on the thread and what a difference,  smooth, smooth, smooth.  Time will tell how well this stuff works but going by what I've read I'm confident this was a good buy.
I also figured I'd "test" it on my ST300 so after cleaning it I applied some and again wow this stuff made a difference.  The opening and closing is smooth but there is one drawback.  Applying it down between the plier jaws is near impossible since its grease.  I smudged it between the implements and also within the tool and wiped the excess onto the tools.
Anyone else use this stuff?
Zombie Apprentice Posts: 18,860 Whiskey Tango Foxtrot, over.
Re: Got Lube? Is it Super?
« Reply #1 on: September 11, 2014, 05:25:37 PM »
Never heard of it. Sounds like good stuff. Where did you get it at?
Might be good to use with the punishment chicken when we run out of lard. :D
« Reply #2 on: September 11, 2014, 05:28:37 PM »
I picked it up at Harbor Freight and Tool.  It maybe cheaper elsewhere tho.
Yeah this and the Chicken  :o let the punishment commence.
No Life Club Posts: 3,392
« Reply #3 on: September 11, 2014, 10:23:04 PM »
According to the Safety Data Sheet, Super Lube Synthetic Multi-Purpose Grease is mostly a synthetic grease plus mineral oil, with 2.5% - 10% suspended Teflon powder.  It sounds like good stuff.  I love trying out new (to me) lubes like this.  They make an oil too, which may be good for plier pivots, etc., where its not easy to apply grease.
No Life Club Posts: 3,303
« Reply #4 on: September 11, 2014, 10:27:52 PM »
Use that whenever I work with any type of bearings or pivots on bikes. It has been absolutely phenomenal in every application I've used it in. Got some hubs on a trash-found bike to spin like brand new after they looked like they would never move again. I have two jars and one of those tubes :D
I would say you will be satisfied.
I'm a total legend..... in my own mind- Herley
Absolutely No Life Club Posts: 9,725 You're amongst friends.
« Reply #5 on: September 11, 2014, 10:35:31 PM »
I found a good deal a while back on some frog silicon lubricant made for flashlights and bought several containers of it. It's also good for watch gaskets.
SAW
« Reply #6 on: September 11, 2014, 11:13:46 PM »
@Powernoodle I haven't seen the oil yet in stores but I'm keeping an eye out.  It would be great in the pivots.
@Higgins great to hear you have experience with this stuff.  I have read up on it and it does sound to be a great bang for the buck.  A little goes a long way on flashlights so this should last me a while.
@Sawman, does that frog lube have a smell?  I got a tool from bay of fleas and it was quite nice smelling.  The seller said he "oiled" it and for some reason I recall frog something.
Absolute Zombie Club Posts: 21,458 Gone
dks cy
« Reply #7 on: September 12, 2014, 08:04:16 AM »
I have given up on using grease for threads as it just attracts dust/sand etc. (I use suitable grease for the rubber seals etc)
I just use some gun oil now (I go that from CPF too)
Also bear in mind that some torches will require an electric contact (a path) between the threads or the lips of the torch tube and the cap etc. so you have to use a material that is an electricity conductor, in those cases, as an insulating grease may stop the light from working.
« Reply #8 on: September 12, 2014, 04:53:59 PM »
Great info DKS.  This is something to be aware of and the 3 lights I used it one are good to go.
« Reply #9 on: September 12, 2014, 09:14:06 PM »
I don't have any in front of me right now but I don't remember it having any.
SAW
dks cy
« Reply #10 on: September 12, 2014, 09:44:33 PM »
Taste?
March Goal: $300.00
Due Date: Mar 31
Total Receipts: $347.59
PayPal Fees: $20.48
Net Balance: $327.11
Above Goal: $27.11
109%
March Donations
Page created in 0.052 seconds with 33 queries.
© 2018 Defender Web & Tool
