Multitool.org
How to remove the bail? 1032
Sr. Member Posts: 277
« on: November 20, 2014, 11:37:57 PM »
I have an 84mm with bail that has damage tools and would like to try and repair it.  How do you remove the bail? Do you drill it out or can you just flick the bail out with a flat screwdriver?
thanks
Global Moderator Point Of No Return Posts: 36,523
Re: How to remove the bail?
« Reply #1 on: November 21, 2014, 12:18:37 AM »
Is it like the bail on a Wenger SI? They flick out with a flat screwdriver.
No Life Club Posts: 4,722 I'm an Adult?!?! When did that happen?
« Reply #2 on: November 21, 2014, 01:09:56 AM »
Do you mean the bail where the rivet goes all the way through?
answer is CAREFULLY!
Try filing a flat on the end with a fine tooth file then centre punch (lightly) to make sure the drill doesn't wander. Drill well undersize and using a dental burr cut around the inside of the hole so the whole end of the rivet comes off. No danger of marking up the bail.
Alternative method if you plan to replace scales would be cut the rivet down between the scale and outer liner with a razor saw.
No Life Club Posts: 1,240
« Reply #3 on: November 21, 2014, 06:47:16 AM »
DON'T DO IT!
Send it to Ibach for the TLC it deserves.
Lurking with a large collection of sharp knives!
Hero Member Posts: 731
« Reply #4 on: November 21, 2014, 03:47:28 PM »
Will Victorinox work on a 50-year old knife?  The bail was discontinued in 1968.
Drill out the ends of the pins as PTRSAK says.  Only the very ends, then pull off the bail, then carefully peen the pin-ends flat.  You probably won't have enough brass there to file the ends before peening.
« Last Edit: November 21, 2014, 03:58:08 PM by J Mackrel Jones »
Sr. Member Posts: 346 Mounted Swiss Army Knight
« Reply #5 on: November 21, 2014, 05:46:46 PM »
Yes, that's what they do!  :salute:
WANTED: Red Farmer, Red Harvester, Soldier/SI 1975, Genuine Horn scales, Wenger 19th Hole Cigar Cutter
« Reply #6 on: November 21, 2014, 10:36:54 PM »
Don't abuse the privilege, but in a bit word yes.
Ibach is where the special cases should.go, and make sure to send the requested shipping. One good turn deserves another.
August Goal: $300.00
Due Date: Aug 31
Total Receipts: $60.00
PayPal Fees: $3.14
Net Balance: $56.86
Below Goal: $243.14
19%
August Donations
Page created in 0.058 seconds with 33 queries.
© 2018 Defender Web & Tool
