Kwakster, I know this is your giveaway, but for what it's worth I'd like to cast a vote for Roadie as well.
Cheers guys But you know if i do get it i'll have to try it out first right.....just to make sure it works.....just being a good friend you understand
You can send it to Canada if you like... Def
Kwakster,Very generous of you...awfully good show...let me know about that paracord bracelet Roadie,Well done, hope your friend doesn't give you the third DEGREE as to how you will test it, what with your DEGREE of luck you will probably loose/break it. Flash Another one in our midst? The more the merrier!
