Thank you, Kirk.I have owned, maimed and disassembled a few of the most manufacturers GAKs. I cannot talk about the steel quality as I have zero expertise in that field.Butr I can tell you that the finish on the ICAR gAKs is rougher than on others, the edges of the springs are quite sharp, the springs rather unfinishedon the sides and the blades are not polished (they do much like the old unpolished tools on early Alox Soldiers with the grinding marks visible). The snap and operation is not Vic like, but perfectly ok.I cannot say for sure if it is a problem with ICAR GAKs in general, but I have come across 2 examples with broken springs. the knives werte pretty beat up so it might just be from misuse.I would rate the GAKs as following, YMMV:VictorinoxAitor and AdlerB&H (less nice finish, same quality as above IHO)CCM and ICARImay be missing some manufacturers here, but my 9 day old daughter is sleeping on my arm and I have only one arm to type and a sleep deprived brain to work with...Stay away from:Mil Tec, Fox, MFHthey are no manufacturers but only rebrand cheaply made copies with their insignia. Every once in a while they have a batch from a decent manufacturer but unless you cannot check the actual knife you purchase firsthand, don´t buy those, buy a used real one in good nick instead.
