Be warned though a combo edge in 154cm is gona be a total bitch to sharpen mate
how was your only 10 bucks more for a CX?
LM skeletool is more than 20 bucks here.
If you can hold off a few months and get the FreeStyle instead, that might be an even better option.The FreeStyle will be the same thing, only with a permanent screwdriver rather than the bit driver, and will be somewhat cheaper still.Def
I was originally told October for the Freestyle but now I'm hearing it won't be until after the first of the year. Should be very hot when it arrives and will probably have a street price around $30.
I believe it would be all the same materials (as the standard version) otherwise, as it would probably cost Leatherman more to order a plastic part to replace the aluminum and CF parts found on the Skeletools than it's worth.Def
does anybody other than me like serrateds here .
