Serrated MT blade sharpening
Kev D · 18 · 1901
england Offline Kev D
on: August 12, 2015, 05:21:54 PM
I leant my surge to someone at work today to cut a hose that turned out to be steel wire reinforced, and he has severely blunted the serrated blade  :facepalm:
Can any of you recommend a good sharpening system so I can sharpen it? I was looking at the spyderco sharpmaker, is that any good for serrated blades?
Cheers
Kev
us Offline Smaug
  • Desk Jockey
Re: Serrated MT blade sharpening
Reply #1 on: August 12, 2015, 07:57:31 PM
Not really. It has a way to orient the rods so that the tips of the triangles will (theoretically) reach into the serration gullies. In practice, it rounds off the pointy tips of the serrations.
Best thing is a tapered rod. Doesn't have to be expensive or particularly fine. I use this one:
http://www.amazon.com/Smiths-PP1-Pocket-Multifunction-Sharpener/dp/B000O8OTNC/ref=sr_1_1?ie=UTF8&qid=1439401863&sr=8-1&keywords=smith%27s+knife+sharpeners
I used that the other day; worked great. If you want the serrations to be honed as well as sharpened, you'll need to find something a little higher-end.
I use the carbide and ceramic rods to sharpen plain edge knives I really don't care much about, or that are really badly ground from the factory.
-Jeremy
"Well begun is half done."
-Aristotle
us Offline raistlin65
  • An Alox SAK Made Me Do It!
Reply #2 on: August 12, 2015, 08:16:40 PM
+1
Smith also has this diamond rod: http://www.amazon.com/gp/product/B001910FOA.
us Offline Dean51
Reply #3 on: August 13, 2015, 08:56:58 PM
I use a KME guided diamond system for Plain edge blades and was using a ceramic rod for the serrated kitchen knives. The rod is to big for the rebar's serrated blade so I'm going to get one of these two.
us Offline Smaug
  • Desk Jockey
Reply #4 on: August 13, 2015, 09:16:07 PM
Get the balisong-style one. Matches the multi-tools. :)
-Jeremy
-Aristotle
us Offline smiller43147
Reply #5 on: August 14, 2015, 01:15:13 AM
I love the spyderco sharpmaker and I have sharpened serrated blades with it.
I'm not a big fan of serrated blades, so I don't know how it works long term, or on a damaged blade.
- Steve
ca Offline Toolslinger
  • Thread Killer 2015
Reply #6 on: August 14, 2015, 01:22:02 AM
+1 for the Sharpmaker. If you go slowly and work the rod in the serrations, you can avoid blunting the tips. It's all in the technique, you can't go fast like with a plain edge.
I have also used rods with success, but have a full Sharpmaker setup sitting on my workbench.
« Last Edit: August 14, 2015, 01:23:11 AM by Toolslinger »
us Offline TRUE LIBERTY
us Offline Dean51
Reply #8 on: August 14, 2015, 04:31:31 AM
Why didn't I think of that.  :ahhh
400 vs 600 grit, the balisong looking one is 600, I think that'll be the one.
nz Offline Syncop8r
Reply #9 on: March 22, 2021, 09:45:01 AM
Five and a half years later, does anyone else have any advice on a good serrated blade sharpener?  :pok:
Has anything else appeared on the market since?  :think:
fi Online Antti Lammi
Reply #10 on: March 22, 2021, 10:12:23 AM
Not really but this helps little, it has different size rods on 1
Only Tools Matters
Reply #11 on: March 22, 2021, 10:12:50 AM
Not really but this helps little, it has different size rods on 1 http://www.jokerknifestore.com.au/warthog-sharpeners-diamond-serrated-blade-sharpene
Only Tools Matters
nz Offline Syncop8r
Reply #12 on: March 22, 2021, 11:14:38 AM
Oh that's cool.  :tu:
A little expensive though.  :-[
nz Offline Syncop8r
Reply #13 on: April 19, 2021, 06:32:40 AM
I'm going to give the Eze Lap Diamond Sharpener ST a try.
Reply #14 on: April 19, 2021, 04:35:00 PM
Should work pretty well. I've been looking at getting one or a DMT.  I've got a ton of work to correct some seriously borked serrations on a used Cold Steel Voyager I bought. Two larger serrations have chips, and a finer serration has completely been broken off.
nz Offline Syncop8r
Reply #15 on: April 19, 2021, 11:48:46 PM
The diameter is smaller than the large serrations on the Wave and Surge so I'll have to employ some sort of sideways motion to sharpen those.
Since purchasing it I have noticed the Smith's sharpeners that Dean51 (RIP) showed for sale nearby.
Reply #16 on: April 20, 2021, 12:15:49 AM
Or wrap it in folds of sandpaper till it fits.
spam Offline Happy Gilmore
Reply #17 on: April 21, 2021, 03:44:27 AM
the most efficient way to sharpen a serrated blade is to remove material from the back by laying it completely flat onto a sharpening stone, it will take a little time but it will create a consistently sharp edge.
