Cooking char cloth
us Offline kmanct3
Cooking char cloth
on: March 04, 2016, 04:43:39 PM
Made char cloth on the grill last night
us Offline rishardh
Re: Cooking char cloth
Reply #1 on: March 04, 2016, 04:51:52 PM
Looks charred for sure  :D  I will be making some soon to test my new Vulcan fire piston.
no Offline Grathr
Reply #2 on: March 04, 2016, 05:12:54 PM
Let us know how it performes :)
us Offline kmanct3
Reply #3 on: March 04, 2016, 06:42:06 PM
I will , I'm making a homemade piston with my son , I'll post a pic of that later
Reply #4 on: March 05, 2016, 10:21:47 AM
Nice job mate.  Can I ask how long you grill it for, and how likely is it my wife will want to kill me if I tried it in my kitchen? :D
us Offline kmanct3
Reply #5 on: March 05, 2016, 01:42:04 PM
I already had the grill heated up ( Grilled Chicken ) It probably took no more than 10 minutes , I knew it was done when the smoke stopped coming out of the vent hole. And the answer to you're other question is Yes ! It gets very smoky  :rofl:
Reply #6 on: March 05, 2016, 03:02:41 PM
That's what I thought. :D  I'll try and remember to give this a go next time I have my fire pit lit up.
  • Benner fan club #003
Reply #7 on: March 05, 2016, 04:22:05 PM
I find that cotton balls make char that is much easier to pack into a fire piston...and stays in place better. I also use an old contact lens case as a holder for char and lube.
* charballs04.jpg (Filesize: 53.34 KB)
* lenscase04.jpg (Filesize: 45.53 KB)
us Offline kmanct3
Reply #8 on: March 06, 2016, 03:16:56 AM
How does that piston work ?
Reply #9 on: March 06, 2016, 03:28:32 AM
You put a fingernail's worth of char cloth on the end of the piston and fit the end of the piston into the tube.  It seals in the tube, note the o-ring on the end of the piston.  Then you smack the piston, driving it into the tube, and the heat from the compression of the air in the tube (sealed by the o-ring) ignites the bit of char cloth.  You then have to remove the piston to expose the ember on the end of the piston, and transfer the ember to a tinder bundle and get a flame out of it just as you would if you created the ember from a bow drill or ferro rod or any other source.
Reply #10 on: March 06, 2016, 05:36:08 AM
If you're asking about the one in my photo...
It's the best and most reliable one I've used of the ones I own. It's a Wilderness Solutions Scout piston.
us Offline kmanct3
Reply #11 on: March 06, 2016, 01:32:17 PM
Thanks Spork , I should have phrased that differently , I know how they work  ;) just wanted to know how well , What is the length and diameter ? It looks smaller than my UST and Numyth Vulcan
Reply #12 on: March 06, 2016, 10:09:33 PM
About 4-1/4" x 1"
* scout_piston01.jpg (Filesize: 97.06 KB)
Reply #13 on: March 07, 2016, 05:51:11 AM
My mistake. I misunderstood what you were asking.  In any case, someone may read this later who didn't know how they work.  The Wilderness Solutions Scout Piston does look well made compared to some I've seen. If Spork will update us to let us know how well it works for him over time I may have to get one.  Thanks Spork.
us Offline kmanct3
Reply #14 on: March 07, 2016, 01:01:00 PM
Don't sweat it  :tu: I too might get one
Reply #15 on: March 07, 2016, 10:45:15 PM
Good idea with the contact lense case Spork  :tu:
I think I may give char cloth making a try :tu: So just put a small hole in top of an Altoid tin then put cotton in and then cook til the smoking stops correct?
Reply #16 on: March 07, 2016, 10:48:39 PM
yes.
Reply #17 on: March 07, 2016, 10:49:41 PM
yes.
That's what I thought but thought best to ask :tu: Thanks for the speedy reply Sir :salute:
Reply #18 on: March 08, 2016, 01:14:57 AM
I don't use the standard Altoids tin for charring because they can't be plugged to prevent oxygen from entering when cooling. I generally use round tins with matching smoke holes drilled through the rim...holes lined up when charring...holes placed apart for storage. A twist of wire to keep the lid from popping open.
* smokehole03.jpg (Filesize: 23.68 KB)
* smokehole04.jpg (Filesize: 72.86 KB)
Reply #19 on: March 08, 2016, 01:31:19 AM
I used the tin from my Thrunite T10 effectively.  I also used old jeans which I find to be very good material.  Its good to experiment with different tins and different materials.  I keep extra char in a air tight mason jar as I find over time the char cloth become "brittle" and crumbles easily.
This material was not jean material.
* IMG_8190 copy.jpg (Filesize: 16.67 KB)
* IMG_8193 copy.jpg (Filesize: 109.65 KB)
us Offline rishardh
Reply #20 on: March 08, 2016, 08:27:36 AM
I made some tonight... with underwear  :D
* LMBlastC08F.JPG (Filesize: 122.9 KB)
* LMBlastC08H.JPG (Filesize: 162.72 KB)
* LMBlastC08K.JPG (Filesize: 132.76 KB)
* LMBlastC08M.JPG (Filesize: 120.13 KB)
« Last Edit: March 08, 2016, 08:30:18 AM by rishardh »
Reply #21 on: March 08, 2016, 08:31:18 AM
As long as its 100% cotton I don't see why not  :tu:.  Looks like it turned out great.  Now to spark it and see how it performs.
us Offline kmanct3
Reply #22 on: March 08, 2016, 01:06:08 PM
Nice job ! Funny , I had a pellet container and never thought to use it  :facepalm:
Reply #23 on: March 08, 2016, 01:24:55 PM
Nice job guys! Any of you tried using charred punk wood?
That's us mobile
Reply #24 on: March 08, 2016, 02:51:20 PM
Nice job mate.  I've got loads of old pellet tins kicking around so I suspect I'll steal that idea whenever I get around to trying this.
Has anyone done a comparison between cotton, linen and wool?  I only ask as cotton cloth was a luxury material for hundreds of years and linen and wool cloth would have been far more common.
Reply #25 on: March 08, 2016, 03:09:44 PM
Not sure if wool will work. Might have to give it a try. You are right about cotton being a luxury. It was more common in the frontier to use charred natural material like fungus, punky wood and the such.
That's us mobile
Reply #26 on: March 08, 2016, 03:44:06 PM
Those are excellent points about what was charred back when.   I've only tried Jute twine and cotton so far.  I thought the just was ok but next chance I get I'll char up some punk wood.
* IMG_6659 copy.jpg (Filesize: 154.49 KB)
Reply #27 on: March 08, 2016, 04:12:12 PM
I've had trouble with charred punk because the surfaces end up so smooth and the sparks bounce off. It is better if broken up a bit and the more traditional method of lighting used...left in the tin and sparks cast into it.
« Last Edit: March 08, 2016, 04:16:11 PM by Spork, Lord of Lime Jello! »
Reply #28 on: March 08, 2016, 04:24:30 PM
That's how I do it. Then I set the birds nest or feather stick in the tin and watch it burst into flame.
That's us mobile
Reply #29 on: March 08, 2016, 07:53:21 PM
This is some good stuff guys :popcorn: I am liking all the ideas I am seeing here :cheers:
Total Receipts: $168.99
PayPal Fees: $9.87
Net Balance: $159.12
Below Goal: $140.88
53%
