Another flea market project
nz Offline Syncop8r
on: May 01, 2016, 02:27:56 PM
I got this today, best of a bad bunch of worn axe heads:
Now.... what to do with it?  :think:
us Offline HarleyXJGuy
Re: Another flea market project
Reply #1 on: May 01, 2016, 02:54:50 PM
Send it to me?
nz Offline Syncop8r
Reply #2 on: May 01, 2016, 03:00:53 PM
Reply #3 on: May 01, 2016, 03:02:46 PM
es Offline alexTOOL
Reply #4 on: May 01, 2016, 03:03:30 PM
Reply #5 on: May 01, 2016, 04:17:01 PM
Looks to be very restorable :tu: I would clean it up some sharpen it and hang it :cheers:
Send it to me?
Got to get up earlier if I am gonna beat anyone with that line :facepalm: :rofl:
Owe and BTW good luck with the restore :tu:
Reply #6 on: May 01, 2016, 09:06:02 PM
Elwell, good bit of steel there  :tu:
 :popcorn:
nz Offline Syncop8r
Reply #7 on: May 01, 2016, 10:57:40 PM
I haven't done this before, I guess the next step is clean the rust off...
us Offline Yadda
Reply #8 on: May 02, 2016, 12:03:22 AM
Check with Tony,  he has the market cornered on rusty English axe heads....  Soak it in vinegar and take a brass wire brush to it.
Reply #9 on: May 02, 2016, 02:24:29 AM
I would clean it up some sharpen it and USE THAT PIG!
Fixed.
nz Offline Syncop8r
Reply #10 on: May 02, 2016, 03:25:10 AM
Does the number refer to a weight or size? Looks not much bigger than a hatchet.
Reply #11 on: May 02, 2016, 06:18:12 AM
Could be either ;) Really depends on what the manufacturer wanted it to be really :tu: In your case the way it looks to me it is the weight of it in pounds perhaps :think:
I have seen them refer to the weight or if they make/made several different models then it could be that model/size number. I have seen this in both axes and sledges :tu:
« Last Edit: May 02, 2016, 06:22:27 AM by Poncho65 »
Reply #12 on: May 02, 2016, 06:21:01 AM
Fixed.
He can't use it without a handle :pok: Hang as in handle it ;) :D
Reply #13 on: May 02, 2016, 08:12:25 AM
Yep it's Two and three quarter pounds  :tu:
Watch this  :salute:
https://www.youtube.com/watch?v=I55QyJXHk2E
If you take a look in here you will see some options for finishing your axe head  ;)
http://forum.multitool.org/index.php/topic,41665.0.html
nz Offline Syncop8r
Reply #14 on: May 02, 2016, 09:51:41 AM
It's soaking in vinegar now and after a couple of days it has a date with an abrasive disc on the angle grinder.
nz Online zoidberg
Reply #15 on: May 02, 2016, 10:30:59 AM
 :popcorn:
Reply #16 on: May 02, 2016, 12:49:32 PM
I guess you already know to use lots of water to keep the steel cool
And it would be safer to hang it before giving it a sharp edge (I always forget that part  :-[ )
nz Offline Syncop8r
Reply #17 on: May 02, 2016, 01:19:04 PM
By abrasive disc I mean it's like a pot scrub, not a grinding or cutting disc... however I may need to use something heavy duty to tidy up the shape of the cutting edge.
Reply #18 on: May 02, 2016, 01:30:08 PM
Ah OK, I’ve never tried one of those, watching with interest  :popcorn:
Reply #19 on: May 03, 2016, 09:29:27 PM
Yeah going by my steps I had him sharpen it first before putting the handle as well ::) :D
Always better to put handle first then sharpen ;)
Reply #20 on: May 03, 2016, 09:30:45 PM
Watch this  :salute:
I always love watching that video :dd: We need to put a link in  a thread and make that a sticky in the Axe Hole :cheers:
nz Offline Syncop8r
Reply #21 on: May 19, 2016, 11:42:15 AM
An update of sorts.... (no internet for weeks...):
I soaked the axe head in white vinegar. I only filled it just above the the equator and turned it over daily:
The problem is this meant the side that was out of the water would start rusting up again:
The grinder wheel got a bit hot and bits of hot plastic were flying at me and sticking to my clothes... I think it's not meant for cleaning metal, just removing paint. (The metal did not heat up at all)
After removing the rust I coated it in linseed oil. It is quite pitted. This is where it is at now:
It looks larger than my hatchet so I'm guessing I should go for a two-handed handle. These are about $40 here so maybe I will make one...
bavaria Offline Tomcat_81
Reply #22 on: May 19, 2016, 01:20:16 PM
Watch this  :salute:
Sometimes, when brooding over things, I gain hope in the thought that it is the invention of film, of videos, and of the possibility of sharing them, that will prevent mankind from the complete loss of culture.
Big thank you for that video!
Tomcat, constantly learning
Sent from my Boconcept sofa, using the 'post'-button
Owing a beer to Whoey since 2016
nz Offline Syncop8r
Reply #23 on: May 23, 2016, 11:40:25 AM
They also show how to hang an axe in the related video "Handtools for Trail Work" (Part 2). There's also a Leatherman being used on a saw in Part 1.
« Last Edit: May 23, 2016, 12:20:38 PM by Syncop8r »
Reply #24 on: May 23, 2016, 06:50:19 PM
You might find one or two interesting videos in this thread  :tu:
http://forum.multitool.org/index.php/topic,30096.0.html
(That will keep you lot quiet for an hour or two   :D )
Reply #25 on: May 24, 2016, 05:18:51 AM
Perhaps longer than an hour or 2 ::) :D :ahhh :ahhh :ahhh
Reply #26 on: May 24, 2016, 06:37:11 AM
I look through them now and then, keeps me out of trouble for a while   :)
Not all about axes but interesting anyway  :tu:
ch Offline Etherealicer
Reply #27 on: May 24, 2016, 08:09:15 AM
What does the inscription say?
"Made in England"
nz Offline Syncop8r
Reply #28 on: May 24, 2016, 08:50:18 AM
"Made in England"
Yes.
And ELWELL 2 3/4 on the other side.
nz Offline Syncop8r
Reply #29 on: May 31, 2016, 11:14:33 AM
Damnit, pitting in the sharpening zone....
Total Receipts: $77.16
PayPal Fees: $3.91
Net Balance: $73.25
Below Goal: $226.75
24%
