P.S. I would like something like the Spartan Lite ...
Thanks for the replies but I need something that is in production or easily found so it doesnt cost alot of money.The Passenger would be perfect size.
Quote from: sir_mike on November 01, 2014, 11:46:09 PMThanks for the replies but I need something that is in production or easily found so it doesnt cost alot of money.The Passenger would be perfect size. Pretty much the explorer is your option then.
If a 4 layer Explorer is uncomfortable lying in your pocket you might :try eBay for a Passengeror try a Leatherman Crater c33TX which has an inline Phillips and,it has a pocket clip.ortry hanging the Explorer from a loop of string / paracord from the belt with a clip.Sometimes when the knife hangs vertically in the pocket it's comfortable.A belt sheath could also be a solution.
Quote from: Syph007 on November 02, 2014, 02:35:10 AMQuote from: sir_mike on November 01, 2014, 11:46:09 PMThanks for the replies but I need something that is in production or easily found so it doesnt cost alot of money.The Passenger would be perfect size. Pretty much the explorer is your option then. Yeah, thought so! Just hoping I could find a three layer one.
Explorer --> Passenger is an easy mod to make. You won't even need new pins if you're careful.
Quote from: hiraethus on November 03, 2014, 11:50:16 AMExplorer --> Passenger is an easy mod to make. You won't even need new pins if you're careful. +1. Would be a nice way to get into modding.
I am considering a Spartan lite and would like someone to swapped out the lite for a mag glass.
Quote from: sir_mike on November 03, 2014, 06:19:04 PMI am considering a Spartan lite and would like someone to swapped out the lite for a mag glass.it would be easier and cheaper to remove the scissors from an Explorer than it would be to take the "Lite" out and put a magnifier in (the magnifier has to come from somewhere). The Spartan Lite is, according to SAKWiki, 2mm thicker than the Passenger and only 1mm thinner than the Explorer.The CT29 is technically only 3 layers, but it's as thick as the 4 layer Explorer.
Yes! The lite has thicker liners than it needs to, to accommodate the stupid light.
Drop me a line if you might be interested in the +B Yeoman.
Quote from: Smaug on November 06, 2014, 03:36:07 AMDrop me a line if you might be interested in the +B Yeoman.I call seconds on the +B Yeoman
Quote from: HarleyXJGuy on November 08, 2014, 04:00:43 PMQuote from: Smaug on November 06, 2014, 03:36:07 AMDrop me a line if you might be interested in the +B Yeoman.I call seconds on the +B Yeoman For the price of them, I will have to stick to the Explorer!
Quote from: sir_mike on November 08, 2014, 07:34:02 PMQuote from: HarleyXJGuy on November 08, 2014, 04:00:43 PMQuote from: Smaug on November 06, 2014, 03:36:07 AMDrop me a line if you might be interested in the +B Yeoman.I call seconds on the +B Yeoman For the price of them, I will have to stick to the Explorer! That means I am first in line if he decides to sell.
