Monrogue's Signal
us Offline Monrogue
  • Wooooo!
Monrogue's Signal
on: December 29, 2015, 04:31:57 AM
Hey all,
It's been no secret that I've really been enjoying my Signal.  Some of you have likely noticed I managed to dye the yellow bits red (sort of) using liquid rit dye.  Well, while I liked them, they weren't the shade I was looking for.  I ended up ordering replacement parts as I couldn't lighten the darker shade.  This has been an experiment for me as I had no idea what I was doing in terms of getting the normal brighter red I wanted.  I tried three different shades of red (first-cherry, second-scarlet, third-flame), and the first set of parts went through three treatments in an attempt to get the shade I wanted.  Didn't work though, although I do like the shade they ended up being.  However, the dye did a number on the ferro rod (which I discovered after the fact that I could remove after all-didn't think I could originally, but it does pop out with a little prying).  You'll see in the pics the effect the dye had on the rod, which is another reason I wanted a replacement.  So I started fresh with the replacement set, using the flame dye.  It turned out pretty close to what I wanted, so I went ahead and did a second treatment with a slight bit of the flame, and mostly scarlet.  I didn't leave them in quite as long as I didn't want to end up with a darker shade as happened with the first set.  Here are the results, with the old set for reference:
K-Tibbs
us Offline Monrogue
  • Wooooo!
Re: Monrogue's Signal
Reply #1 on: December 29, 2015, 04:40:12 AM
I also made another significant change-I swapped out the wood saw for the metal file from a Charge.  Yes, I know it may seem a bit redundant given the little diamond file already present.  However, I have maybe used a wood saw on a MT or SAK maybe once or twice, and while I like having one just in case, I like having the sweet LM dual file/metal saw better.  Yes, any SAK I carry also has the Vic metal file, but it is rather different to the LM type, and I don't mind having both.  It is still more likely to be used than the wood saw ever is, and for that matter, either metal file/saw could likely function as a wood saw in a pinch, at least for anything minor that a MT would be sawing anyway in most cases, especially in my daily life. Here are some pics:
K-Tibbs
us Offline rdub934
Reply #2 on: December 29, 2015, 05:23:51 AM
I really like both changes. The red looks great. Also, I agree with you on the file vs saw issue. I have only used a saw on my MT once, and that was mostly just to test it out.
us Offline Monrogue
  • Wooooo!
Reply #3 on: December 29, 2015, 05:26:46 AM
Thanks rdub :)
K-Tibbs
Reply #4 on: December 29, 2015, 05:50:20 AM
Nice job ! Great to see you make it your own   :tu:
us Offline Monrogue
  • Wooooo!
Reply #5 on: December 29, 2015, 05:56:57 AM
Thanks Steve!  Perhaps I should call it the MonSignal :think:  :)
K-Tibbs
Reply #6 on: December 29, 2015, 06:07:16 AM
I also like both changes you made.  Good job making it your own.
us Offline Monrogue
  • Wooooo!
Reply #7 on: December 29, 2015, 06:14:06 AM
Thanks man
K-Tibbs
Reply #8 on: December 29, 2015, 06:17:45 AM
Nice job! :tu:
us Offline bdAmmo
Reply #9 on: December 29, 2015, 06:45:08 AM
Those new red pieces sure do stand out better, I like it :tu:
I can understand why you opted to swap the saw for the file, the removable file on the Signal really has its limits.  It will probably be fine to sharpen fish hooks, not likely a whole lot else I would use mine for though.
Did the dye make the ferro rod unserviceable or just affect the looks?
no Offline Grathr
Reply #10 on: December 29, 2015, 08:29:41 AM
Nice job Monrogue! :tu:
au Offline pietervn
Reply #11 on: December 29, 2015, 08:35:06 AM
G'Day,
That Signal looks cool. I do like the red over the yellow. Could you please post a pic with the file closed?
Did the file just drop in? I may have to give the Signal a closer look now, pity they still pretty pricey.
Cheers
Pete
« Last Edit: December 29, 2015, 08:37:18 AM by pietervn »
Reply #12 on: December 29, 2015, 08:43:02 AM
Always nice to see people putting effort in to make the tools better suited for their needs  :tu:
Reply #13 on: December 29, 2015, 08:44:15 AM
+1   :tu:   :tu:
wales Offline magentus
  • mmmmm SAKrelicious
Reply #14 on: December 29, 2015, 01:01:56 PM
Nice job Mo - might I suggest the 'Monsignour'? Or you could just face reality and save time by calling it Harleys.
ch Offline Etherealicer
Reply #15 on: December 29, 2015, 02:28:48 PM
03 - Etherealicer
Wait, that is not a GAW :cry: :cry: :cry:
Great job...
How about calling it SignalRouge?
us Offline Monrogue
  • Wooooo!
Reply #16 on: December 29, 2015, 03:40:15 PM
Nice job! :tu:
Thanks buddy!
K-Tibbs
us Offline Monrogue
  • Wooooo!
Reply #17 on: December 29, 2015, 03:44:19 PM
Thanks man!  Yeah, the sharpener wouldn't be handy for much of anything I'd use the full size one for.  The ferro rod does still work, but just looks crappy, especially when side by side with the new one.
K-Tibbs
us Offline Monrogue
  • Wooooo!
Reply #18 on: December 29, 2015, 03:44:51 PM
Thanks grathr
K-Tibbs
us Offline Monrogue
  • Wooooo!
Reply #19 on: December 29, 2015, 03:45:58 PM
G'Day,
Cheers
Pete
Thanks!  I will try to remember to post more pics tonight.  I can't at work.
K-Tibbs
us Offline Monrogue
  • Wooooo!
Reply #20 on: December 29, 2015, 03:49:16 PM
G'Day,
Cheers
Pete
Oh, and yes, the file fit right in, albeit a little snug compared to the saw.  It does rub against the liner lock and the nub down towards the tip.  Doesn't bother anything though.  The nub must have been to help keep the saw in place I guess :think:  I never noticed it before now.
K-Tibbs
us Offline Monrogue
  • Wooooo!
Reply #21 on: December 29, 2015, 03:49:33 PM
Thanks Al
K-Tibbs
us Offline Monrogue
  • Wooooo!
Reply #22 on: December 29, 2015, 03:50:03 PM
+1   :tu:   :tu:
Thanks Zman
K-Tibbs
us Offline Monrogue
  • Wooooo!
Reply #23 on: December 29, 2015, 03:52:46 PM
Harley will not be getting his mits on my Signal
K-Tibbs
us Offline Monrogue
  • Wooooo!
Reply #24 on: December 29, 2015, 03:54:18 PM
03 - Etherealicer
Great job...
Sorry Big E....no GAW  I am long overdue for one though, but not my Signal
K-Tibbs
us Offline NKlamerus
  • Captain's Apprentice
Reply #25 on: December 29, 2015, 07:28:08 PM
Looking real good!
us Offline Monrogue
  • Wooooo!
Reply #26 on: December 29, 2015, 07:55:41 PM
Looking real good!
Thanks man!
K-Tibbs
se Offline Fortytwo
Reply #27 on: December 29, 2015, 08:42:38 PM
Nice, I want to like the Signal and it's nice to see it adapted to work better. I propose the name "The Rogue Signal", sounds like the title of some spy-novel.
Reply #28 on: December 29, 2015, 08:52:46 PM
03 - Etherealicer
Great job...
 :rofl: :rofl: :rofl:
ca Offline derekmac
  • Little to the right...
Reply #29 on: December 30, 2015, 12:21:13 AM
Awesome buddy!!  Really glad it turned out better the second time! :tu:
