Possible?
fr Offline hellsing
Possible?
on: January 24, 2015, 11:14:32 AM
Is it possible to put the wingman scissor on a charge, instead of the serrated edge?
I love the big scissor of my surge and want an equivalent on my charge. Are the wingman scissor good enough?
us Offline sawman
  • You're amongst friends.
Re: Possible?
Reply #1 on: January 24, 2015, 12:12:07 PM
It's been done on a Wave so it should work on a Charge.
SAW
gb Offline Cupboard
Re: Possible?
Reply #2 on: January 24, 2015, 02:12:40 PM
They're not the greatest scissors in the world though.
wales Offline hiraethus
  • I brake for cake
Re: Possible?
Reply #3 on: January 24, 2015, 02:39:58 PM
Works on the Wave.  Here's mine:
 :think:  You might need to muck about with extra washers on the Charge, if the Wingman scissors are thinner than the blade they're replacing.
The scissors are OK.  Better than the stock Wave ones, not as good a Micra/Style CS.
fr Offline hellsing
Re: Possible?
Reply #4 on: January 24, 2015, 08:40:19 PM
Yeah i know, but surge one's are too big for a wave/charge.
Maybe some victorinox one's, but it's harder to make.
that's exactly what i have in mind, thanks.
us Offline tommywp
Re: Possible?
Reply #5 on: January 25, 2015, 12:02:09 AM
I'd like to do this too. But I don't have a spare awl to replace the small stock scissors. Any idea if a Wingman clam shell opener could take the place of the small stock scissors on a Wave?
us Offline HarleyXJGuy
Re: Possible?
Reply #6 on: January 25, 2015, 07:42:18 AM
I have seen 91mm SAK scissors on a Wave before.
Someone here was saying the Wingman scissors while ok to start with were much improved with a good sharpening.
Micra/Style scissors are in the running for the best MT scissors of all imo.
  • I brake for cake
Re: Possible?
Reply #7 on: January 25, 2015, 08:35:16 AM
Yes, it should fit (thickness is OK) but you'll need to reshape the area around the pivot a bit so you can close the handles completely.
Shhhh, you'll wake Lynn. :D
us Offline Breezy12
Re: Possible?
Reply #8 on: January 25, 2015, 08:42:35 AM
just so you know -- you'll have to enlarge the pivot hole on the Wingman scissors to do this.
good luck with your mod, and keep us posted with pics! :D
fr Offline hellsing
Re: Possible?
Reply #9 on: January 25, 2015, 06:20:03 PM
How much do i need to enlarge? I don't have carbide bit, just regular bit or a dremel.That's the main problem with the vic mod, you can put vis scissor but you need a good bit, and it don't close very well.
I already have spare awl to replace the small scissor, just need to buy the wingman scissor or a full wingman.
us Offline Breezy12
Re: Possible?
Reply #10 on: January 25, 2015, 09:32:19 PM
the Wingman pivots are 3/16", and the plier pivots on a Wave/Charge are 7/32", so it's not much.
I use a 1/8" carbide bit in my Dremel and slowly enlarge the pivot hole, frequently stopping to do a test fit. I'm not sure how well it would work with a regular drill bit; I seem to remember someone having a problem with the Wingman scissors snapping. :think:
ca Offline Toolslinger
  • Thread Killer 2015
Re: Possible?
Reply #11 on: January 26, 2015, 02:31:07 AM
fr Offline hellsing
Re: Possible?
Reply #12 on: January 27, 2015, 06:28:56 PM
ok thanks all for the answer.
Time for some change after all the reading on this topic and in the mod section.
It gonna be on an old wave, no big change. And it will be sak scissor as they cut better and i manage to find one in my garage (no need to buy a wingman).
quite like in this thread: http://forum.multitool.org/index.php?topic=41869.0
just wondering why he doesn't drill in the hole, so the lock would have work.
fr Offline hellsing
Re: Possible?
Reply #13 on: January 29, 2015, 10:49:01 PM
Possible and done:
And the lock is working, notre perfectly sadly as i grind half a millimeter too much.
* 2015-01-29 22.46.56.jpg (Filesize: 331.95 KB)
* 2015-01-29 22.46.21.jpg (Filesize: 399.1 KB)
us Offline Breezy12
Re: Possible?
Reply #14 on: January 30, 2015, 08:43:14 PM
looking good! very nice work. :)
I think that's the first time I've seen Vic scissors on an OG Wave... :think:
fr Offline hellsing
Re: Possible?
Reply #15 on: February 03, 2015, 01:59:48 PM
Thanks, it looks me more time than expected, quite hard to put back the plier on this og wave. Close up on the lock:
* 2015-02-03 13.58.58.jpg (Filesize: 195.47 KB)
Re: Possible?
Reply #16 on: February 03, 2015, 05:28:02 PM
Glad to see someone else doing this mod. :tu:
As I said there, the hole should be raised from the actual Victorinox pin hole, and the bottom of the scissors flattened for the lock to work properly. :D
There was actually a mod done later that added a shim to the scissors so the scissors don't lock in 90° anymore, just full open position. Can't find it now though. :-\
Re: Possible?
Reply #17 on: February 03, 2015, 11:41:02 PM
Nice work mate.  :tu:
