I don't have a cybertool to compare sizes, but what about a 1/4" square drive.(Image removed from quote.)
Maybe house a bit in the corkscrew cut out and then add the appropriate bit driver as an inline tool.
Quote from: tommywp on April 20, 2015, 10:38:00 PMMaybe house a bit in the corkscrew cut out and then add the appropriate bit driver as an inline tool. Wenger already came up with a much better solution. The Pocketgrip houses 6 full sized bits (if pliers would be dropped, maybe even and carries the bit driver adapter in place of the corkscrew. (Image removed from quote.)(Image removed from quote.)(Image removed from quote.)(Image removed from quote.)
A spoon knife?
I'm a lurker here at the forums and love your work Syph. I hope this thread is a sneaky way of asking which layer you should work on adapting to the 91mm frame next. Anyway, I wish Victorinox made a 91mm layer with the phillips+can-opener+cap-lifter and reamer+fine-screwdriver on the back.That layer with the serrated-blade+electrician-blade&corkscrew and scissors&hook layers would be the perfect SAK for me.One can only dream.
I have two primary wishes for Victorinox: Different blade shapes (not a fan of the spear-point) and bring back the marlin-spike(Image removed from quote.)
I'm not sure how the extra reach under torque would effect the drivers and pins. I fear there would be a lot driver bending and possible pin breakage.
Ooh ooh, an olive fork, or a tape measurer too small to read, or a hairbrush............ Oh wait, those are in that one display at the factorySent from my iPhone using A box of monkeys on a treadmill and a quantum leap
