Can you help me figure out what kind of SAK I have?
Offline Alie Schnabel
on: March 01, 2016, 04:13:13 AM
I was given this knife by my late great grandfather, but I have no idea of its make.
The inscription on the blade says Wenger Delemont Switzerland Stainless
There are photos in the attachments, but here is a list of the features:
*Large blade
*Nail File/Nail Cleaner
*patented spring-less, self-sharpening
*reamer, awl (back side)
*Can opener
*patented locking screwdriver, cap lifter, wire stripper
*Phillips head screwdriver (back side)
*double cut wood saw
* metal file (no saw teeth)
*fish scaler
the scales once held a tooth pick and tweezers, but are long since lost.
Thanks in advance for the help
us Offline yud
  • Still has a SOGgy feeling
Re: Can you help me figure out what kind of SAK I have?
Reply #1 on: March 01, 2016, 06:18:16 AM
Well it is a Wenger that is the maker, they have since been taken over by Victorinox.  But at any rate that is all I can really say I can not find a model name to attach to it.
But if you want an opinion on what to do with it, I would carry it.  Personally I prefer Vic but Wengers are good solid knives.and it seems in Good condition.
Or keep it some where safe and hand it down to you great grand kids
us Offline ColoSwiss
Reply #2 on: March 01, 2016, 06:53:28 AM
It is a Wenger, probably model number 1.22.03.
Its name may be Classic 22, but that's iffy.  SmartKnives lists it as a Monarch Original, but that is made-up.
A good solid knife.
https://www.smartknives.com/Wenger-Pocket-Knives/Monarch-Original.htm
Reply #3 on: March 01, 2016, 01:16:31 PM
Whatever it is, is a great knife!
You might get some replacement toothpick and tweezers, maybe even some new scales from Victorinox.
Welcome!
  • Bored
Reply #4 on: March 01, 2016, 01:20:00 PM
Welcome
Nice knife, with history
Reply #5 on: March 01, 2016, 03:12:33 PM
Thanks guys. I appreciate  the help. I do carry it with me all the time. I just noticed  that the toothpick broke off inside the scale, so that might be problematic  if I want to replace  it.
wales Offline magentus
  • mmmmm SAKrelicious
Reply #6 on: March 01, 2016, 03:27:39 PM
You can quite easily remove the scales and replace them with a bit of care Alie, have a look at the modding sticky here;http://forum.multitool.org/index.php/topic,43303.0.html
us Offline yud
Reply #7 on: March 01, 2016, 03:32:30 PM
They are relatively easy to pop off, just take something thin (like a butter knife) work it under the scales and and they will come off allowing you to clean it out and get rid of what is left of the toothpick. To put it back on put some cloth on the scales to protect them then apply even pressure and they should snap into place, ideally you should a vise.
Reply #8 on: March 02, 2016, 12:39:04 AM
So if I took the scales off, would I then have access to the pins holding the whole knife together, because I really do need to deep clean it. there is only so much one can reach with Qtips and compressed air.
us Offline yud
Reply #9 on: March 02, 2016, 12:48:45 AM
Yes you can, just be fore warned that the knife may never be the same if you start messing with the pins.  That being said for cleaning I would just take out the pin for the corkscrew that way you can take out the back springs. (Also that way you would not re-peen the main tools)
Also recently I was surprised by how clean I got a knife with dish soap and toothbrush, soaking can also be a good method too.
  • Benner fan club #003
Reply #10 on: March 02, 2016, 01:02:24 AM
It will look like this with the scales removed
* wenscale03.jpg (Filesize: 52.51 KB)
Reply #11 on: March 02, 2016, 01:17:36 AM
I just cleaned it like you suggested and it looks much better, although the toothbrush i used in now stained black and may support a tiny eco system from all the crap I removed.
us Offline yud
Reply #12 on: March 02, 2016, 01:27:37 AM
Yeah I have a dedicated knife brush they can get real nasty.
us Offline SAK Guy
Reply #13 on: March 02, 2016, 02:36:28 AM
Me too! I use double ended M16 cleaning brushes.....
Like these:
http://www.ebay.com/itm/FIVE-5-US-RIFLE-CLEANING-TOOTH-BRUSHES-sporting-tactical-gun-part-lot-/281947910560?hash=item41a567b1a0:g:U6wAAOSwcwhVQ4tq
- Robert
Quo Fata Ferunt
us Offline yud
Reply #14 on: March 02, 2016, 02:44:05 AM
Like these:
I like the look of those
Reply #15 on: March 02, 2016, 02:54:09 AM
* IMG_1551.JPG (Filesize: 83.63 KB)
us Offline SAK Guy
Reply #16 on: March 02, 2016, 03:04:37 AM
Like these:
They work great! The small end brush is pretty narrow and will get down into the bays better than a toothbrush.   :tu:
- Robert
Quo Fata Ferunt
us Offline yud
Reply #17 on: March 02, 2016, 03:06:31 AM
Great :tu:
us Offline yud
Reply #18 on: March 02, 2016, 03:11:30 AM
Like these:
I might have to go over to the local gun store to see if they have any
us Offline jalind
Reply #19 on: March 02, 2016, 04:09:16 AM
I use a watch back knife made for popping off snap-on watch backs. Thin enough to get under the scales but not sharp enough to cut you, and the tip is rounded sufficiently that it won't stab you either. Victorinox makes a very nice Uhren Offner (German for Watch Opener) with a case back blade. The blade of a decent watch back knife is hard enough that the aluminum liners and brass pins won't ding it.
Scales can only be popped off and put back on a couple times at most. If putting on scales that have been used before I use a bit of Welder in the scale hole that will fit over the pin bushing to help hold it on. It's good contact adhesive, dries "clear" (slightly translucent) and has some hardness but doesn't get brittle, so it will give some before breaking adhesion (thinking about coefficient of thermal expansion mismatch between brass and celidor).
John
« Last Edit: March 02, 2016, 04:32:27 AM by jalind »
John
Reply #20 on: March 02, 2016, 10:56:59 PM
That is a very capable looking Wenger you have there :tu: Glad you got the toothpick problem sorted out and welcome to the forum :salute:
Total Receipts: $122.41
PayPal Fees: $6.85
Net Balance: $115.56
Below Goal: $184.44
39%
