Show me your Bike Tools
ch Offline Etherealicer
Re: Show me your Bike Tools
Reply #30 on: February 19, 2016, 11:09:24 AM
My bike tools are my Swisstool X which is my edc and a 1 euro costing 6 inch adjustable wrench which i keep in my jacket pocket.
I never really had any problems with my bike except for a couple of times when i put to much force on the pedals that cause the rear wheel to pull forward on one side and that causes the tire to rub against the frame. Loosened the main nut and put the wheel back in its correct position.
Thanks for sharing. I love seeing what others carry  :tu:
+1
Although I wonder what you use for tyre-levers :salute:
fi Offline AlephZero
  • Smurf smash!
Reply #31 on: May 12, 2016, 08:02:43 AM
My latest bike tool is Topeak Ratchet Rocket. I've neededwanted one for quite some time and finally pulled the trigger... :D
Here's couple of pics of said tiniest of the tiny ratchets:
In the (apparently waterproof) plastic case are the ratchet, bit kit /w chain tool and two small tire levers:
Given the minuscule size of the tire levers, I would probably only use them in emergency situation, but it's nice to have them as a backup as they take no space whatsoever.
Closer look at the ratchet and the bit storage:
Bit kit has pretty much all the bits you'll need with your bike, hex bits 2mm to 6mm, Philips #2 and Torx T25. In my case I'll be pairing this up with my Skeletool /w Bit Kit and Bit Extender, so I'm good for pretty much any screw around here :)
All in all, excellent piece of kit :tu:
« Last Edit: May 12, 2016, 08:21:29 AM by Aleph78 »
"Hoarder of weirdness,
Always posting random things,
I'm AlephZero" :ninja:
Reply #32 on: May 12, 2016, 08:19:12 AM
Bit kit has pretty much all the bits you'll need with you bike, hex bits 2mm to 6mm, Philips #2 and Torx T25. In my case I'll be pairing this up with my Skeletool /w Bit Kit and Bit Extender, so I'm good for pretty much any screw around here :)
Nice, I've been looking at that one too... love my two Topeak ratchets :tu:
wales Offline hiraethus
  • I brake for cake
Reply #33 on: May 12, 2016, 10:29:09 AM
Here's my current kit:
2x inner tubes
Topeak Mini 9 Hex/Torx keys + screwdrivers
Tyre levers
Cable ties
Tyre boots
Puncture kit (also contains a few 11-speed chain links and a spare M5 screw)
Pedros chain tool (with spoke keys)
Chain lube
Duct tape
Nitrile gloves
Rag
Multitool (today a Charge TTi)
ca Online Grant Lamontagne
Reply #34 on: May 12, 2016, 11:49:09 PM
I need to dig out some of my bike tools and add to this thread.  Still haven't located a lot of my stuff after the move though...
Ded
us Offline rishardh
Reply #35 on: May 14, 2016, 07:33:08 AM
Nice, the built in chain tool is a nice touch  :tu:
us Offline rishardh
Reply #36 on: May 14, 2016, 07:54:24 AM
Speaking for chain tools I have not seen anyone's chains break on a ride in the last 5 years or so. Looks like they are solidly built now. I probably jinxed myself saying that  :P
Still can't believe we've gone up to 11 speed systems. Not too long ago I remember thinking 9 speed was awesome. I guess once they get to 14-15 we will not need front gears.
Reply #37 on: May 14, 2016, 01:09:52 PM
Who wouldn't want an 87 speed bike?  :D
I remember my first mountain bike- it was 18 speeds, and I recall everyone telling me then that there was no way I would use all of them.  And they were right.  More often than not I really only used the three gears on the crank.  Occasionally I would switch one of the rear gears, but not that often.  Probably 80% of my shifting was in those three gears.
us Offline rdub934
Reply #38 on: May 16, 2016, 03:23:38 AM
That's funny, I am the exact opposite: I'll use all 7 on the wheel, and only scarcely change from my smallest crank-sprocket.
us Offline rdub934
Reply #39 on: May 16, 2016, 03:27:05 AM
I went riding with this huge duusher two years ago and he simultaneously got a rear flat and broke his chain. It was hilariously satisfying :tu:
Reply #40 on: September 26, 2016, 07:39:22 AM
Topeak Nano TorqBar DX
Small ratchet with room for 2 bits in the shaft + torque limiting bit (Topeak calls it a TorqBit). Of course you can put a regular bit extender, or a 3rd bit in place of the TorqBit.
Feels solid built and is really nice machined, of course it is not made for rusty screws that haven't been moved in aeons.
* torqbar_01.jpg (Filesize: 54.65 KB)
* torqbar_02.jpg (Filesize: 70.66 KB)
« Last Edit: September 26, 2016, 07:42:21 AM by Etherealicer »
Offline pauluspaolo
Reply #41 on: November 24, 2016, 02:06:41 PM
Good topic this as I've quite a few bike multi-tools all of which are useful to a greater or lesser degree.
I always carry the following either on my bike or in my commute backpack: inner tube (of a suitable size for whichever bike I'm riding), tyre (tire!!) levers, pump, folding allen keys/screwdriver set, Leatherman Wave, pocket torch/flashlight (AA cell).
Unfortunately most of my decent/nice tools (I have an old & very nice Topeak Alien) are at home with my bikes. I do try & cycle into work at least once a week though so I do have these two stashed away in a drawer in my office in case of emergencies. The first one is rubbish (though the allen keys/screwdrivers are usable - the spanner is impossible to use) whilst the Bell is altogether nicer, it's still not great quality but the spanners are at least usable & useful though, they also lock into position which is a nice touch on such an inexpensive tool. Like other tools also shown this one splits in two for convenience/ease of use & the halves can be used as tyre levers (that's the idea anyway I think).
Cheap one:
The Bell - open & closed:
As I say I do have others & I'll post a photo of them if/when I get chance  :)
« Last Edit: November 24, 2016, 02:29:30 PM by pauluspaolo »
Reply #42 on: May 30, 2017, 10:24:28 AM
I will take some better pics of it soon.
Reply #43 on: May 30, 2017, 03:25:06 PM
The picture is good... but we need more information. How wide does the spanner open... where can I get one...
  • I brake for cake
Reply #44 on: July 16, 2017, 07:21:27 AM
My current setup.
Bigxtop tool roll, can be used as a saddle bag or chucked in a bigger bag depending what I'm riding.
Contents:
Clockwise, from top left: Hex keys, torx key, oil, tyre boot, tubeless tyre 'anchovies', tube, rag, gloves, Rebar, duct tape, chain tool (and spoke keys), puncture repair kit, 8mm hex key adaptor.
  • I brake for cake
Reply #45 on: July 16, 2017, 04:11:27 PM
Multitool wiki says 18mm: http://wiki.multitool.org/tiki-index.php?page=Cool+Tool
AFAIK, it's been out of production for at least 10 years, probably more like 20. You could ask Gerber, they bought the rights to make them.
  • Smurf smash!
Reply #46 on: July 17, 2017, 12:28:17 PM
Reposting with working pics...
nz Offline Syncop8r
Reply #47 on: August 15, 2017, 12:51:08 AM
* 20170815_094146.jpg (Filesize: 123.65 KB)
* 20170815_094211.jpg (Filesize: 125.18 KB)
* 20170815_094342.jpg (Filesize: 146.76 KB)
Reply #48 on: January 29, 2019, 09:34:45 PM
Bumping this thread due to needing inspiration.   :pok:   :cheers:
  • I brake for cake
Reply #49 on: January 30, 2019, 02:20:48 PM
Damn flickr.  I'll get some more pics up...
Reply #50 on: January 30, 2019, 03:06:35 PM
Old but I think a link would not hurt
Nutter from Full Windsor & Urban 8 from Topeak
Full review here
* nutter_02.jpg (Filesize: 477.59 KB)
Reply #51 on: January 30, 2019, 03:12:27 PM
Lezyne T-Driver
Neat little bit-driver in well crafted carry container. You can take the yellow bar out for storage... That said, it's overpriced
* tdriver.jpg (Filesize: 127.89 KB)
nz Offline Syncop8r
Reply #52 on: February 01, 2019, 08:52:56 AM
Tyre levers. I haven't had to use them yet, but I like how they fit together. :dd:
nl Offline bonc
Reply #53 on: April 25, 2019, 04:02:52 PM
I commute by bike everyday and these are what I bring with me every day.
* 20190425_153456~01.jpg (Filesize: 133.64 KB)
- Juice CS4 '01 / Charge AL '13 / Charge TTi '12 & '14 / Wave '01 / Freestyle '10 / Skeletor CX '17 / Style CS '16
us Offline ezdog
Reply #54 on: May 05, 2019, 02:06:33 AM
Got the Hard Tail out and cleaned up a little Today just to make it rain again evidently!?
At least I got to round up some old friends again though too.
nl Offline bonc
Reply #55 on: May 05, 2019, 03:32:19 PM
My bike kit got upgrade  :D
* 20190504_204335~01.jpg (Filesize: 141.62 KB)
gb Offline MrMckay
Reply #56 on: May 09, 2019, 06:40:22 PM
Just got this today! So far I'm impressed
Sent from my SM-G960F using Tapatalk
gb Offline andywork
Reply #57 on: May 24, 2021, 01:10:19 PM
I thought this thread could do with some extra peddling…   :facepalm: ;)
So here are most of the tools I carry, depending on which trike/bike I’m riding.
Mostly Park Tools. Though I also really like the No-Name Allen key and spanner two-part multi tool – a cool Christmas present from my Aunty (bottom right, of the photo). :tu:
I’m contemplating the upgrade to the Topeak Ratchet Pocket DX.
How’s it holding up, over time?
Keep on pedalling!  :salute:
nz Offline Syncop8r
Reply #58 on: May 24, 2021, 02:03:36 PM
I'm glad you spoke. I would post again, but I would just be recycling.  ::)
gb Offline andywork
Reply #59 on: May 24, 2021, 03:28:55 PM
