Shop projects
Sparky415 · 601 · 91099
Re: Shop projects
Reply #570 on: November 30, 2020, 03:13:36 AM
Niice!! Using the magnets was a clever idea, it must feel great and really comfortable!!
Thanks, yeah I must say that was a pretty good idea, and oh so good to just sit back in the most comfortable chair in the house and do whatever!
00 Offline WWW
Re: Shop projects
Reply #571 on: January 02, 2021, 11:07:18 PM
After watching countless hours of putty knife restorations, I was ready to restore one myself. But after seeing the ridiculous shipping prices on eBay I decided that I would have to buy localy. It was settled, localy it was. But the putty knives I'd found were in no need of TLC. They were NOS (New Old Stock), and were a better buy than older beat up ones. In that moment I realised that I could make one myself!! But as usual it took me ages to gather the willingness to produce one. After watching a rehandling by YouTuber 357magdad, I knew that I could not waste more time. And so this journey began...
Reclaimed wood from a "cake stand" (no idea what they're called), parts were filled with bugs, used my Stanley nº4 to taper and clean up the sides. The tenon was cut with a chisel to fit a 15mm copper connector that was cut in half.
A better look at the tenon. A hole was drilled and a slot was cut with a hacksaw. The slot is then carved into the handle with a modified hacksaw blade.
An old saw blade is cut and shaped to form the blade of the putty knife. Later decided to add the taper you see marked with a sharpie marker.
Decided against the round shoulders and went for straight 90º. The tang was also filed a little more, enlarging the slot was more difficult than making the tang narrower.
Finished product with the copper "ferrule" in place. I reckon that I could use a reduction to get a little bit of a radius on the top of the ferrule.
Backside of the handle. I did not apply any finish as I may change my mind regarding the handle shape.
Sorry for the bad photos and the unnecessarily long windedness!
Re: Shop projects
Reply #572 on: January 02, 2021, 11:26:43 PM
Nice project and well done !
00 Offline WWW
Re: Shop projects
Reply #573 on: January 06, 2021, 06:19:12 PM
Thanks SteveC!! I was really fun and the results really surprised me!!
Re: Shop projects
Reply #574 on: February 20, 2021, 08:27:40 PM
us Offline tattoosteve99
Re: Shop projects
Reply #575 on: June 07, 2021, 04:07:03 AM
This would be a fun project
https://www.youtube.com/watch?v=4sDubB0-REg&ab_channel=SRHacksaw
Pretty cool. Btw hello Steve  :pok: :pok:
Although I would not have made it a flat bottom boat.
Re: Shop projects
Reply #576 on: June 08, 2021, 01:19:23 AM
 :waving:
Re: Shop projects
Reply #577 on: September 20, 2021, 06:47:50 PM
nz Offline Syncop8r
Re: Shop projects
Reply #578 on: September 20, 2021, 09:58:23 PM
Flat-bottom hulls, they make the rockin' boats go 'round...
no Offline Vidar
Re: Shop projects
Reply #579 on: December 15, 2021, 09:35:54 PM
Due to some unfortunate purchasing of a TV walls setup we ended up with on made for buildings with a smaller distance between the joist in the wall. Thus it needs to be fastened to something than spans wide enough to hang it up. I thought that would be a nice little project to test a new toy I got some time ago on sale, and maybe add some pictures here in the process.
So I started with a leftover piece of 3mm steel sheet that happened to be suitable wide but too long. So it had to be cut, and I get to try my new toy.
1. So the new little toy is a, eh, something, that mounts on the angle grinder. It serves three purposes - gather dust via the vacuum coupling, having a straight edge to follow for straight cuts, and a cut depth setting. I try to avoid doing much inside that spreads dust in general, and metal dust in particular, so this is a nice little addition. It worked very well - very little escaped from that test cut.
2. After that I got to try another new addition, a small 125mm angle grinder, to just clean up all the edges and round the corners. Note the narrow grip compared to the other angle grinder - this one is very easy to grip.
3. The old steel sheet had a lot of character and rusty patina. It is to be spray painted later so at least the rust have to go. Some steel brushing does that just fine.
4. This needs to hang on the wall so some holes will be needed. Some marking tools are good to locate those.
"Simple is hard"
"Hard is hard too"
no Offline Vidar
Re: Shop projects
Reply #580 on: December 15, 2021, 09:41:21 PM
Next is putting the actual TV hanger on and finding a sensible position for it.
5. The TV hanger.
6. Using a distance tool to place it 1cm from the top edge, and in the middle lengthwise.
7. When in the right spot make some marks for where the holes to secure this position should be.
8. Making some quick holes with a hydraulic punching tool.
"Simple is hard"
"Hard is hard too"
no Offline Vidar
Re: Shop projects
Reply #581 on: December 15, 2021, 09:45:06 PM
9. Holes made - going on the prepare for welding.
10. Removing paint and patina in the areas that will later be welded.
11. Cleaning up the same areas with acetone.
(An important note on acetone by the way is that is self-ignites quite easily - thus the paper or rag used need to be dispersed of safely in a fireproof bin or soaked in water.)
"Simple is hard"
"Hard is hard too"
no Offline Vidar
Re: Shop projects
Reply #582 on: December 15, 2021, 09:49:28 PM
I was going to do the actual welding too, but that hit a stumbling block. It is -12 degree Celsius in the workshop, and the welding machine refuse to cooperate at that temperature. So I've turned on some heat and hopefully the machine will warm up enough to finish this later.
"Simple is hard"
"Hard is hard too"
Re: Shop projects
Reply #583 on: December 15, 2021, 09:58:07 PM
 :like: :tu:
no Offline Vidar
Re: Shop projects
Reply #584 on: December 16, 2021, 12:51:12 AM
After a few hours the workshop was warm enough for the welding machine to operate properly. So:
12. Preparing for welding. The screws and clamps hold the TV holder in the right position and contribute to minimize welding distortions.
13. Welding pretty much done. The edges of the TV holder was quite rounded so it took more heat than anticipated to get in those nooks. So some paint melted off here and there. No worries as long as it kept away from the actual weld areas.
14. Finished with welding and removed clamps and screws. Later on the welds will be cleaned up and the bottom area spray painted matte black similar to the rest.
15. Just a curiosity for those who haven't seen one: A welding stool. It can be tipped in three positions giving different sitting heights. Simple and great!
Hope someone found it remotely interesting :)
"Simple is hard"
"Hard is hard too"
nz Offline Syncop8r
Re: Shop projects
Reply #585 on: December 16, 2021, 03:54:42 AM
Weld done!  :tu:
no Offline Vidar
Re: Shop projects
Reply #586 on: December 16, 2021, 08:11:01 AM
By the power invested in me by heat, electrons, and the mighty Fronius, I declare the parts joined in lowly welding. (Until something do them part).
"Simple is hard"
"Hard is hard too"
se Offline RF52
Re: Shop projects
Reply #587 on: December 16, 2021, 08:28:43 AM
Good job :tu: And the welding chair is a good idea :like:
Re: Shop projects
Reply #588 on: December 16, 2021, 03:08:24 PM
I so wish I could weld, I mean I can, I’ve done my share on cars, I like stick, but I just can’t now because of my seizures, I can’t be around the flashing lights! That one project I did from parts which was a recumbent trike from like 4 bikes all I used was nut and bolt, grinder and drill, that thing would have been soooo much better welded! Here’s a video the Mrs took when I was testing it out,,
https://youtu.be/eL5SUIF9t2o
no Offline Vidar
Re: Shop projects
Reply #589 on: December 16, 2021, 04:52:29 PM
That cycle looks good. I can imagine how welding would make it easier though.
I have machines for a few different welding processes for metal and few of them flashes much as such. Dirty base materials/ rust/ paint and whatnot will misbehave but they shouldn't be in a good weld in the first place.
Stick welding - random flashes and sparks.
MIG welding - less random flashes and sparks, but still there.
TIG weldiing - no random flashes or sparks, a single continuous light with turn on and off and intensity under your control.
Gas welding - similar to TIG welding.
Resistance welding - literally done in a single flash in a fraction of a second. I usually just close my eyes and fire. (If the weld itself is covered you can't even see the flash).
(There are many others too, but I don't have those).
Then there is brazing as opposed to welding - the filler additive melts, but the base metals don't. The process has some advantages and disadvantages compared to welding. As a mad plumbarian you likely know it very well already. (I think some bikes are built like that rather than with welding?) Two options I find interesting is the option to braze using induction coils or high temperature ovens - the temperature makes the additive melt but not so high that the base materials get soft. (The base material can still have all kinds of reactions to being heated and cooled, but that might be for better and worse).
I'd like to try brazing with an oven or inductive coils, but so far I haven't had an excuse to spend time exploring - I imagine a sturdy setups and repeated failures will take more time and money than than justifiable for what I typically do.
« Last Edit: December 16, 2021, 05:02:04 PM by Vidar »
"Simple is hard"
"Hard is hard too"
us Offline ThundahBeagle
Re: Shop projects
Reply #590 on: October 07, 2024, 06:09:37 PM
Never really stopped in here before.  Shame.  Some good work here.
This is not really work IN the shop so much as it is work ON the shop.  The house...the work bench is in the basement:
Re: Shop projects
Reply #591 on: October 07, 2024, 06:13:46 PM
^^^ Second and third picture give an idea the condition of the logs when I got here.  Dry, peeling, exposing some wood.  Second pic, bottom rows give a good example.  Second pic top rows after HAND sanding and restaining with Sikkens (PPG) ProLux.
Top and bottom picks are front of house while work in progress.  Too pic is the corner closest to driveway.  Bottom pic wide view of front
Re: Shop projects
Reply #592 on: October 07, 2024, 06:16:27 PM
I finally decided that hand sanding was out of the question if I wanted to get this done before I die someday.  Took my Milwaukee grinder with a Diablo wheel and tried to touch the logs very gently.
Finished product front wall of the house:
nz Offline Syncop8r
Re: Shop projects
Reply #593 on: October 13, 2024, 11:59:53 AM
Looks good TB!  :tu:
Re: Shop projects
Reply #594 on: October 14, 2024, 05:20:13 AM
Proluxe is good stuff, nice job   :tu:
no Offline Vidar
Re: Shop projects
Reply #595 on: December 10, 2024, 09:31:52 PM
I've had this long running project with a frankenstein camera setup for a steady handheld use with a long heavy lens. I'm finally getting there, and apart from some rewiring only the handle remains. I don't want to add more weight than necessary so I got a carbon fiber tube, and now the little shop project is to cut that. I suspect those working carbon fiber has some special saw blades, but I decided to give it a go with a pipe cutter for stainless steel pipes.
1. Initial plan - carbon fiber tube, aluminium end reinforcements, pipe cutter and deburring tool.
2. The pipe cutter had been used for stainless steel pipes so the edges were properly rounded. For a better chance of a decent cut I decided to change the blade with a new one. That turned out to not be so easy as the center pin needed to be pressed out. I considered a hammer and pin, a gear puller, and a rack and pinion press.
3. Rack and pinion press seemed the most controlled so that was it.
4. Starting the cut.
« Last Edit: December 10, 2024, 09:39:56 PM by Vidar »
"Simple is hard"
"Hard is hard too"
no Offline Vidar
Re: Shop projects
Reply #596 on: December 10, 2024, 09:32:34 PM
5. Nasty edges to deburr. Likely also wrong deburring blade for this.
6. Gluing the aluminium end pieces in place.
7. Mounted handle. A bit of glue spill, but that should wear off at some point.
8. Works well - balanced in use, when put down, and during carrying by the handle. Yay!
"Simple is hard"
"Hard is hard too"
Re: Shop projects
Reply #597 on: December 11, 2024, 02:31:04 AM
Nice! The kid wants to get into photography,,
no Offline Vidar
Re: Shop projects
Reply #598 on: December 11, 2024, 04:37:32 AM
The aim is get some pictures of the wildlife around here. Elk, reindeer, deer, stout, eagles, ptarmigan, fox, hare, swan, various ducks and smaller birds, marten, least weasel, and two big ass otters which will hopefully have some funny offsprings. Lemmings are surprisingly good models too when they are not upset by something. And if stars align maybe even the odd lynx or wolverine.
Maybe even tourists  :D - I once saw a red cap sticking up of some high vegetation, and by closer inspection it turned out to be an entire japanese family with two kids in there doing selfies!
"Simple is hard"
"Hard is hard too"
Re: Shop projects
Reply #599 on: December 11, 2024, 03:09:25 PM
Idk what he wants to do, just that he wants to get a few expensive items to start his adventure, our one friend does little, yet she does “old things” like graves or memorials,,
