Sebenza thread
Dunc · 215 · 22689
Re: Sebenza thread
Reply #90 on: November 02, 2008, 07:37:29 PM
I'll show you mine if you show me yours  :P
Dunc
Re: Sebenza thread
Reply #91 on: November 02, 2008, 07:43:34 PM
Mine is a bit further over than that. In fact, it goes over a bit more now I have cleaned it.
I'll take some pics in a bit.
Re: Sebenza thread
Reply #92 on: November 02, 2008, 07:46:41 PM
The funny thing about Sebbies lockbars  is they can change a bit with use but go back to a default position when striped and put back together .
Dunc
Re: Sebenza thread
Reply #93 on: November 02, 2008, 07:58:16 PM
Dunc
The lube I used is quite thin and it spread over the lock bar which may have caused it to go over a little more.
Still, it's maybe at 80% now which is fine.  :)  The lock up is really impressive.
scotland Offline Sea Monster
Re: Sebenza thread
Reply #94 on: November 02, 2008, 08:01:17 PM
Stupid private sebenza owner's club.
I'll bet you've even got some kind of magical handshake.
Gits.
Re: Sebenza thread
Reply #95 on: November 02, 2008, 08:03:30 PM
Gits.
No but we have one for you  :P  :D
Dunc
Re: Sebenza thread
Reply #96 on: November 02, 2008, 08:07:47 PM
Ben don't worry about the lockup , there was a guy over at bladeforums who used his daily for 12 years and he reckons the lockbar hasn't moved .
   Also don't worry if you grip the knife hard and the lockbar goes over and touches the other side . As long as it doesnt touch when opening .
Dunc
Flash
  • Guest
Re: Sebenza thread
Reply #97 on: November 02, 2008, 08:49:29 PM
Ben, Dunc,
Will you both please stop posting pictures...I am trying VERY hard not to buy one  >:(
Flash
Re: Sebenza thread
Reply #98 on: November 02, 2008, 08:54:41 PM
Dunc
It is far from touching the other side.  Here is how far mine travels;
Re: Sebenza thread
Reply #99 on: November 02, 2008, 09:00:11 PM
Ben, Dunc,
Flash
Sorry Pal!  :D
Just a few quick pics whilst I had the camera out.  :)
Flash
  • Guest
Re: Sebenza thread
Reply #100 on: November 02, 2008, 09:02:28 PM
smurfo  >:(
Re: Sebenza thread
Reply #101 on: November 02, 2008, 09:02:52 PM
Ben I wouldnt say that was 80% , more like 60 . Looks perfect to me . Sometimes the pocket clip can effect it . Btw are you keeping the pocket clip ? I don't like the clip and theres no way I'm trusting it to keep the knife safe . Deep pocket carry for me .
Dunc
Re: Sebenza thread
Reply #102 on: November 02, 2008, 09:07:44 PM
Great pics Ben , Doesn't the blue spacer and thumb stud look nice against the grey Ti ?
Dunc
Re: Sebenza thread
Reply #103 on: November 02, 2008, 09:07:53 PM
Dunc
That was after I took the blade out again.  It seems to not go over as far now.
I am using the clip and I quite like it.  I wonder if you would feel any different if you tried the small one?
Re: Sebenza thread
Reply #104 on: November 02, 2008, 09:10:35 PM
Dunc
Are you driving Flash mad on purpose?  :D
Yes I think it sets it off really nicely.  :)  The blue seems pretty hard waring too, as considering this has seen quite a bit of use it has not lost much.
Flash
  • Guest
Re: Sebenza thread
Reply #105 on: November 02, 2008, 09:13:39 PM
Double smurfo  :twak:
us Offline Smitty44
Re: Sebenza thread
Reply #106 on: November 05, 2008, 06:07:29 AM
Ben I have the same one that you have,and I just looked at your lock picture,and at mine,and they are in the exact same place,I did rub a #2 lead pencil across where the lock slides over,and it worked a lot easier because of the graphite in it works like a lubricant. :salute:
Re: Sebenza thread
Reply #107 on: November 05, 2008, 05:32:31 PM
Since taking that picture, I noticed that my pocket clip was too tight and that the tension was causing the lock to go over further than it would normally.  After a minor adjustment (yes I bent it  :D) the clip is still snug on the lockbar when the blade is closed, but there is a tiny gap when the blade is open. The whole action is a lot smoother now, and the bar goes over slightly less (about 50% over).
Smitty, do you carry yours using the pocket clip or do you get on well without it?
Re: Sebenza thread
Reply #108 on: November 05, 2008, 09:44:47 PM
I am giving it a go without the pocket clip ATM, so have replaced the clip with the insert.  I have also swapped the screws around (again  ::)) so they match the insert.
This is how it looks now;
Re: Sebenza thread
Reply #109 on: November 05, 2008, 10:24:47 PM
 Have you tried to copy the Chris Reeve lanyard knot yet ?
Dunc
Re: Sebenza thread
Reply #110 on: November 05, 2008, 10:26:06 PM
No not yet.  Not sure if I want a lanyard yet, but before I give it a go I want to get some black paracord.
Re: Sebenza thread
Reply #111 on: November 05, 2008, 10:33:06 PM
I'm keeping mine on till it falls off , which may not be that long as I keep toying with it in my pocket  ::)
  Have you noticed how the titanium warms very quickly in the hand  :)
Dunc
Re: Sebenza thread
Reply #112 on: November 05, 2008, 10:34:21 PM
You two clearly have too much time, and far too much money on your hands :D
Re: Sebenza thread
Reply #113 on: November 05, 2008, 10:35:59 PM
Dunc
I sure have.  :)  Mind you I have pretty much been playing with it since I got it.  :D
Re: Sebenza thread
Reply #114 on: November 05, 2008, 10:36:57 PM
Says Mike going green with envy  :P
 Ben , remember those things called multitools we used to be into  :oops:
Dunc
Re: Sebenza thread
Reply #115 on: November 05, 2008, 10:37:20 PM
Time, yes, money, certainly not.  :D
Did have before the Sebbie though.  :D
Re: Sebenza thread
Reply #116 on: November 05, 2008, 10:38:37 PM
Dunc
Yeah we have kinda been neglecting our other vice.
The Sebbie looks good AND cuts well.  Does that make it a MT?  :D
Re: Sebenza thread
Reply #117 on: November 05, 2008, 10:40:58 PM
Dunc
I'm happy, that your both happy, but I'm afraid the sebbie leaves me cold mate :-\
Re: Sebenza thread
Reply #118 on: November 05, 2008, 10:41:51 PM
Dunc
Some people just can't recognise quality.  :D
Re: Sebenza thread
Reply #119 on: November 05, 2008, 10:42:38 PM
Dunc
Most definitely although I dont think the others would agree . I think Sebbies should have their own sub forum  >:D
Dunc
