Tire patch question for the bike gurus
ca Offline jzmtl
on: April 22, 2015, 08:26:22 PM
How long does the glue in kit last if untouched, assuming left outside throughout the year (not particularly hot in summer but cold in winter)? I can't check the glue's condition without punching the top, but don't want to open up a tube of nothing if I need it.
us Offline Higgins617
Re: Tire patch question for the bike gurus
Reply #1 on: April 22, 2015, 08:45:31 PM
it's usually just some type of super glue or rubber cement, I've had them go solid on me after a few years. Have you tried the slime patches??
I'm a total legend..... in my own mind- Herley
Reply #2 on: April 22, 2015, 09:58:08 PM
Mine seems ok after a year,but i have too admit i mainly just change the tube,especially if im on the trail, :tu:
Reply #3 on: April 22, 2015, 10:41:11 PM
I usually find they go like toothpaste and only the bit by the opening harden. Having said that it's a wee bit colder where you are :)
ca Offline jzmtl
Reply #4 on: April 23, 2015, 03:15:44 AM
Never heard of those. The kit is really for emergency since I ride recreationally and not too far from home. I've only patched once and it was with contact cement and a piece I snipped off another tube, didn't use the kit I have. The other time the inner tube completely blew up and I had to call for a ride home (no, it's not the same tube I patched  :D).
« Last Edit: April 23, 2015, 03:16:50 AM by jzmtl »
au Offline bounding star
Reply #5 on: April 23, 2015, 03:39:54 AM
I cant say for certain, but the glue we have in our kit has been used on and off for at least a decade and still seems to work
wales Offline hiraethus
  • I brake for cake
Reply #6 on: April 23, 2015, 10:54:45 AM
If the tube is sealed and still squishy it''ll probably be ok.  New tubes of vulcanising solution are available, but normally they're bigger than you need and cost more than buying a new patch kit. ::)
I've tried the self-adhesive patches and didn't get on with them, but for emergency use they might be ok.  Carry a spare inner tube too, just in case. :tu:
ca Offline 16VGTIDave
Reply #7 on: April 23, 2015, 03:37:59 PM
I used to buy larger tubes of rubber cement, or even tins of it. Now I buy tiny "single use" tubes because I find that once a container is opened it will dry out in less than 6 months. I'd rather use a portion of a tiny tube of cement and dispose of what isn't needed, than have a larger tube of solid rubber when I need to patch a tire.
I EDC'd a SAK before MacGyver did...
ca Offline jzmtl
Reply #8 on: April 23, 2015, 09:34:35 PM
This brings up another question, is the bike tube glue exactly the same thing as contact cement or is it something else special?
nz Offline Syncop8r
Reply #9 on: April 24, 2015, 12:54:39 AM
B133 vulcanising fluid if I remember correctly...
