Newbie modding SAKs
m47mu74nt · 117 · 13845
Re: Newbie modding SAKs
Reply #30 on: January 25, 2016, 06:41:00 AM
Very nice looking work M  :tu:
ca Offline Syph007
  • SAK Surgeon
Reply #31 on: January 25, 2016, 03:51:28 PM
Victorinox uses an orbital rivet machine in that video.
https://en.wikipedia.org/wiki/Riveting_machines
« Last Edit: January 25, 2016, 04:15:09 PM by Syph007 »
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
fi Offline temo
Reply #32 on: January 25, 2016, 04:12:49 PM
Tx. Yes called pushies or something. Should work with more simple tool then press as well (hammer and hit tool). Though should find some first.
Reply #33 on: January 26, 2016, 09:00:40 AM
I don’t know about you Guys but I save interesting pictures I find on the net
Not sure where I found it but this one might be useful to you M?
* ti_color_large.jpg (Filesize: 34.77 KB)
fr Offline m47mu74nt
Reply #34 on: January 26, 2016, 10:26:10 AM
In fact this chart works with a whole piece of Ti dipped in the electrolytic solution (H2SO4, water).
For very small parts of using a cotton/brush, the chart is slightly different (this is the exact same spectrum) but the voltages aren't the same:
I could get a light 'urine' yellow at 57V (+lemon juice) with a small cotton and multiple passes even if the chart says you should get that at 70V+
It is a good base of work, but it won't give you predictable results unless your are in the same exact conditions of the chart
i've tried to give an explanation here : http://forum.multitool.org/index.php/topic,64287.0.html
« Last Edit: January 26, 2016, 10:27:21 AM by m47mu74nt »
Reply #35 on: February 01, 2016, 02:19:49 AM
Excellent thread mate.   :ahhh   Nice to have you here.   :tu:   :tu:   And congrats on the badges.   :cheers:
Reply #36 on: February 01, 2016, 06:54:55 AM
Thank you, there might be some time before next project coming though  :whistle:
Wouah, 3 badges at once  :D thanks!   :ahhh  :cheers:
Reply #37 on: February 01, 2016, 07:02:01 AM
Can't stop once you pop.   :P
Reply #38 on: February 01, 2016, 08:35:05 AM
Reply #39 on: March 15, 2016, 10:01:28 PM
I suddenly thought the donor scales deserved a picture too, so ...
91mm : Red Cellidor Compact
84mm : Nylon Sentry
58mm : Green Cellidor Classic SD
* Scales.jpg (Filesize: 184.86 KB)
Reply #40 on: July 25, 2016, 08:38:30 PM
Next project : Ti-Rambler
(i'm using scales i started to make during previous project)
disassembling :
the parts:
drilled a [bigger] bevel:
pre-pinning the rivets:
* Ti_Rambler-disassembly.JPG (Filesize: 160.91 KB)
* Ti_Rambler-splitted.JPG (Filesize: 175.31 KB)
* Ti_Rambler-bevel.JPG (Filesize: 156.85 KB)
* Ti_Rambler-prepinning.JPG (Filesize: 143.95 KB)
« Last Edit: July 25, 2016, 08:42:06 PM by m47mu74nt »
Reply #41 on: July 25, 2016, 08:46:47 PM
Looking good :tu:
:popcorn:
Reply #42 on: July 25, 2016, 10:55:36 PM
Looking good :tu:
:popcorn:
sadly next steps might be in a few weeks, i won't be able to finish it before  :oops:
Reply #43 on: July 26, 2016, 04:46:43 PM
Looking good :tu:
:popcorn:
I'll be waiting :cheers:
id Offline jaya_man
Reply #44 on: July 26, 2016, 05:07:10 PM
Awesome work...
I've always wanted to do through peening work on 58mm series... How much excess do we need to leave out? Have only done 91mm peening with the bushings in place and always leave 1mm for peening..
Reply #45 on: July 26, 2016, 10:52:08 PM
I left a little less than 1mm iirc on previous build,
But, with the bevel I might need a little more to get the V shape in the scale and still a rounded tip  :think:
I'll tell you after this one  :D
BTW, 1.6mm diameter rod is a little thinner than the holes (like 1.65mm?) Which gives some smoothness (some might say a beginning of wobble)
Reply #46 on: August 03, 2016, 04:04:34 PM
DIY of the day: Ti pocket clip
Hammered and flame-anodized titanium
Thank to Syph007 for bending tip
* Ti-Clip0.jpg (Filesize: 142.62 KB)
* Ti-Clip1.jpg (Filesize: 142.42 KB)
« Last Edit: August 03, 2016, 04:06:11 PM by m47mu74nt »
id Offline jaya_man
Reply #47 on: August 03, 2016, 04:05:32 PM
Looks awesome
Reply #48 on: August 03, 2016, 04:07:52 PM
Thanks!
wales Offline magentus
  • mmmmm SAKrelicious
Reply #49 on: August 03, 2016, 04:11:09 PM
Nice clip! I like the finish on it.  :salute:
Reply #50 on: August 04, 2016, 01:06:41 AM
Very  8)
Reply #51 on: August 05, 2016, 01:52:32 PM
Here is the Ti Rambler assembly:
(yeah i skipped the scale making part and anodizing/oxidizing -flamed his time-)
Major issues: There are some scratches on the scales i couldn't erase, and I reversed the file, it looks towards the Ti scale  :facepalm: (everything was already pinned when I saw it  :twak: )
I also tried to made a pocket clip, -two as the first broke during cold bending-unbending-bending- ...
Everything is oxidized to light blue and some shades around (deep violet - yellow)
* Ti-RamblerWIP1.JPG (Filesize: 145.45 KB)
* Ti-RamblerWIP2.JPG (Filesize: 132.8 KB)
* Ti-RamblerWIP3.JPG (Filesize: 167.91 KB)
* Ti-RamblerWIP4.JPG (Filesize: 175.28 KB)
« Last Edit: August 05, 2016, 01:56:21 PM by m47mu74nt »
tr Offline ddogu
Reply #52 on: August 05, 2016, 02:05:57 PM
Flame anodizing is fun, but what about playing with electricity and lemon juice?
Here is a test :
- 40V, using an old Epson printer PSU, (12V from computer PSU gives a nice bronze/gold)
- Some cotton dipped in Lemon juice as electrolysis solution
- The + is connected to the scale, the - clamped to the cotton
- The scale is wiped with the cotton a few time until the color is the one desired (this technique at 40V gives a random pattern between gold, deep-violet and light blue)
Awesome tip&instructions!  :tu:
Reply #53 on: August 05, 2016, 05:45:37 PM
Here is a test :
Very nice work :cheers:
:popcorn:
Reply #54 on: August 05, 2016, 05:47:36 PM
Major Issues!
 :salute:
Reply #55 on: August 05, 2016, 08:51:12 PM
Yes Major  :salute:, as it is a gift for a friend  :facepalm:
btw I also flamed my first clip again to get that nice blue as on the Rambler, it looks much nicer than bronze/violet now
* BlueClip.JPG (Filesize: 175.54 KB)
Reply #56 on: August 13, 2016, 05:58:58 PM
I use it daily for now (and it's not going to change soon)
So here is a picture under the Alps sunlight:
* TiClip_Hunstman_in_Italian-Alps.JPG (Filesize: 114.82 KB)
Reply #57 on: August 13, 2016, 08:56:25 PM
Nice :cheers:
Reply #58 on: August 16, 2016, 05:22:25 PM
Why do people (and me too) like Titanium so much?
  • It screams to deaf when you cut it with hacksaw
  • It wears your hacksaw as much as it gets cut
  • It blinds you when you burn it with its bright flame
  • It breaks your drill bits
  • It is a pain to grind
  • It gets scratched when you look at it
  • It breaks when you want to bend it
  • It bends when you want to break it
But
  • It has so lovely colors and is tougher and lighter than its steel equivalent
I made three [four] more clips:
(old one is the second from the left)
One broke (again)
* Ti-Clips.JPG (Filesize: 100.97 KB)
* BrokenTi.JPG (Filesize: 127.58 KB)
« Last Edit: August 16, 2016, 05:24:13 PM by m47mu74nt »
Reply #59 on: August 16, 2016, 08:11:35 PM
But
One broke (again)
Easy...
It begins with "Tit"...
 :D :D
