Bleh, why can I never find posts with clear info like this when I search.. :/ Thanks for that link though.So I guess the next question then is, are there any 91mm besides the Compact that have a combotool? Throwing $31 at a knife just for one tool is silly.... If there's another larger model with more stuff it might make sense to just use that as the base (instead of hacking up a Swisschamp which is my original idea).
Quote from: Quartz on September 14, 2014, 07:14:54 PMBleh, why can I never find posts with clear info like this when I search.. :/ Thanks for that link though.So I guess the next question then is, are there any 91mm besides the Compact that have a combotool? Throwing $31 at a knife just for one tool is silly.... If there's another larger model with more stuff it might make sense to just use that as the base (instead of hacking up a Swisschamp which is my original idea).Nope just the Vic compact. The next one that has it is the XXLT at lots more $.The combo on the 111mm models (Hunter, Equestrian and workchamp XL) that have it are also the same size, but I doubt those would be cheaper than the Compact.
Quote from: Syph007 on September 14, 2014, 07:23:30 PMQuote from: Quartz on September 14, 2014, 07:14:54 PMBleh, why can I never find posts with clear info like this when I search.. :/ Thanks for that link though.So I guess the next question then is, are there any 91mm besides the Compact that have a combotool? Throwing $31 at a knife just for one tool is silly.... If there's another larger model with more stuff it might make sense to just use that as the base (instead of hacking up a Swisschamp which is my original idea).Nope just the Vic compact. The next one that has it is the XXLT at lots more $.The combo on the 111mm models (Hunter, Equestrian and workchamp XL) that have it are also the same size, but I doubt those would be cheaper than the Compact.The 91mm DofE has one too. Depends on your location as to how available these would be for you
Trail Guides can be found cheap sometimes.
Here's the link.
This is almost invisible, and works OK, well enough at least. But I was much more of a hassle than I originally thought it would be.
I know about the Waiter plus, but they seem rare. I've searched a few times but can't find anyone selling them either new or used.I don't actually care about the can/bottle feature, I just need a flathead screwdriver and general prybar thing.And yes, it'll be a custom 91mm Vic.
Ugh. I knew that the combo was thinner and I wouldn't be able to do as much with it, but I didn't think it was quite that bad. The 84mm combo I have loose in my drawer didn't look quite that flimsy (although it's hard to get a good feel for a loose part when you have no leverage).Is the combo really not even strong enough open a can of paint?
