Shop projects
Sparky415 · 590 · 50636
us Offline Yadda
Re: Shop projects
Reply #210 on: October 17, 2017, 05:15:55 AM
Getting frustrated trying to see why this angle grinder won't work
Try using a hammer.  It may not fix it, but it does help with the frustration!
us Offline Wallace72
Re: Shop projects
Reply #211 on: October 18, 2017, 04:53:27 AM
Did a continuity test and up till the two wires that separate to the field windings (cord and switch) are getting power. And the brushes seem okay but it still won't turn on.
us Offline gerleatherberman
Re: Shop projects
Reply #212 on: October 18, 2017, 05:41:50 AM
Check the solder joints on each end of the stator. My old Milwaukee grinder had a tiny separation at one of these points. It had only about 3 hours of use before it pooped out. Resoldered and it works fine now. I did have to press the stator out before I could see the problem. I took the gear housing off, pulled out the rotor, and pushed it out from the back.
Getting it back in was a real treat. ::)
Good luck wallace!
Re: Shop projects
Reply #213 on: October 21, 2017, 09:44:41 PM
A little recycling
I bought these speakers second hand when I was a young apprentice for quite a lot of money, don't need them and can't even give them away (dang kids with their newfangled... )
So I cut them up and threw some paint at them,
Storage drawers for the garage  :tu:
Yeh I know there's a hole in the bottom, it's for ventilation  :whistle:
nz Offline Syncop8r
Re: Shop projects
Reply #214 on: October 21, 2017, 10:08:09 PM
Good idea!
(A town nearby has a new bus shelter, designed by architects with a big hole in the roof.  :facepalm:)
Re: Shop projects
Reply #215 on: October 21, 2017, 10:21:39 PM
Ventilation?   :shrug:
nz Offline Syncop8r
Re: Shop projects
Reply #216 on: October 21, 2017, 10:43:51 PM
"The hole actually represents the Māori name for the Wairau Valley, Kei puta te Wairau, which means "the place with the hole in the sky" or "the place with the hole in the cloud".
https://www.stuff.co.nz/national/97376462/council-defends-hole-in-bus-shelter-logic
Re: Shop projects
Reply #217 on: October 22, 2017, 12:48:01 AM
Ah, it all makes sense now :D
nz Offline Syncop8r
Re: Shop projects
Reply #218 on: October 22, 2017, 01:12:21 AM
Then there was the new $2m architect-designed toilet block in the mountains where the pipes kept freezing...  :whistle:
Re: Shop projects
Reply #219 on: October 23, 2017, 11:02:12 PM
To make sanding drums for knife making etc I've been glueing sandpaper to old hole cutters, works well but it's a pain to remove the old paper
This Guy had a better idea than mine, did a nice job  :salute:
Re: Shop projects
Reply #220 on: October 23, 2017, 11:07:59 PM
10mm bolt, 12mm would be even better  :tu:
Try to get good plywood, it will save you from filling and sanding  ::)
3 hacksaw blades together  ;)
Sorted  :D
nz Offline Syncop8r
Re: Shop projects
Reply #221 on: October 23, 2017, 11:22:12 PM
 :tu:  Is the sandpaper just held in by something jammed tight in the hole?
Re: Shop projects
Reply #222 on: October 23, 2017, 11:35:05 PM
  :pok:  watch the video, at 4.00
I hammered 2x 8mm dowels in to an 8mm hole (might have to enlarge the hole a little)
nz Offline Syncop8r
Re: Shop projects
Reply #223 on: October 23, 2017, 11:42:21 PM
Yeah I saw him hammer something metal in, just surprised that was it.
Re: Shop projects
Reply #224 on: October 24, 2017, 01:26:12 AM
Good job !   That looks like it will work great  :tu:
Re: Shop projects
Reply #225 on: October 24, 2017, 02:14:34 AM
Nice job, :tu:
I did me a little project and made a hankie,,
Re: Shop projects
Reply #226 on: October 24, 2017, 06:35:32 AM
I put two dowels in with a hammer, they lock in very well I'm a little worrIed that I might have to drill them out when I change the sand paper
Nice job, :tu:
That looks very cool JR  :cheers:
Re: Shop projects
Reply #227 on: October 24, 2017, 07:31:19 AM
Nice job, :tu:
Thanks, just another to add to the collection..
mc Offline Gerhard Gerber
Re: Shop projects
Reply #228 on: October 24, 2017, 07:32:13 AM
 :salute: :salute:
I need to build a big and a small one of those......  :tu:
Re: Shop projects
Reply #229 on: October 24, 2017, 01:38:17 PM
I need more sizes, I think the 'locking' hole might be hard to get right on a little one  :think:
Re: Shop projects
Reply #230 on: October 24, 2017, 03:20:14 PM
I've got an eternal struggle, a knifemaker I follow on FB has the motto "Tool up or Die", I see the wisdom of these words, but if I use spare time to "tool up" there would be no time to use these tools...... :facepalm:
I finally made a rack to hold my belts, that only took about a year to get around to doing.........making and hanging took about 1 hour and 30 minutes respectively.  :facepalm:
Better lights bought 2, maybe 3 months ago and still at times I'm smurfing around with a headlight on  :facepalm:
Re: Shop projects
Reply #231 on: October 24, 2017, 06:08:07 PM
Any pics? I got enough belts myself, right now one stays out then the rest make a coil inside one of my drawers, one inside the other then stacked,,
Re: Shop projects
Reply #232 on: October 24, 2017, 07:00:18 PM
I think Gerhard is talking about sander belts   :whistle:
Re: Shop projects
Reply #233 on: October 24, 2017, 07:03:50 PM
Oops, but I have a belt sander too, just no belts..
Re: Shop projects
Reply #234 on: November 05, 2017, 04:28:40 PM
This Guy does some nice work
https://www.youtube.com/watch?v=5VAmWs5vH1o&index=60&list=WL
I have been thinking of making one of these for an Axe wall, mine won't be so clever...
Now Tazzie Rob has made an Axe wall I better get started
Re: Shop projects
Reply #235 on: November 05, 2017, 05:31:50 PM
That’s nice, I might have to do something like that, but nothing will ever come close to a Studley!
Re: Shop projects
Reply #236 on: November 05, 2017, 05:56:04 PM
Some unistrut, Oak scraps, plane a 5ish degree angle on edges
Space things out very carefully
Mmmm  :think: how are we going to fix it together?
Copper rivets  :D
Re: Shop projects
Reply #237 on: November 05, 2017, 05:59:34 PM
Copper rivets  :D
Nice what are you making?
Re: Shop projects
Reply #238 on: November 05, 2017, 06:02:48 PM
This  :D
Sadly the pegs don't all fit the slots (and it's not the pegs that are at fault  ::) )
I'm very happy with this so far, I might have to adjust a few of the pegs
It's now in test mode as I think it's a bit soon to be screwed to the wall above my computer desk  :whistle:
Oh yeah...... and it's not big enough  :facepalm:
Re: Shop projects
Reply #239 on: November 05, 2017, 08:05:23 PM
Ooh, that’s nice, it might be big enough you just have to adjust the ax's, you could double the storage size if you put the others upside down,
__________     __
[_]   _________[_]
Kinda like that
