Newbie modding SAKs
m47mu74nt · 117 · 13849
fr Offline m47mu74nt
Re: Newbie modding SAKs
Reply #90 on: August 25, 2018, 07:11:16 PM
Back to assembly
With the file in the middle this time ...
Cutting rivets to size
Peenig and filing
* 9_Assembling-1080.jpg (Filesize: 495.65 KB)
* 10_Assembling2-1080.jpg (Filesize: 413.96 KB)
* 11_CuttingRivetsToSize-1080.jpg (Filesize: 471.59 KB)
* 12_PeeningAndFiling-1080.jpg (Filesize: 441.88 KB)
« Last Edit: August 25, 2018, 07:12:52 PM by m47mu74nt »
Reply #91 on: August 25, 2018, 07:14:31 PM
Pfiuuuuu, that was a tough build!
Here is the Wenger TrailGuide Evo S
 :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
(the spring modification was far from easy)
* 13_DOOOOOOONE-1080.jpg (Filesize: 467.5 KB)
« Last Edit: August 25, 2018, 07:16:43 PM by m47mu74nt »
Reply #92 on: August 26, 2018, 09:34:08 AM
Reply #93 on: August 27, 2018, 06:16:56 PM
 :salute: :salute: :salute:
us Offline Myron
Reply #94 on: September 05, 2018, 09:35:09 PM
Very nicely done!  You've really mastered the art of pin peening.
Myron
Reply #95 on: September 06, 2018, 09:33:51 PM
Myron
No I didn't, or at least not enough to dare trying to peen visible rivets like on alox  :facepalm:
But thank you  :like:
Reply #96 on: September 30, 2018, 08:15:56 PM
Not a SAK mod, but I'm quite happy with the result : a 5mm thick Titanium Heart shaped pendant
- Raw cut and shaping done with angle grinder (OMG the burning sparks ....) and a coarse file
- Fine shaping with smaller medium files and diamonds files
- Hand grinding with abrasive papers ... a long long time :
180, 240, 320, 400, 600, 800, 1000, 1200, 1500, 2000, 2500, and finally 3000
* RawCut.jpg (Filesize: 214.1 KB)
* ShapedNGround.jpg (Filesize: 377.89 KB)
* TitaniumHeart.jpg (Filesize: 425.67 KB)
« Last Edit: September 30, 2018, 08:27:17 PM by m47mu74nt »
Reply #97 on: September 30, 2018, 08:20:36 PM
Mirror polish and fixing the sterling silver ring (made out of stuff i had lying around)
* SterlingSilverRing-1080.jpg (Filesize: 487.51 KB)
* MirrorPolish.jpg (Filesize: 496.04 KB)
* Finished.jpg (Filesize: 453.7 KB)
Reply #98 on: September 30, 2018, 11:10:18 PM
:dd: it’s beautiful.
Reply #99 on: September 30, 2018, 11:47:30 PM
Skills! Nice one m47m... Nice one!  :tu:
wales Online magentus
  • mmmmm SAKrelicious
Reply #100 on: October 01, 2018, 10:06:45 AM
Gorgeous Mut  :cheers: Which lucky member is going to receive that?
Reply #101 on: October 01, 2018, 01:18:20 PM
:hatsoff:
Is my nickname hard to remember? :whistle:
Thanks, she is not a member -yet- but I teach her the love of SAKs  :angel:
Reply #102 on: June 01, 2019, 12:23:55 PM
I couldn't wait for a Wenger file, so I resigned to make a Titanium Wenger Voyageur instead!
1st step : cutting roughly the needed Titanium using the templates (I used old scales + the aluminium liners to get both good external dimensions and well placed holes
* 01_cuttngRawMaterial-1080.jpg (Filesize: 339.49 KB)
* 02_drillingHoles-1080.jpg (Filesize: 333.63 KB)
* 04_template-1080.jpg (Filesize: 325.38 KB)
* 05_cuttingTwins-1080.jpg (Filesize: 356.13 KB)
Reply #103 on: June 01, 2019, 12:37:00 PM
2d and 3rd step: rough shaping, and then getting more precise on the back,... and the belly
scales are done ! (here they are from the back, the front side has little bevels on the holes, and they need some sanding)
* 07_shapingTheBack-1080.jpg (Filesize: 357.19 KB)
* 08_basicShapeBelly-1080.jpg (Filesize: 340.14 KB)
* 09_basicShapeBack-1080.jpg (Filesize: 325.14 KB)
* 10_shapingDone-1080.jpg (Filesize: 307.8 KB)
Reply #104 on: June 01, 2019, 12:43:15 PM
Very pretty!  :tu:
I wish I could do that.
Reply #105 on: June 01, 2019, 12:52:59 PM
Very pretty!  :tu:
thank you :)
you don't need that much tools,
I only used
- hand drill mounted on a stand,
- hacksaw,
- a set of metal files ( and an angle grinder / dremel tool for faster shaping, but beware they eat fast and might make more harm than good ...)
- clamps / vice
- sand paper(s)
- material : titanium sheet (1mm thick), brass sheet (I used 0.3mm thick, but that might be too thin), 2.5mm brass rod
next :
1- dry run time !
2- pre-peening ...
3- making brass liners ... because titanium stick too much on the tools and prevent smooth action
4- making the tail piece ! that was tough to make (ok, not as much as filing titanium by hand.)
* 11_blankTry-1080.jpg (Filesize: 354.72 KB)
* 12_prePeening-1080.jpg (Filesize: 335.16 KB)
* 13_brassLiners-1080.jpg (Filesize: 352.64 KB)
* 14_tailPieceMaking-768.jpg (Filesize: 370.24 KB)
Reply #106 on: June 01, 2019, 12:53:58 PM
Very pretty!  :tu:
:iagree: Good stuff! I love flush finishing.  :like:
Reply #107 on: June 01, 2019, 12:56:43 PM
that's the exact reason I used a Wenger frame  :angel:
Reply #108 on: June 01, 2019, 12:58:11 PM
here is the tail piece done and the build in progress
* 15_tailPiece-1080.jpg (Filesize: 339.94 KB)
* 16_assemblyAgain-1080.jpg (Filesize: 346.47 KB)
Reply #109 on: June 01, 2019, 01:08:31 PM
and .. Finished!
a picture of the back, and some of its friends !
* 000_comparisonCadetOC-1080.jpg (Filesize: 347.66 KB)
* 002_back.jpg (Filesize: 423.13 KB)
* 099_TitaniumSaks-1080.jpg (Filesize: 317.9 KB)
Reply #110 on: June 01, 2019, 01:13:18 PM
Owww!!! smurfing lovely!  :like: You must be pleased with that? How's the snap?
Reply #111 on: June 01, 2019, 01:21:48 PM
snap is super good (as good as its donors, the blades comes from a Basic 62, that has a smooth but kinda 'weak' spring)
it was sticky on the first assembly (without brass liners, the titanium scales where in direct contact with tools), but with brass liners it is really top notch !
so I really am happy with that build :)
fi Offline temo
Reply #112 on: June 01, 2019, 01:28:15 PM
Very nice mods
Finding tool is a journey, not destination to settle
Reply #113 on: June 02, 2019, 05:54:40 PM
* Wenger_Titanium_Voyageur.jpg (Filesize: 345.01 KB)
us Offline PitCarver
  • Average Old Guy.
Reply #114 on: June 02, 2019, 06:46:41 PM
Very pretty!  :tu:
Me too.
Reply #115 on: June 03, 2019, 11:16:39 AM
Lush!   :like:  :cheers:
Reply #116 on: June 12, 2019, 08:02:10 PM
Sleek.... excellent work m47mu74nt  :like:
