The Mega84
gr Offline firiki
Re: The Mega84
Reply #60 on: September 01, 2015, 01:17:28 PM
:rofl: BRILLIANT!!!!!!
Grip pin in chuck, set to hammer, and "drill" the side of an axe head at a slight angle! Just enough pressure to get the hammer action to kick in, but not enough to bend the pin. A perfectly pre-peened pin in seconds  :D
WE DEMAND A VIDEO! :ahhh
Hear, hear!  :whistle:
I was referring to a 91mm metal saw earlier; I know 84mm ones are hard to find. Besides, newer ones are better ;)
I'm probably too late for this but what if you turned the pruner balde to a wharncliffe, a sheepsfoot or a bevel point? More function then.  >:D  :)
It was your preference of cellidor that I recalled, then.
Now you've got me thinking about a mod I had in mind... Will you be modding a Wenger next by any chance?  :ahhh
Re: The Mega84
Reply #61 on: September 01, 2015, 01:23:31 PM
No vids, sorry.
I was tempted to use the MFV blade for turning into a wharncliffe actually. Unfortunately, it's only 2.0mm tang thickness and I need the 2.4 due to the awl tang thickness.
Yes, Wenger may well be next, but that's (hopefully) a MUCH simpler project  :)
Re: The Mega84
Reply #62 on: September 01, 2015, 01:32:01 PM
84mm saw springs are a PITA  >:(
Re: The Mega84
Reply #63 on: September 01, 2015, 01:40:46 PM
Awl spring is protruding a little, which means the Phillips is sitting high. I've marked it up with a sharpie marker to see if it can be reprofiled without compromising the spring under the cap lifter
* IMG_20150901_123625_1067_800.jpg (Filesize: 44.04 KB)
Re: The Mega84
Reply #64 on: September 01, 2015, 01:44:19 PM
Peening with a hammer drill, you've got to love it.  :drink:
gr Offline firiki
Re: The Mega84
Reply #65 on: September 01, 2015, 01:48:28 PM
No video  :cry:  :P
I was thinking of a Vic/Wenger frankenmod. I wonder if you could offer some insight on Wenger entrails once you got it open.
But that's not for now. You're tackling the first project yet.  :cheers:
:popcorn:
Re: The Mega84
Reply #66 on: September 01, 2015, 02:03:30 PM
 :oops: That's not going to work grinding that off  :whistle:
Bacon sandwich and cup of tea required while I think this through....
* IMG_20150901_130029_1067_800.jpg (Filesize: 39.17 KB)
Re: The Mega84
Reply #67 on: September 01, 2015, 02:05:02 PM
No video  :cry:  :P
:popcorn:
 :tu:  :cheers:
Re: The Mega84
Reply #68 on: September 01, 2015, 03:20:32 PM
Bacon butty completed, Mega84 built up and clamped, and Phillips sits at an acceptable height with no spring modification (spring sits sufficiently off centre on the driver).
Commence operation "whack it with a hammer"  :D
ca Offline Syph007
  • SAK Surgeon
Re: The Mega84
Reply #69 on: September 01, 2015, 03:35:02 PM
I really can't believe how well that works. They've actually slightly "over peened" and don't quite seat in the bushings, so I'm just tickling them up with a file. It actually gives a nice domed and burnished finish.
Alox modders take note!
Ha, I had that idea and tried to peen an alox mod together... the drill got away from me and just ended up damaging the scales.  I gave up on peening alox after that try.  :D
As for pre peening I dont bother any more just put the rods through, cut to lenght and pen both ends.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
Re: The Mega84
Reply #70 on: September 01, 2015, 03:43:38 PM
Mega84 v1 is complete and operational
:nanadance:
* IMG_20150901_143531_1067_800.jpg (Filesize: 63.14 KB)
* IMG_20150901_143618_1067_800.jpg (Filesize: 64.42 KB)
* IMG_20150901_143720_1067_800.jpg (Filesize: 51.34 KB)
* IMG_20150901_143744_1067_800.jpg (Filesize: 54.39 KB)
Re: The Mega84
Reply #71 on: September 01, 2015, 03:49:27 PM
Very nice Al  :salute:
Re: The Mega84
Reply #72 on: September 01, 2015, 03:50:29 PM
It's not 100% perfect, and there is a tiny bit of daylight between the springs/liners, though it is fully functional.  :tu:
Re: The Mega84
Reply #73 on: September 01, 2015, 03:52:03 PM
Using the hammer drill for pre peening did make it a lot easier, although I just finished off with a hammer so I had more control  :tu:
Re: The Mega84
Reply #74 on: September 01, 2015, 03:52:53 PM
Cheers mate  :cheers: I'll carry it for a while and see how it works out  :)
us Offline sawman
  • You're amongst friends.
Re: The Mega84
Reply #75 on: September 01, 2015, 04:27:00 PM
Great work :tu:
SAW
Re: The Mega84
Reply #76 on: September 01, 2015, 04:29:04 PM
I carried it for half an hour before I realised I forgot something  :ahhh :ahhh
Mini-driver for the corkscrew  :D Now sorted  :tu: ;)
A quick count up of the features:
Full sized plain blade
Full sized serrated blade
Scissors
Wood saw
Corkscrew
Nail file
Inline awl
Phillips driver
Large flat blade driver
Small flat blade driver
Eyeglasses precision driver
Can opener.... untested  :whistle:
Cap lifter
Wire bender
Toothpick
Tweezers
Re: The Mega84
Reply #77 on: September 01, 2015, 04:29:46 PM
ca Offline Syph007
  • SAK Surgeon
Re: The Mega84
Reply #78 on: September 01, 2015, 04:55:05 PM
 :salute:
I think thats gotta be the most tools on an 84mm mod Ive ever seen.  Excellent job!
us Offline sawman
Re: The Mega84
Reply #79 on: September 01, 2015, 05:05:47 PM
I so envy you folks that have the skill to mod these SAKs. As SAKs are one of my favorite things, I like them even more for the fact they can be customized with so many different parts/implements as I like to call them. I've pondered over what would make my perfect SAK and it changes almost daily. Currently, I am quite content with the Swisschamp, but would actually like to add a pruner blade and electrician blade to it, along with possibly some other implements.
I think the SAK I really want is the XLT (correct me if I'm wrong), the one the adds the pruner, elec. blade, and cyber tool.  ???
Anyhow, whenever I see a mod like this it gets the gears turning in my head and if I could afford the overhead, I might even get into modding myself!  ::)
SAW
Re: The Mega84
Reply #80 on: September 01, 2015, 05:13:10 PM
:salute:
Thank you  :salute:
Coming from a professional modder, that means a lot  :cheers:
ca Offline Syph007
  • SAK Surgeon
Re: The Mega84
Reply #81 on: September 01, 2015, 05:19:30 PM
:salute:
Thank you  :salute:
Its hard to think of what else you'd be able to add.  Pliers would be kind of impossible to add on an 84, so the only other thing you could go for would probably be a metal file/saw.  It would work on the wood saw backspring, but youd have to shorten it to fit.
I stopped working on 84s as it was much more difficult than any other size to work on.  I still get alot of requests though for cadets with scissors, so someday I'll get back to working on that size.
Re: The Mega84
Reply #82 on: September 01, 2015, 05:27:58 PM
So far as this goes, I certainly wouldn't call myself skilled. I just winged it  :D and it was all done at my kitchen table (apart from the peening - table wasn't up to it, so I used the concrete step outside the back door) without any special tooling. The right size nail could be used for a punch. A large hammer as an anvil.
As to the XLT wishes, my next Vic mod will be a Cyber-Outdoorsman. Take a CT41, ditch the pliers, and switch the large and small blades for large serrated and pruner. However, I've not completely abandoned the idea of also breaking up a Voyager Lite, including the Phillips and torch layer, switching the hooks over for the nail file on the back, and of course having the alarm clock scales.
In the meantime I have one more mod to look at. A simple (hopefully) Wenger upgrade  :)
Re: The Mega84
Reply #83 on: September 01, 2015, 05:35:23 PM
:salute:
Thank you  :salute:
Yeah, I think the best thing for pliers on an 84 would be to start from scratch, and conjure up something like they have on the Rangers with the triple backspring. Not a job for at the kitchen table though  :D It would have been nice to have the metal saw in there too, but that might have been one tool too many. At the minute it's a very good size and weight, and isn't too unwieldy or obtrusive.
I was actually walking around earlier and thought to myself you can't actually tell it's in the pocket.... then I realised it wasn't even in my pocket  :rofl:
us Offline sawman
Re: The Mega84
Reply #84 on: September 01, 2015, 05:38:59 PM
:salute:
Thank you  :salute:
 :twak:
SAW
Re: The Mega84
Reply #85 on: September 01, 2015, 05:40:36 PM
Scissors
Wood saw
Corkscrew
Nail file
Inline awl
Phillips driver
Cap lifter
Wire bender
Toothpick
Tweezers
I forgot can key  :ahhh
Re: The Mega84
Reply #86 on: September 01, 2015, 09:07:52 PM
Well, I'm very pleasantly surprised!
Despite the can opener's compromised positioning, upon offering the tool up to a range of different sized cans, it seems the can opener should work fine on cans of up to 85mm diameter (standard cans being around 75mm diameter). So standard cans will be fine, but larger cans may be a problem. I can live with that.
us Offline tommywp
Re: The Mega84
Reply #87 on: September 01, 2015, 10:12:00 PM
I can picture you at your kitchen table, stuffed to the gills, unhappily eating tuna fish, beans, peaches and spaghetti-Os so as not to let them go to waste
gr Offline firiki
Re: The Mega84
Reply #88 on: September 01, 2015, 10:19:28 PM
:nanadance:
Now, that's quite an unusual SAK toolset, especially clad in nylon scales! No key ring tho'  :rofl:
Re: The Mega84
Reply #89 on: September 01, 2015, 10:20:39 PM
I only offered it up, I didn't actually start opening them, but yeah a chucklesome image :D
The can I found where it might start to struggle was a can of new potatoes. I'll have a go at that one tomorrow. If I can get that open, I know I'm good to go with anything smaller  ;)
