Good job, it is nice to have all the options!
If you ever work on electronic equipment you will know that the shafts of the screwdriver bits are too short to work on many screws and terminals. The tool bit extender doesn't help as the head is too big. I made a couple of my own by grinding down hex bits and they work great. They fit easily in the front pouch. If you want to try to make your own all you need is a bench grinder and I suggest you buy a couple of each size to allow for botching the first attempt.
I must be missing something. I am already using long shank bits and just grinding the bottom part of the hex to fit the built in tool holder on the charge.
Any new, ingenious ideas??Sent from my Nexus 6 using Tapatalk
Quote from: zrxoa1 on November 27, 2016, 10:47:15 AMAny new, ingenious ideas??Sent from my Nexus 6 using TapatalkMostly tracking down regular bits and grinding them flat
