My Fenix E21 bit the dust....... well kind of. Its acting weird and I am hoping someone might be able to help me fix it if at all possible. I will try to explain what it is doing. When I start to depress the tail switch the light will come on in momentary, but once the switch "clicks" the light is not producing any light. When I depress the switch again (which would be to turn it off) it comes on momentarily and when it "clicks" the light is off again. Any ideas?
MODs please delete the other threads accidentally posted. Something is up with MTO. I screen capped the error.
I had similar problems with my LD20 - turns out the LED/circuit board holder had come slightly loose inside the head. Maybe the same construction on the E21? Unscrew the head from the body and inside there's a ring with two holes - I managed to wedge the tips of a pair of needle nose pliers in there and tighten the while thing back down, worked fine after that.
I fixed it and you where exactly correct as this is what was wrong. I pulled the back end of the light off and noticed the metal ring with the two holes. I found SAK pliers worked the best and screwed it tight... or so I thought. I guess it is reverse threaded as I loosened it and it fell apart into 5-6 pieces. Put it back together and screwed it in counter clockwise until tight. Works perfectly now.
