Zebralight getting stuck
on: February 12, 2015, 10:33:39 PM
Yesterday night I grabbed my Zebralight SC51 off of the nightstand and wanted to turn it on in moonlight, the long press. But instead it went straight into High-high. And was stuck there. Off-On. Still in high. Pressing the button to make it cycle through modes. Still High. (No, not me, the flashlight. :twak: ) Took the battery out and clicked the button a few times, reinserted the battery. Still only High. :think: Repeated the process a few times and finally managed to engage a low but it had a lot of flickering. :-\ Played around a bit with it and after a few attempts to get it to cycle it started acting normal again. :shrug:
The last and only mode I used it that day was High and it was running in that mode for maybe 10 minutes, so high from of and no cycling. Switched it off normally and the next time I turned it off, it got stuck.
It's in full working order now again but I found it odd and a bit worrying. Never happened to me in all the years I've had it. I know we have a few Zebralight fans here (and Al, who's a bit less of a fan of it :P ) so I was wondering if anyone had similar issues with their lights.
I seem to remember someone posting about their light having similar problems but that turned out to be cause they cycled to much and went into maintenance mode.
us Offline captain spaulding
Re: Zebralight getting stuck
Reply #1 on: February 12, 2015, 10:48:57 PM
Never had anything like that happen with mine. Not sure why yours would be doing this.  :think:
I'm the milk man!
um Offline Mr. Whippy
Reply #2 on: February 12, 2015, 10:51:34 PM
I can't remember:  Does the Zebralight have a lock setting (my Lumapower D-mini VX has a lock setting that is pretty easy to accidentally set)
Reply #3 on: February 12, 2015, 10:53:04 PM
Nope. Lockout is by backing off the battery cap.
I'm the milk man!
Reply #4 on: February 12, 2015, 10:57:59 PM
Not doing it. Did it once last night. Hope it doesn't happen again.
As the Captain said, unscrewing the tail cap a bit is the only lockout available. Would be useful though as the SC51 was notoriously known for accidentally turning on in the pocket.
Reply #5 on: February 12, 2015, 11:10:13 PM
Guess I wasn't clear.  On the Lumapower, if you click 3 times in rapid succession, it will lock the setting.  That is, if it locks on high, you can't cycle through to low until you unlock it again.
Reply #6 on: February 12, 2015, 11:29:46 PM
Yup, I understood you. ;) But the unscrewing the tailcap slightly IS the only "lockout" available on the SC51. Don't know how familiar you are with Zebras but there's a lot of clicking modes there. 7 mods in total 3 of them available from off. And no lockout.
The button is quite raised and soft so it was very easy to turn it on accidentally so a lot of people were asking for a redesign of it when the SC52 came out. I think they just made it harder to click and more recessed. Still no lockout on the new model either.
au Offline gregozedobe
Reply #7 on: February 13, 2015, 04:27:24 AM
Many of theses sorts of issues with Zebralight have been related to low voltage (either battery or poor contact on tailcap).  Mine can get quite weird when the battery gets too low, but swap in a freshly charged battery and everything is working as per normal again.
Reply #8 on: August 13, 2016, 02:35:16 AM
And I had it happen again. :facepalm:
Cleaning the the threads, changing the battery, nothing helped.
So I started clicking the switch repeatedly in quick succession. After about 50-60 clicks, the medium mode popped up and after that it started normally working again. :shrug:
Reply #9 on: August 14, 2016, 01:59:29 PM
And this is the first time it's happened in the last year and a half?
Reply #10 on: August 14, 2016, 02:12:43 PM
Yup. I had it hung in my tent as a night light during the first trip at the start of July but forgot to take it out when I packed up my tent. Then during this trip I left it up although it was only on moonlight due to low battery. When I got home I put in a fresh battery and noticed it was stuck.
Probably got locked in on high during storage/transport, but I never heard or read anywhere that the Zebras have a mode lock function and there's nothing like it mentioned in the manual.  :shrug:
Reply #11 on: August 14, 2016, 04:15:49 PM
It's definitely not something I've heard about anywhere else.  Perhaps worth a message to Zebralight themselves?
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
