Camillus GLIDE Sharpener.
on: November 02, 2014, 09:43:28 PM
Here is a neat little sharpener that would make a good companion for those out in the field. The Camillus GLIDE sharpener is a multitool in its own right. The device resembles the shape and size of a large folder. You get several ways to sharpen items that need sharpening. For example, along the edge, you get 4 sharpening zones, and 3 more zones located in the middle of the tool. Above that, you get 4 Torx bits (1 on each corner -T6, T8, T9, and T10), and a flat head screwdriver at home on one end. The Torx and flat head driver all not detachable, and thus I have to wonder how long they would last before becoming damaged.
Note in the above photos, only one side is labeled. There is also a hole for a lanyard which isn't included with the tool.
On the top side, there are nice arrows tell you which direction your blade should go for proper sharpening. You get a straight multi angle and V carbide sharpener, as well as a ceramic V sharpener.
On the bottom edge, you get a long ceramic sharpener with a groove for sharpening hooks.
Cut into the tool, are 3 angled sharpeners for scissors etc with 20, 30, and 45 degree angles. All told, a nice little sharpener. My complaint have to center around the drivers. They are short and stubby, limiting access to anything flush with a surface. If it is found at the bottom of anything greater than 5mm deep, forget about it. Likewise, those Torx drivers stick out enough to get caught in things, and because they are small, they can also prick your hands when you grab a hold of the tool for use. I jammed a few Torx drivers into my palm just playing around with it. I can only imagine grabbing it in the field with cold hands. If you can live with that, then this sharpener offers quite a bit of options in sharpening blades, knives, hooks, and anything that needs it.
us Offline Higgins617
Re: Camillus GLIDE Sharpener.
Reply #1 on: November 03, 2014, 05:42:14 AM
Great review of what looks to be a pretty thoroughly specced sharpener. The presence of the torx drivers to me make sense only as a way to tighten loose pivot screws on a folding knife in the field maybe?
Reply #2 on: November 03, 2014, 01:32:30 PM
That is the impression I get.
ca Offline ba-ta
Reply #3 on: November 04, 2014, 08:58:15 PM
Or perhaps they are trying to market it as one tool for all your knife maintenance needs. Wouldn't mind getting one for myself, depending on the price.
If it's stupid and it works.....
It ain't stupid.
us Offline captain spaulding
Reply #4 on: November 04, 2014, 09:45:33 PM
Great review! I cringe at the thought of pull through sharpeners though.  :ahhh
I'm the milk man!
ca Offline jzmtl
Reply #5 on: November 04, 2014, 10:57:57 PM
Do people use scissors that much in the field? I dunno, just find it strange that there are THREE slots dedicated to sharpening scissors.
Reply #6 on: November 05, 2014, 12:53:22 PM
I don't think it just for the field.
