Okapi Sisal knife, a small fixed blade from around the 1960's-1970's timeframe.
The handle consists of 2 riveted Bakelite halves with a steel finger guard in front, while the sheath is made from one piece of Bakelite coupled to a fake leather belt loop.
Since the knife came completely blunt i gave it a new edge of about 30 degrees inclusive along the entire edge.
This makes for wider bevels near the point (as the steel gets thicker there), as i want the knife to be able to cut also with that area, not just scrape.
The tough & springy steel takes a very good edge and is treetopping sharp.
Specs:
Overall length: 20,6 cm / +/- 8 inch
Blade length: 10,7 cm / +/- 4 inch
Blade thickness: 1,95 mm /
Steel type: carbon steel
Weight without sheath: 87 gram
Weight with sheath: 132 grams
