Shop projects
Sparky415 · 601 · 89134
Re: Shop projects
Reply #30 on: May 01, 2016, 12:07:27 PM
Not yet, I feel a bit guilty only visiting him when I want something done  :-[
Maybe drop it off tomorrow  :shrug: :D
Re: Shop projects
Reply #31 on: May 11, 2016, 08:42:19 PM
Ooh is it welded yet Tony  :tu:
Got this back from my Mate Kev, then threw some hammerite at it  :whistle:
« Last Edit: September 17, 2017, 10:43:08 AM by zoidberg »
nz Offline Syncop8r
Re: Shop projects
Reply #32 on: May 19, 2016, 01:08:17 PM
A fleshlight for knives?  :facepalm:
Re: Shop projects
Reply #33 on: May 19, 2016, 09:21:43 PM
Sadly only an inch an a half wide so it’s a bit on the small side  :whistle:
 ;) :cheers:
Re: Shop projects
Reply #34 on: November 06, 2016, 10:17:32 PM
Did anyone notice my copper an brass pencil in this picture?
Re: Shop projects
Reply #35 on: November 06, 2016, 10:20:00 PM
There's a couple of places in the UK that 'give' you a little pencil when you go shopping there,
All across the UK builders vans have these rolling around in the glove boxes/ash trays
But they are a little small for my hands  ::)
So...
I stuffed one in the end of some copper pipe,
then added a brass nut thingy to stop it rolling,
then added a magnet so I didn't keep loosing it
That worked ok, been using it for months  :tu:
Re: Shop projects
Reply #36 on: November 06, 2016, 10:21:38 PM
Then on youtube Greg and Jimmy made one to hold a sharpie, from steel
 and Giaco's done an aluminium one
Re: Shop projects
Reply #37 on: November 06, 2016, 10:24:24 PM
So I had to make one
Mine are Copper an brass with a magnet  ;)
Now all I have to do is figure out what to do with my space pen inserts  :think:
« Last Edit: November 06, 2016, 10:26:59 PM by Sparky415 »
mc Offline Gerhard Gerber
Re: Shop projects
Reply #38 on: November 07, 2016, 09:24:20 AM
 :tu:  :tu:  :tu:  :tu:
I have to get a knife vice ASAP or my story will end in tears.....
Re: Shop projects
Reply #39 on: November 07, 2016, 09:55:37 PM
They are relatively simple to make if you know someone with a welder  :tu:
Re: Shop projects
Reply #40 on: November 08, 2016, 06:58:46 AM
True enough.......what I'm missing for most of my projects is a good scrapyard to source parts and materials!  :rofl:
For instance, I have a large diameter piece of metal pipe with the one end welded shut that I use like an oven in my forge when I do the heat treat, and that has a hole burnt through the side......
Re: Shop projects
Reply #41 on: November 08, 2016, 09:05:37 PM
I do find a lot of rubbish to play with, if I had to buy it I probably wouldn't try
Re: Shop projects
Reply #42 on: November 09, 2016, 12:53:22 AM
 :like:    8)
Re: Shop projects
Reply #43 on: December 22, 2016, 09:26:29 PM
What to do with your old hoover when all the magic smoke escapes  :think:
Add some leftover PVC waste pipe
Yep we've made a cyclone  :D
Get a little pink friend to sit ontop
That seems to work
« Last Edit: December 22, 2016, 09:33:14 PM by Sparky415 »
Re: Shop projects
Reply #44 on: December 23, 2016, 08:39:07 PM
Neat idea there Tony.  :tu:
Re: Shop projects
Reply #45 on: December 23, 2016, 08:53:42 PM
Thanks Mate,  :salute: I wanted to make one for sometime but needed the right container  :tu:
Hetty might not be powerful enough as she get quite warm  :think:  :think:
Oh, and the CD case cut in to the top is because I wanted to see what was going on inside  :ahhh  :D
« Last Edit: December 23, 2016, 08:57:03 PM by Sparky415 »
Re: Shop projects
Reply #46 on: December 24, 2016, 11:56:25 PM
Hey, if it's good enough for Dyson then I can't criticize. :D
Re: Shop projects
Reply #47 on: December 28, 2016, 12:25:39 AM
I sometimes wonder why I keep all this crap  :shrug:
 :think: :think:
After trying some leather-work for a sheath I decided I needed a proper press,
so …
Square up edge of leftover kitchen worktop
I think I need a new blade in my chop saw  ::)
Round over edges
Fit hinges
Hit metal parts with a big hammer  :D
Adjust metal bits
Jam a piece of 6.8mm drill in the end of the clamp  ;)
More or less sorted  :D
Re: Shop projects
Reply #48 on: December 28, 2016, 01:11:55 AM
Love it    :salute:
us Offline Yadda
Re: Shop projects
Reply #49 on: December 28, 2016, 04:18:53 AM
Re: Shop projects
Reply #50 on: December 28, 2016, 11:44:06 AM
Thanks Guys  :salute:
From the Mora Club thread
Thanks   :salute:
Made a button from a 4mm copper leather rivet and washer (on top of the steel at the back of the picture) with a piece of old leather belt  ;)
That works but its a bit of a tight fit
(The white thing in my hand is a belt covered with baking paper)
To be honest copper is a bit soft for this project and the edges are a little sharp  :whistle:
Would be nice little job for someone to make on a lathe   :tu:
fr Offline Whoey
  • I am geek, hear me code
Re: Shop projects
Reply #51 on: December 29, 2016, 11:56:44 AM
As I follow some woodworking pages on facebook there seems to be a rash of "shop projects" in my suggested feed, which is fine, but lately I've noticed a lot of them are using the same tool fixings they are intending to build (IE tablesaw, drill press, scroll saw, etc) to build the same very diy fixings.  :facepalm:
Given I have no space for a proper workshop it's very tempting to get one of those allinone multifunction setups for minor projects. (like this:)
Re: Shop projects
Reply #52 on: December 29, 2016, 12:55:10 PM
 ;) :cheers:
 :D :D :D :D
se Offline Fortytwo
Re: Shop projects
Reply #53 on: December 29, 2016, 04:10:00 PM
There are a couple of solutions. Renting tools is fairly easy and many people (me included) have sporadic opportunities to use well equipped workshops, in my case my father's or grandfather's but they are 250 and 500 km away respectively. There is also a number of workshop clubs where you pay a membership fee to user their tools.
Or possibly the authors are just lazy, that's probably the more likely case.
Re: Shop projects
Reply #54 on: December 30, 2016, 12:15:38 AM
 ;) :cheers:
 :D :D :D :D
That took you sooooooooo long  :P
Re: Shop projects
Reply #55 on: December 30, 2016, 12:37:41 AM
Cool bunch of projects Sparky :cheers: :cheers: :like:
How did I miss this thread ??? It didn't show up in my unread threads either :think:
Well I have seen it now and am glad to have seen it :D
Re: Shop projects
Reply #56 on: December 30, 2016, 12:55:44 AM
Thanks very much Mate,  :salute:
Everyone is welcome to add to it and show what they are doing in their workshops  :cheers:
Re: Shop projects
Reply #57 on: December 30, 2016, 03:18:27 AM
I usually don't do much this time of the year after work cause the dark doesn't seem for workshopey to me (it is dark when I get home in the evenings) I have lights in my garage but rather the sun be out at least for a while when doing a project :D I will start doing projects this Spring more cause I get in the mood to do stuff like that then :dd: :like:
« Last Edit: December 30, 2016, 03:19:38 AM by Poncho65 »
fr Offline Whoey
Re: Shop projects
Reply #58 on: December 30, 2016, 12:57:20 PM
Probably, it irks me that they are "fixing" a solution where you should not have the means to do it in that manner.
us Offline Yadda
Re: Shop projects
Reply #59 on: December 30, 2016, 02:12:47 PM
What you need is an old Shopsmith. The models from the 50's are almost indestructible and it is still possible to find parts. (At least it is on this side of the Big Pond.)
