Hytest Axe
TazzieRob · 134 · 33103
au Offline TazzieRob
Hytest Axe
on: September 01, 2015, 02:26:12 AM
Back in 1997 we moved into a house with a wood heater. I'm not sure where this axe came from (my dad probably sourced it somewhere) but I used it to split a fair amount of gum over the next 10 or so years. It has been at my mum's place and used in the garden for chopping roots.
I bought a new handle for it a while back but never fit it. Found it in the shed and asked my mum about the axe. It was looking in a sorry state so I said I would put the new handle on and will give it a sharpen.
The stamp is hard to see. I could make out CRAFTS initially but with a bit closer inspection thought I could see an H and TEST 4. Bit of online search found the Hytest Craftsman. It was originally painted green, and a trace of green can still be seen in the stamped lettering. This is either a 4 or 4.5 lb axe. Handle was either American Hickory or Spotted Gum. They were made in Australia and now Cyclone one the trade name, though doesn't look like they use it on any currently produced axes
« Last Edit: September 01, 2015, 02:27:29 AM by TazzieRob »
Re: Hytest Axe
Reply #1 on: September 01, 2015, 06:33:32 AM
Nice
Watching  :popcorn:
Re: Hytest Axe
Reply #2 on: September 01, 2015, 07:57:42 AM
Here is a great advert from the Canberra Times 1958:
http://trove.nla.gov.au/ndp/del/article/136300552
The Forester - For the Timber Getter (most expensive)
The Craftsman - For the Farmer (middle)
The Challenger - For the Householder (most affordable)
Hopefully I'll get some evening time in the shed coming up to get the new handle on. Knowing the history now I wish I'd shelled out the extra few dollars for the spotted gum handle, but I remember standing in the store for a good while examining all the handles picking out the one with best grain orientation.  I'll probably use an aluminium wedge, as I'm pretty sure I have a couple.
Re: Hytest Axe
Reply #3 on: September 01, 2015, 08:35:18 AM
Looks like a good axe.       :popcorn:
Re: Hytest Axe
Reply #4 on: September 02, 2015, 03:32:43 PM
Cut the old handle off. It must have been only using about 60% of the handle due to the top portion being split. Removed a couple of the wedges. You can see the holes where they were and them sitting to the left of the vice  :whistle:
There is a proper metal wedge in there somewhere too, but it was too small and has ended up at a 45 degree angle.
Here's where I got to tonight. No wedge in yet as the ones I have are too small.
Close up of the stamp which you may be able to just see
Not sure if I should take the handle off again and file beck those protrusions in the eye or just bang the wedge in as is. What do you guys think?
The aren't very clear in the pic.
Re: Hytest Axe
Reply #5 on: September 02, 2015, 03:40:01 PM
I also weighed the head when I had it off. Came in at 2.015kg  or 4 lb 7 oz. So it would have been a 4 1/2 lb model.
Filed the nicks out of the cutting edge a bit too, and a slight sand of the handle. I have some raw linseed oil but have read that boiled linseed is better to use.
Re: Hytest Axe
Reply #6 on: September 02, 2015, 03:44:27 PM
IMO leave it as is and go with a wooden wedge.
Re: Hytest Axe
Reply #7 on: September 02, 2015, 08:21:22 PM
Hey Rob your bench looks very much like mine  :tu:
I would take the handle out and just file back any sharp edges/burrs on the inside of the eye (top and bottom) (if you haven’t already)
Raw linseed is OK to use but might take a little while to dry
Re: Hytest Axe
Reply #8 on: September 02, 2015, 11:30:04 PM
^  ^  ^. Agree with Tony.
us Offline toolguy
Re: Hytest Axe
Reply #9 on: September 03, 2015, 12:39:59 AM
I knew the head looked big but a 4 1/2 pounder is real felling axe.
Re: Hytest Axe
Reply #10 on: September 03, 2015, 04:14:15 AM
I'm not very good at keeping things spick and span. My whole shed looks a lot like the bench!
There aren't any sharp edges or burs but some that may cause reduced surface contact if they don't bite into the wood. I'll back the handle out again and give it a bit more clean up. Looks like the eye may be deformed a touch from heavy hitting on the poll. Will give the raw linseed a go.
This one was designed or priced towards farmers and land owners for everyday duties. Came in 3.5, 4, 4.5 and 5 lb heads. I've never felled a tree, but this axe has split its fair share of wood.  :tu:
« Last Edit: September 03, 2015, 04:18:02 AM by TazzieRob »
Re: Hytest Axe
Reply #11 on: September 03, 2015, 04:20:54 AM
Notice the deodorant can alcohol stove in the bottom left of the bench pic?
Re: Hytest Axe
Reply #12 on: September 03, 2015, 06:33:20 AM
I do now  :tu:
And the beer keg below   :D
Re: Hytest Axe
Reply #13 on: September 04, 2015, 09:21:03 AM
Just a tiny bit more of bump in the top of the eye and then I'm done.
Will stick a nice thick wedge in there.
Wondering if I should vinegar it first or wire brush inside to clean up some of the rust?
nz Offline Syncop8r
Re: Hytest Axe
Reply #14 on: September 04, 2015, 12:07:56 PM
For real fellers.  ;)
Re: Hytest Axe
Reply #15 on: September 05, 2015, 11:54:51 AM
The hardware store doesn't sell timber wedges, so I made my own. Using a flap sanding disk on the 4" angle grinder. Made my shed super dusty! Feeding the handle with linseed oil now, then will burnish with steel wool and finish the sharpen.
It was sharp enough that when it fell over and chopped through my vacuum cleaner cord it tripped the breaker to the shed! :rofl:
Re: Hytest Axe
Reply #16 on: September 05, 2015, 07:36:54 PM
That’s brilliant Rob!  :D
Re: Hytest Axe
Reply #17 on: September 06, 2015, 01:06:05 AM
Thanks, mate  :cheers:
I made the wedge chunky enough to fill the extra space due to the handle being a tad small for the length of the eye. As I was pounding the wedge in I had to do it on the floor and dropped the axe. Thankfully it only got the one cord as there were a few laying there!
« Last Edit: September 06, 2015, 02:23:56 AM by TazzieRob »
Re: Hytest Axe
Reply #18 on: September 06, 2015, 01:14:12 AM
I made the wedge chunky enough to fill the extra space due to the handle being a tad small for the leg th of the eye. As I was pounding the wedge in I had to do it on the floor and dropped the axe. Thankfully it only got the one cord as there were a few laying there!
Lucky it didn't get your toes  :pok:
Re: Hytest Axe
Reply #19 on: September 06, 2015, 02:26:28 AM
Kneeling down and it fell away from me. Even if I was standing the head would have ended up a handle length from my toes in any direction  :tu:
Re: Hytest Axe
Reply #20 on: September 05, 2017, 01:04:46 AM
Something very strange has just happened.
I logged into Photobucket with the intention of redoing the photos in this post by downloading them and adding them to Google Photos, and now I can see them straight from Photobucket. I'm assuming no-one else can see them?
Re: Hytest Axe
Reply #21 on: September 05, 2017, 03:43:00 AM
So here are the updated pics
Before:
Eye after Nail "wedges" removed
Start of fitting process
Stamp
Before Tidying up the Eye
Eye Grinding
Casualty
Finished and oiled
Re: Hytest Axe
Reply #22 on: September 05, 2017, 04:52:40 AM
Nice before and after pics :like: :like: Looks like a nice axe :cheers: but be careful :ahhh :ahhh :ahhh :D
Just noticed this thread is a couple years old :whistle:  So how is it holding up :think:
« Last Edit: September 05, 2017, 04:55:15 AM by Poncho65 »
Re: Hytest Axe
Reply #23 on: September 05, 2017, 06:35:20 AM
She's a real beaut Rob  :cheers:
Re: Hytest Axe
Reply #24 on: September 05, 2017, 08:11:45 AM
Well its last actual outing was in May
Could do with another oil on the handle probably
Re: Hytest Axe
Reply #25 on: September 05, 2017, 08:12:16 AM
Cheers Tony  :cheers:
Re: Hytest Axe
Reply #26 on: September 05, 2017, 08:14:52 AM
I got another one the same at a local market a while back too. It has a bung handle too so might try and source a spotted gum replacement and try the green head and red stained handle like the original. Or that might just be too much work!
Re: Hytest Axe
Reply #27 on: September 05, 2017, 12:26:52 PM
Just don't forget pics if you do buy and fix it up :dd: :like:
Re: Hytest Axe
Reply #28 on: September 05, 2017, 09:01:29 PM
More  :popcorn:
Re: Hytest Axe
Reply #29 on: September 06, 2017, 04:00:05 AM
More  :popcorn:
Don't get fat eating all that popcorn waiting for me to work on this  :rofl:
Total Receipts: $66.45
PayPal Fees: $3.99
Net Balance: $62.46
Below Goal: $237.54
21%
