"58 pattern" canteen+cup+stove+pouch.
Offline Tarrodemierda
  • Smells like tar and smoke.
on: June 26, 2008, 10:09:13 PM
i know most of are propably very keen to this but i aint.but i was looking at some foreign surplus sites,and now ive been thinking of havin one set/kit,so i really wouldnt mind if some of you would guide me to perfect set-up.id rather "official issue" stuff but good quality copies are wellcome too.
i know theres some teflon ones out there too.
-what maker/issue/type of bottle and cup should i get
-                                   stove/burner
-                                   pouch
Re: "58 pattern" canteen+cup+stove+pouch.
Reply #1 on: June 26, 2008, 10:14:37 PM
Just looking for you now mate :)
Reply #2 on: June 26, 2008, 10:17:14 PM
I've been running a similar set up for years, and it's never let me down...
http://www.surplusandadventure.com/shop/survival-emergency/survival-equipment-2/web-tex-warrior-cooking-unit-524051.html
I think you'll have to buy a bottle to go with it though :-\
http://www.surplusandadventure.com/shop/army-surplus/military-equipment/british-army-58-pattern-water-291858.html
Not cheap, but well worth it :)
Reply #3 on: June 26, 2008, 10:27:08 PM
hmm,bit language issues....
so if id get stuff from both links,it would be total kit consisting cup+bottle+puch+burner ?
they dont mention does it fit into molle webbing?
have u used some burning gel or bits?
Reply #4 on: June 26, 2008, 10:32:07 PM
Yeah if you got all the stuff in both links yes  :)
You can use hexamine blocks in the burner, and as for molle, no I'm pretty sure it's for PLCE style webbing  :-\
Reply #5 on: June 26, 2008, 10:58:59 PM
ok its not a big job to modify it to molle compatible.ive used those bits,british ones tend to create smoke and dye everything black but those german ones i have got with pocket stoves are great.BUt i think the gel has more kick.
anyways i might just get a british belt and collect some useful pouches to it if i find some ok priced  seller from uk.
i already have golok in british dpm sheath.i think ill only need pouches for multi and one or two utility pouches,large  and small.ive seen those harnesses with two about 10 litre capacity pouches from the rucksacks sides.
are those you linked,teflon coated?
Reply #6 on: June 26, 2008, 11:01:40 PM
Well it says non-stick, so I guess so :)
Reply #7 on: June 26, 2008, 11:04:13 PM
oh yes the teflon is just a trademark.hmm...i gotta check the totals now ;)
Reply #8 on: June 26, 2008, 11:06:21 PM
I'm still looking to see if i can find them for less :)
Reply #9 on: June 26, 2008, 11:11:10 PM
I think thats the best deal your gona get mate, I paid £14.99 for my Crusader cup alone :o
Reply #10 on: June 26, 2008, 11:12:17 PM
i was just about to ask about that crusader,tell me about it more
Reply #11 on: June 26, 2008, 11:16:53 PM
Well it's probably the most expensive cup known to man :D
Seriously though it is a great bit of kit :), more often than not I use it suspended over a fire and cook in it, and in 6+ years it's still got 90% of the coating left, and is practically indestructable too :), I expect mine to out last me :)
+ Ray Mears takes his crusader all over the world, so if it's good enough for him, then it's good enough for me :)
Total Receipts: $84.35
PayPal Fees: $5.00
Net Balance: $79.35
Below Goal: $220.65
26%
