What is the best way to remove patina?
Benner · 30 · 5850
on: July 19, 2008, 08:55:08 PM
I am thinking of removing the patina from my Carbon V Trail master;
Does anyone know what is the best way to do it without me affecting the etching on it?
Cheers guys.
Offline jock1
Re: What is the best way to remove patina?
Reply #1 on: July 19, 2008, 09:47:24 PM
I am no help whatsoever but why would you want to it think it adds character to the blade
Reply #2 on: July 19, 2008, 09:50:44 PM
Normally I would agree, but I think I would rather this knife without.
Reply #3 on: July 19, 2008, 10:29:10 PM
My only success has been with a buffing wheel on my Dremel tool. I'd be interested in finding something easier myself.  :-\
Reply #4 on: July 19, 2008, 10:49:56 PM
I was going to sugest a buffering wheel too, see how well it comes off with normal soap and water first, failing that it's the dremel of VERY fine sand paper :)
Reply #5 on: July 19, 2008, 10:56:20 PM
How about metal polish?  Brasso?
us Offline WhichDawg
Reply #6 on: July 19, 2008, 10:58:40 PM
they just talked about this in BF (last month) http://www.bladeforums.com/forums/showthread.php?t=566288
hope you get it!
Reply #7 on: July 19, 2008, 10:59:22 PM
hope you get it!
Nope can't see it.  :(
Reply #8 on: July 19, 2008, 10:59:59 PM
Nice one Dan
Reply #9 on: July 19, 2008, 11:01:31 PM
so Micky can see it but Ben can't?
Reply #10 on: July 19, 2008, 11:02:20 PM
I'm guessing Mike is a member.  :-\
Reply #11 on: July 19, 2008, 11:02:44 PM
I re-enlisted on BF recently, never made a post though ;)
Reply #12 on: July 19, 2008, 11:04:43 PM
Basically there sugesting the same thing we are, but adding some chemicals into the equation like Flitz :)
Is Flitz like Brasso ???
Reply #13 on: July 19, 2008, 11:05:07 PM
I'll put what they say;
"Never dull" The wadding stuff that comes in a can will do the trick. You can also use it to blend a un uniform patina too.
i use a fine sandpaper like 1200 and up, or i use a scotchbrite pad or some super fine steel wool...basically any really fine abrasive.
you can also use metal polish...a common one i hear about is simichrome or flitz
with the steel wool/scotchbrite, you might rub out some of the gray color, but as long as you don't scrub too much you should still have a nice patina left over...
I use super fine steel wool or 1500 wet dry followed by buffing it using a little buffing wheel attached to my drill press.
The neverdull will not make it new and shiny unless you polish it for a long time. You can use it to more or less blend the patina, and even it out.
If you use 0000 steel wool or a scotchbrite pad, add WD-40 to it. It will cut down on the stratching of the blade. It gives a nice satin finish.
Man, I need to get some Flitz..I had some years ago, and that stuff works wonders...I am having trouble finding it in the store lately.
Flitz would be my choice after the above-mentioned remedies (oooo steel wool and WD 40). I love patina and think it gives a knife a lot of character. It makes the user wonder where the knife has been and how it achieved that well-worn look.
« Last Edit: July 19, 2008, 11:07:14 PM by WhichDawg »
Reply #14 on: July 19, 2008, 11:06:01 PM
I never heard of it?!
Reply #15 on: July 19, 2008, 11:08:45 PM
Heathen :o, it's practically a national institution over here :)
Reply #16 on: July 19, 2008, 11:16:54 PM
Wouldn't I lost me etch by doing any of those though?
ca Offline jzmtl
Reply #17 on: July 19, 2008, 11:17:10 PM
Burn it off with a propane torch.  >:D
Reply #18 on: July 19, 2008, 11:18:24 PM
It all depends how deep you go when sanding it away :)
Reply #19 on: July 19, 2008, 11:21:59 PM
exactly, I doubt if you'll go that deep (if you sand).
Reply #20 on: July 19, 2008, 11:36:07 PM
and the first stuff they suggest is "Nevr Dull" http://www.nevrdull.com/What.htm
Reply #21 on: July 19, 2008, 11:37:00 PM
Sounds a bit like Autosol :think:
Offline Tarrodemierda
  • Smells like tar and smoke.
Reply #22 on: July 20, 2008, 02:51:17 AM
ive used nevr dull a lot on chopper parts,especially on pipes,its really good stuff.
Offline jdailey4206966
  • America- Love it or leave it, but don't bleed it!!
Reply #23 on: July 25, 2008, 05:15:36 AM
Brasso does an ok job, but it doesn't fully remove it. I have used scotch-brite on a blade, but if you have a razor sharp edge, kiss it goodbye because the scotch brite will dull the hell out of a knife, but its the best way to remove a patina I found. I was given an old case that had somewhat a patina and had alot of rust, but I used scotch-brite and some wd-40 and it was like a new blade, but I had to resharpen it. Can split hairs with it now, but it is in my knife collection.
J
Offline Leatherman123
Reply #24 on: July 25, 2008, 05:20:49 AM
I have a product called Brite Boy that removes patina fairly well..
Ben, how do you like the San Mai knife steel?
B
Reply #25 on: July 25, 2008, 09:11:17 AM
It's not SanMai it's a Carbon V one, I doubt you'd be able to get a San mai blade to accept an etch :)
Reply #26 on: July 25, 2008, 12:26:59 PM
Like Mike said, it's Carbon V - hence the patina.  ;)
Thanks for the suggestions.  :)  I had a quick go with brasso, but didn't have much luck.  I think I need to adopt a liking for the patina rather than finding a way to remove it.  :D
Reply #27 on: July 25, 2008, 12:58:02 PM
I never said to try brasso! :P :D
get yourself some Scotch-Bright! (not steel wool!) it's cheap like...never mind :twak:
Reply #28 on: July 25, 2008, 01:06:31 PM
You didn't, but others did  :pok: :pok:
Reply #29 on: July 25, 2008, 01:08:21 PM
the bastoids!  :P
