What I want to know Kwakster is do you repair multi"s like professionally?
I have two Swisstools that need fixed...
How did you manage to break them? They seem really solid.
Neither are either of them really broken.
The first one and X has a bunk plier head that the pivot is so loose on that the wire cutters make serious contact with each other when closing. Yes I know I can send it in for warranty work just haven't done it yet.
The second is my RS, my helper cut a live extension cord with and almost burned a hole in the blade at the same time. I polished up the blade and resharpened it and its fine really. But there is something wrong with the pivot on the blade and the crate opener next to it now. They are both much harder to get out, and they both clump together when trying to open either.
By all means do send them in for warranty work! I read on here where a man cut a live wire with is super tool and it nearly ate all the wire cutter out of them. He sent them in and had them back in 2 weeks.
If SAK has a full lifetime warranty, than this should be covered as well.
