Topsaw Chainsaw multi-tool.
on: December 03, 2014, 03:37:23 AM
Meet Topsaw, the Ultimate Power Saw Tool.
The packaging states that you can work on any brand chainsaw, cut off saw, trimmer, and blower in the field. That is if you don't mind carrying something heavy. This tool reminds me of an N-Star AR15 weapon multi-tool in weight.
The Topsaw has the following features:
- T27 torx.
- 4 mm hex.
- Large and small screwdrivers.
- Bar groove cleaner and bottle opener.
- 10 and 19 mm socket.
- 13 mm socket and file handle.
The tool comes with a not bad nylon sheath. With the weight of this hefty and heavy duty tool, the sheath is built well enough to not fall apart on you anytime soon.
Yes, it is an ugly duck of a tool. You are given a D ring for a lanyard, or a tow rope.  ;)
There are a few patent numbers stamped on the tool. Note also the 13 mm socket welded 90 degrees to the surface. the hole seen is, I presume, the file handle holder.
And here it is in all its glory.
So what do I think? Built like a tank, and probably could withstand a lot of abuse in the field, the Topsaw is interesting because it is so different. Different in looks, as well as function. I can see this tool being a handy companion to a logger in the forest, or some other industrial use. It is big, ugly, and heavy. Sometimes, that isn't such a bad thing.
us Offline Lynn LeFey
Re: Topsaw Chainsaw multi-tool.
Reply #1 on: December 03, 2014, 05:10:07 AM
Form following function. It looks like it's exactly what it needs to be to do the job, and not fail in the field. I like it.
Reply #2 on: December 03, 2014, 01:33:44 PM
Looks like that would be handy for a chainsaw. I wonder if that will work for a Stihl?
Reply #3 on: December 03, 2014, 08:12:47 PM
No file for sharpening though.
gb Offline Cupboard
Reply #4 on: December 03, 2014, 08:32:37 PM
The last (and in fact only) Stihl strimmer I had apart used loads of T27s, so that's right at least.
Reply #5 on: December 06, 2014, 08:06:03 AM
Nice overveiw Dan!
I've had one for five years. Works well.
* IMG_0258.JPG (Filesize: 34.68 KB)
Reply #6 on: December 06, 2014, 12:04:19 PM
Good to know! Thanks!
us Offline JBW1
Reply #7 on: December 06, 2014, 09:49:26 PM
The larger size wrench looks like Stihl, and the smaller for Husqvarna\poulan etc. It looks great!
Ive never like having to carry around a 'scwench'. I'd bet with some modding you may figure away to keep an interchangeable file? The hole on the wrench does look like that's its intention, but it would be cool to keep it foldable
Total Receipts: $36.34
PayPal Fees: $1.66
Net Balance: $34.68
Below Goal: $265.32
 12%
