Kampfer's PLSK (Pliersless Sidekick)
Kampfer · 124 · 14301
Re: Kampfer's PLSK (Pliersless Sidekick)
Reply #60 on: January 08, 2015, 10:53:48 AM
Are you finding the PS4 is handling all your plier duties, Kampfer?
They are better then pliers on 91mm SAK I'd say.
I'd agree with that  :tu:
us Offline Kampfer
  • Tactical Desk Jockey
Reply #61 on: January 08, 2015, 07:11:15 PM
Finally we had agreed on something.
Reply #62 on: January 08, 2015, 07:12:59 PM
 :D :D :D
gb Offline Raukodur
Reply #63 on: January 08, 2015, 11:48:31 PM
us Offline Kampfer
Reply #64 on: January 15, 2015, 06:44:55 PM
PLSK is shown in attached photo, completely disassembled
Also shown are the three parts that had been modified.
* IMG_3207.JPG (Filesize: 80.1 KB)
* IMG_3209.JPG (Filesize: 121.79 KB)
us Offline HarleyXJGuy
Reply #65 on: January 15, 2015, 09:06:55 PM
Thanks Kam this will be useful when I do my mod.
wales Offline magentus
  • mmmmm SAKrelicious
Reply #66 on: January 16, 2015, 02:54:11 PM
That looks like a v smart mod.  :salute:
Offline kalans
Reply #67 on: January 27, 2015, 02:22:56 AM
Hey @Kampfer I am having trouble getting the drivers onto the plier side due to the riveted spring bar tensonioner. I have tried pressing it down, but that only helps getting one on. First LM mod for me, really hoping to get this one done. Thanks!
us Offline Kampfer
Reply #68 on: January 27, 2015, 03:18:49 AM
Hi, I used a pony spring clamp to counter the tension.
If that doesn't work then you should check the shape of yours drivers to make sure they match the shape of pliers.
Offline kalans
Reply #69 on: January 27, 2015, 03:55:23 AM
I was able to get them on, which was very difficult at first lol. The drivers will not straighten out without shaving it looks like, is this correct? Thanks kampfer!
Reply #70 on: January 27, 2015, 05:04:30 AM
Not an expert by any means but I do remember it being said the tools will need some grinding.
I am sure one of the experts will come along and sort you out once they wake up.
Reply #71 on: January 27, 2015, 08:18:04 AM
Got me a care package from Kamasaurus today.
The Sidekick pliers are kinda neat how they open on there own. Still ripping it apart after work though.
Time to reread the threads and see what is up with the file/grinding.
Reply #72 on: January 27, 2015, 11:31:46 AM
Now instead of having a Sidekick or a PLSK I have a pile of parts and a pliers head that wont come off the dang handle.
Took the screws, blade, pocket clip and brass washer off. I am guessing it is some kind of sleeve press fitted in the hole but before I start whacking it I thought I would ask here.
Pretty close to finding a big hammer and going this route.  :twak:
us Offline Kampfer
Reply #73 on: January 27, 2015, 05:32:36 PM
No trick to it, I the the spring tension bar is giving you smurf.
force it out with care.
Reply #74 on: January 27, 2015, 05:46:37 PM
Got that sorted now I am wondering how much to file off the drivers and how I am going to get it back together with the tension from the riveted spring pushing it all out.
Reply #75 on: January 28, 2015, 03:05:14 AM
No ideas huh?
I think there has to be more filed off the drivers so will give that a go after work tonite.
us Offline Kampfer
Reply #76 on: January 28, 2015, 05:57:52 AM
The flat head is made of 420HC, your hand file might be smurfed by it, be ware.
Reply #77 on: January 28, 2015, 06:07:15 AM
Thanks for the info.
So did you grind the piece that you use to open the tool? Like where it would hit the handle?
us Offline Kampfer
Reply #78 on: January 28, 2015, 06:16:18 AM
Yes I did, otherwise the drivers would be 15* off.
Reply #79 on: January 28, 2015, 08:01:10 AM
Good deal.
Going to need a better file I think. Time to make a trip to the mechanics.
us Offline Franimal
Reply #80 on: February 03, 2015, 08:10:50 PM
I am removed the plier and used the pivot post and original bolt to bolt the plier to the tool I wanted to grind the back off of. This way I lined everything up, 'clamped/bolted' it all together and ground it nice and smooth and easy with a dremel. I used the plier as a guide to get perfect angles and 'template'.
I'll post some pictures what i'm talking about later tonight some time.
us Offline Kampfer
Reply #81 on: February 03, 2015, 08:13:52 PM
Please do post photos, love to see em
Reply #82 on: February 03, 2015, 10:45:14 PM
Good deal.
The Harley has started modding?  :salute:
us Offline Franimal
Reply #83 on: February 04, 2015, 05:08:37 AM
Here you go! Wow, i must have been over excited for that post. Even i couldn't follow along with what the hell i wrote!
Pictures are worth a thousand words...
The plier is sandwich between the parts i need to shape using the pivot post. I am going to hit it with a dremel and hope for magic
Reply #84 on: February 04, 2015, 05:18:56 AM
Good deal.
Started yes, finished no.
Reply #85 on: February 04, 2015, 06:13:55 AM
Good deal.
What is the hold up?  :think:
Reply #86 on: February 04, 2015, 06:16:16 AM
Good pics bro, shows the difference nicely.  :tu:
Reply #87 on: February 04, 2015, 07:29:37 AM
Good deal.
The little files I have are not up to the job. have not got around to "borrowing" some from the mechanics.
Been busy around here.
us Offline Kampfer
Reply #88 on: February 04, 2015, 09:28:02 AM
Excellent work :tu:
Reply #89 on: February 11, 2015, 01:41:59 PM
So I scored some files from the mechanics and am making some progress. Got the phillips and flathead sorted where they will go on the tool but they will not close.
Guessing a good little bit of the back end area needs to be ground off?
Total Receipts: $0.00
PayPal Fees: $0.00
Net Balance: $0.00
Below Goal: $300.00
 0%
