How should I sharpen this one?
firiki · 17 · 2199
gr Offline firiki
on: May 25, 2016, 02:19:31 PM
It's about the Glock knife. Here's a nice, short video to give you an idea of the blade's profile.
I have one living in my emergency bag and it's probably the definition of a sharpened prybar. It could cut ropes and cardboard and even paper when I first got it but you couldn't call it sharp.
I gave it a few passes with the ceramic rod found on the dual sharpener by Victorinox just to see what gives: not much, it needs something more substantial. I have no power tools so I was thinking of using a metal file (first a coarser, triangular one, then a finer, round one), then a messed up sharpening stone I use on my pruners and finally some sand paper.
Maybe all this treatment is excessive and unnecessary since this knife isn't meant (by me) to do any real cutting but rather all the nasty jobs that might come up in an emergency, like prying, light digging, batoning and even self defense. All of these the knife can do as it is now but putting a new edge that could be easily maintained in the future would be useful. My sharpening skills aren't very good, I can merely keep an existing edge serviceable on knives.
BTW, I intentionally left the knife without oil just to see what would happen. That was last summer. By February some minor spots of rust had already formed despite the fact the knife was kept in a bag inside the house.
Any thoughts and suggestions are most welcome. Thanks in advance  :)
bavaria Offline Tomcat_81
Re: How should I sharpen this one?
Reply #1 on: May 25, 2016, 04:03:25 PM
Similar to sharpening lawnmower blades ;-)
The Glock Feldmesser has a reputation amongst metal detectorists in Austria and Germany- it's seen as the handy, yet rusty prybar that's good for poking around in the ground, but which is best left unsharpened, because the steel is softer than anything which is really made for cutting....
If you want to come back to the initial sharpness (just for the sake of storing it then, awaiting that one emergency) I would also try the files and  some ceramic rods on it, cautiously keeping the angle of the initial edge.
Good luck!
« Last Edit: May 25, 2016, 04:07:35 PM by Tomcat_81 »
Sent from my Boconcept sofa, using the 'post'-button
Owing a beer to Whoey since 2016
no Offline Grathr
Reply #2 on: May 25, 2016, 04:07:33 PM
I havent got one of those, bute a coarse and a fine sharpening stone should get the job done.
Id be careful with the files if you go down that road. I think the fine file should be enough.
If you dont want to use much time on sharpeing, maybe a simple pull throug sharpener would do? It wont get it super sharp, but its easy to use, and will give you a usable edge i no time.
us Offline captain spaulding
Reply #3 on: May 25, 2016, 06:19:30 PM
Depending on conditions keeping it in a bag could be worse than leaving it out.
I'm the milk man!
gr Offline firiki
Reply #4 on: May 25, 2016, 10:55:48 PM
Good luck!
I had to Google how to sharpen lawn mower blades; it's pretty much what I had in mind -except I don't have a clamp vise :facepalm:
To be honest, I'm inclined to leave the thing as it is. I can see why it has that reputation and for what I expect it to do it feels perfectly fine. I also keep a Mora Companion and a couple of SAKs in that bag and I hope said emergency never occurs.
I'm mostly concerned with having to evacuate the building due to an earthquake -we had a good one earlier today  :ahhh
gr Offline firiki
Reply #5 on: May 25, 2016, 11:08:17 PM
The pull-through thingie on the Vic dual sharpener isn't wide enough for the job and while those can be useful I don't really like them.
I realise that putting a very fine edge on this knife isn't really beneficial, I avoid those in general because they need constant care.
Actually, I was wondering if I should try to re-profile the edge but I'm not sure what result I should go for. I guess I could have mentioned this in the OP  :-[
no Offline Steinar
Reply #6 on: May 25, 2016, 11:13:01 PM
Sandpaper and a mouse pad, perhaps.
Just do a quick search on freehand sharpening of convex edges if you don't get what I mean.
gr Offline firiki
Reply #7 on: May 25, 2016, 11:16:09 PM
That's true, the spot wasn't particularly damp, though :) I keep the bag close to the exit door, that's why I don't want to attach the knife on the MOLLE loops; people would look at me funny.
gr Offline firiki
Reply #8 on: May 25, 2016, 11:26:13 PM
Scary sharp, that was my first thought :) Then, I figured that this would probably result in a quite fine edge that doesn't seem suitable for this blade. This is how I started wondering if I should try to re-profile the blade, not in a scandi grind fashion but rather try to make it a little less convex (steeper angle near the egde).
Edit: Come to think of it, this does sound a bit like a scandi grind, doesn't it :think:
« Last Edit: May 25, 2016, 11:28:38 PM by firiki »
no Offline Steinar
Reply #9 on: May 26, 2016, 12:03:44 AM
The idea of the mouse pad is giving a springy layer which makes it easier to sharpen the edge to convex geometry, i.e. "blunter" towards the edge. In other words, my suggestion was to add a convex bevel to a hollow ground edge.
Convex edges are the opposite of hollow ground edges.
Edit: Ah, seems it is a sabre grind, not hollow ground? Doesn't change the idea, though. :)
« Last Edit: May 26, 2016, 12:05:44 AM by Steinar »
gr Offline firiki
Reply #10 on: May 26, 2016, 12:43:42 AM
I'm not sure what to call that blade profile, that's why I posted the video. I think it's closer to convex but the way it starts tapering so near the spine perplexes me. I doubt I can put a wider bevel on this thing without ruining the edge, though.
:drink:
Edit:
Aren't those two contradictory? :think:  :ahhh
« Last Edit: May 26, 2016, 12:45:48 AM by firiki »
no Offline Steinar
Reply #11 on: May 26, 2016, 08:49:09 AM
Not really, we used to call almost the same thing (derogatory) "round ground" in Norwegian, being the sign of someone unable to hold a consistent sharpening angle. :)
I tried to draw a cross section of a hollow ground blade with a convex bevel, attached below.
gr Offline firiki
Reply #12 on: May 26, 2016, 11:12:49 AM
Hey, thanks! Now I see what you mean. The Feldmesser's blade isn't hollow ground, I'm almost certain about that. It actually looks a lot like the grind on your sketch, the only difference being that it tapers much more gradually, thus making me think of it as convex.
The problem is the blade is quite narrow, this is a bayonet after all.
no Offline Steinar
Reply #13 on: May 26, 2016, 11:17:37 PM
It's soft steel so stuff like a whetstone or sandpaper will probably work very well. Anything ceramic sucks at removing enough steel to get an edge on something very dull, as you pointed out yourself. (Ceramic hones are my preferred type, whether the steel is hard or soft, but they require the edge to be not too horrible.)
gr Offline firiki
Reply #14 on: May 27, 2016, 08:49:45 PM
Agreed, I like ceramic sharpeners better too. Sometimes using a whetstone is inevitable though.
For what I expect of this knife I think that I should leave it as it is and just touch it up one bit, which shouldn't be too difficult given this baby's soft steel. I'm just wondering whether a different edge could be better for these tasks. I'm thinking something like an axe's edge maybe. I didn't mention that in the OP though :facepalm:
ca Offline Syph007
  • SAK Surgeon
Reply #15 on: May 27, 2016, 09:01:16 PM
For that type of work I would just file sharpen.  Thats how I do cheap machetes that arent blade steel.
Modding thread : Here
Website : WWW.SAKModder.com
Facebook : SAKModder
Instagram : robertjlessard
gr Offline firiki
Reply #16 on: May 27, 2016, 09:20:05 PM
I'm thinking the same, a few strokes with a file and a little sandpaper to smooth the edge a bit in the end.
It's not worth messing up my whetstones even further and I might even find some inspiration and get creative in the process :D
