When visiting a sports shop in a small town here in Sweden I stumbled over some really nice Compacts (and Scientists).
The most intriguing part about the Compacts are that one of them might shed some light over the 91mm Golfer and Compact timeline. I am new here so correct me if there is reason for it.
The lot consists of:
One (1) Compact (labeled so on the box - 1.3405), no hook, groved corkscrew and no pin. Box labeled "52n" and "7" on the inner tabs. Scissor with screw
One (1) Compact no hook, groved corkscrew and with pin. Box labeled "52n" and "11" on the inner tabs. Scissor with screw.
Seven Compacts with hook, non-groved corkscrew and with pin - only, probably, differing from the current offering in the nailfile on the hook part. Scissors riveted and groove guide for the spring.
If anyone wants me to check anything to help in the timeline for Compacts - this might be a good opportunity.
Together with the Scientists:
edited the inner tabs numbers as I had switched them around in the text.
edit 2 info on the scissors
