FS- Gerber Fisherman
larz · 3 · 1663
Offline larz
  • New User
on: July 08, 2008, 02:42:06 AM
Hi All:
I have a brand new never used Gerber fisheman 600 for sale which includes the regular nylon reinforced sheath as well as the molded "quick draw" kydex (i believe) sheath, box and papers.
Sells for $75.00 asking $60.00 including ground shipping to the 48, specs are as follows:
Carbide cutters, index able and replaceable
Elongated pliers for hook extraction
Fiskars scissors
File with hook sharpener
Tools lock for safety
Product Description:
The Multi- Plier 600 Fisherman is the first U.S.A. built multi-tool designed specifically for anglers. Awarded Field and Stream "Best of the Best" in 2002. The Fisherman has true angler’s needle-nose pliers, replaceable wire cutter inserts, locking components, and can be deployed with one hand, leaving the other hand free. The most innovative feature on the Multi-Plier 600 Fisherman is the wire cutter inserts. These cutting edge wire cutters are made from tungsten cobalt carbide steel.
Technical Specs:
Overall Length: 7.25''
Length Closed: 5.63''
Weight: 8.6 oz.
Handle Material: Stainless Steel
Sheath: Ballistic nylon
Components:
Elongated needlenose pliers with index able, replaceable carbide wire cutters, wire crimper, fine edge knife, serrated knife, Fiskars scissors, cross point screwdriver, small and medium flat blade screwdrivers, lanyard ring, bottle opener, file with hook sharpener, awl and ruler.
« Last Edit: July 22, 2008, 01:49:38 AM by larz »
Re: FS- Gerber Fisherman
Reply #1 on: July 10, 2008, 05:43:56 AM
That's a pretty good price for a unique tool Larz. Any particular reason you decided to sell it?
Offline larz
  • New User
Reply #2 on: July 10, 2008, 11:43:09 AM
Hi
I actually have 2, so this one is basically sitting collecting dust.
Thanks
