Leatherman Rebar X-Man?!
kaput · 34 · 4084
us Offline kaput
on: July 19, 2016, 09:49:25 PM
I did a modification (tool swap ;) )  to my EDC leatherman, the Rebar.
I of course added some scissors from a Wave. Worked well, following the lead of others here. It was a simple addition and functional. Much more useful than some spacers :) and the terrible-terrible cap lifter. So this effectively gave me the Rebar-X.
Also, to me the cap lifter is so bad. I always seem to have one close by anyway, whether it's a SAK or a keychain opener, I don't need the LM bottle opener. Although, I did not mind the wire stripper and may miss that. So I subbed out the cap lifter for a retail package opener from the Wingman. I believe I will find this to be of much more use. So, this gave me the Rebar-X-Man!
The Wingmans package opener fit in just about perfectly. It even locks into place with no needed modification. The only problem that I ran into is when the pliers close the plier head will not go in completely flush. It's not bad, maybe 1/8 gap when closed. Since the cap lifter was rounded and shorter, it was able to accommodate for the plier head and the tool to close flush. This is acceptable for the moment imo, but I will fix this issue.
 :multi:
us Offline kaput
Re: Leatherman Rebar X-Man?!
Reply #1 on: July 19, 2016, 09:50:47 PM
us Offline kaput
Reply #2 on: July 19, 2016, 09:55:19 PM
Action shot! Cuts like buttah!
Reply #3 on: July 19, 2016, 09:55:45 PM
I do like the idea of the package cutter instead of the can/bottle opener :cheers:
Still burns me that they could have put scissors instead of a lanyard ring and a larger washer :facepalm:
Reply #4 on: July 19, 2016, 09:56:17 PM
Those wrenches are just awesome :dd: Loving mine :cheers:
Reply #5 on: July 19, 2016, 09:59:11 PM
Loki's wrenches have made the world a better place  !!!
Reply #6 on: July 19, 2016, 10:01:23 PM
Nice job  :tu:
 I turned the tip of my  can opener into a package opener by sharpening it.
« Last Edit: July 19, 2016, 10:12:24 PM by SteveC »
Reply #7 on: July 19, 2016, 10:06:29 PM
Yes, yes they have :D
Reply #8 on: July 19, 2016, 10:07:03 PM
Nice job  :tu:
 I turned the tip of my opener into a package opener by sharpening it.
OK I am gonna have to do that to mine :o :tu:
Reply #9 on: July 19, 2016, 10:14:16 PM
Nice job  :tu:
It's easy peasy, 5 min job with a file. Make sure you round the tip a bit because otherwise it can stick through the handle where the slot is for the lock spring.
« Last Edit: July 19, 2016, 10:16:10 PM by SteveC »
us Offline kaput
Reply #10 on: July 19, 2016, 10:20:47 PM
Nice job  :tu:
That is a good implement, now you're talking 4 tools in 1. I have noticed that the actual retail package opener is a bit more aggressive however, and like I said, it literally cut like butter. The angles are a little different, but I think it's the shallowness up to the curve/tip that lends itself so well to cutting blister packs.
How has that worked out or can you compare that to a retail package opener? Because if all things being the same, that would be a better all around tool.  :tu:
« Last Edit: July 19, 2016, 10:21:51 PM by kaput »
Reply #11 on: July 19, 2016, 10:24:53 PM
I haven't used it a bunch but when I did it cut right through the plastic no problem at all. I don't have any other package openers to compare it to though.
Reply #12 on: July 19, 2016, 10:35:16 PM
When I file mine down I will be able to compare as I have a Wingman with package cutter as well :cheers:
us Offline kaput
Reply #13 on: July 19, 2016, 11:38:02 PM
Atta boy! Let us know.  :tu:
Reply #14 on: July 19, 2016, 11:58:44 PM
I just tried mine again on a package and it zipped right through it.
Reply #15 on: July 20, 2016, 12:06:52 AM
Nice work kaput.   :tu:   :tu:
us Offline rdub934
Reply #16 on: July 20, 2016, 04:14:01 AM
Really cool, Kaput :tu: I think package opener is a fantastically useful little tool, and adding it to your Rebar was a great idea
us Offline kaput
Reply #17 on: July 20, 2016, 04:25:14 AM
Thanks zberg. Next on the list is your kick clip addition. :tu:
us Offline kaput
Reply #18 on: July 20, 2016, 04:28:44 AM
I open product and packages on a daily basis. So to me it's worth it's weight in gold.
*What if I gold plated the package opener. That'd be so gangster!  8)
Reply #19 on: July 20, 2016, 04:35:48 AM
I took an extra course diamond stone to it and after a few minutes I was satisfied it would cut packages open :cheers: It worked good but I worked on it a little more to fine tune it ;) I tried both the opener of the Rebar and the package cutter on the Wingman on some magazine covers and they both preformed about equal :tu: Well to me they did anyways :D
us Offline kaput
Reply #20 on: July 20, 2016, 04:39:47 AM
Tested on magazine covers?  :think:  :rofl:
Reply #21 on: July 20, 2016, 05:38:12 AM
Front page of a magazine, whatever :pok: The paper is a little thicker on the cover than regular paper :P
I got one of those free ones in the mail about I have no idea what so I decided to cut it up for my test >:D
Anyway :b2t: They cut very evenly ::)
Reply #22 on: July 20, 2016, 07:05:58 AM
Excellent choice for your first badges, congrats.   :cheers:
us Offline kaput
Reply #23 on: July 20, 2016, 07:36:38 AM
us Offline rdub934
Reply #24 on: July 20, 2016, 02:56:05 PM
Fo sizzle muh nizzle
ch Offline Etherealicer
Reply #25 on: July 20, 2016, 03:51:27 PM
001 - Etherealicer
002 - Etherealicer
003 - Etherealicer
004 - Etherealicer
005 - Etherealicer
006 - Etherealicer
007 - Etherealicer
008 - Etherealicer
009 - Etherealicer
010 - Etherealicer
011 - Etherealicer
012 - Etherealicer
013 - Etherealicer
014 - Etherealicer
015 - Etherealicer
016 - Etherealicer
017 - Etherealicer
018 - Etherealicer
019 - Etherealicer
020 - Etherealicer
021 - Etherealicer
022 - Etherealicer
023 - Etherealicer
024 - Etherealicer
025 - Etherealicer
026 - Etherealicer
027 - Etherealicer
028 - Etherealicer
029 - Etherealicer
030 - Etherealicer
031 - Etherealicer
032 - Etherealicer
033 - Etherealicer
034 - Etherealicer
035 - Etherealicer
036 - Etherealicer
037 - Etherealicer
038 - Etherealicer
039 - Etherealicer
040 - Etherealicer
041 - Etherealicer
042 - Etherealicer
043 - Etherealicer
044 - Etherealicer
045 - Etherealicer
046 - Etherealicer
047 - Etherealicer
048 - Etherealicer
049 - Etherealicer
050 - Etherealicer
051 - Etherealicer
052 - Etherealicer
053 - Etherealicer
054 - Etherealicer
055 - Etherealicer
056 - Etherealicer
057 - Etherealicer
058 - Etherealicer
059 - Etherealicer
060 - Etherealicer
061 - Etherealicer
062 - Etherealicer
063 - Etherealicer
064 - Etherealicer
065 - Etherealicer
066 - Etherealicer
067 - Etherealicer
068 - Etherealicer
069 - Etherealicer
070 - Etherealicer
071 - Etherealicer
072 - Etherealicer
073 - Etherealicer
074 - Etherealicer
075 - Etherealicer
076 - Etherealicer
077 - Etherealicer
078 - Etherealicer
079 - Etherealicer
080 - Etherealicer
081 - Etherealicer
082 - Etherealicer
083 - Etherealicer
084 - Etherealicer
085 - Etherealicer
086 - Etherealicer
087 - Etherealicer
088 - Etherealicer
089 - Etherealicer
090 - Etherealicer
091 - Etherealicer
092 - Etherealicer
093 - Etherealicer
094 - Etherealicer
095 - Etherealicer
096 - Etherealicer
097 - Etherealicer
098 - Etherealicer
099 - Etherealicer
100 - Etherealicer
101 - Etherealicer
102 - Etherealicer
103 - Etherealicer
104 - Etherealicer
105 - Etherealicer
106 - Etherealicer
107 - Etherealicer
108 - Etherealicer
109 - Etherealicer
110 - Etherealicer
111 - Etherealicer
112 - Etherealicer
113 - Etherealicer
114 - Etherealicer
115 - Etherealicer
116 - Etherealicer
117 - Etherealicer
118 - Etherealicer
119 - Etherealicer
120 - Etherealicer
121 - Etherealicer
122 - Etherealicer
123 - Etherealicer
124 - Etherealicer
125 - Etherealicer
126 - Etherealicer
127 - Etherealicer
128 - Etherealicer
129 - Etherealicer
130 - Etherealicer
131 - Etherealicer
132 - Etherealicer
133 - Etherealicer
134 - Etherealicer
135 - Etherealicer
136 - Etherealicer
137 - Etherealicer
138 - Etherealicer
139 - Etherealicer
140 - Etherealicer
141 - Etherealicer
142 - Etherealicer
143 - Etherealicer
144 - Etherealicer
145 - Etherealicer
146 - Etherealicer
147 - Etherealicer
148 - Etherealicer
149 - Etherealicer
150 - Etherealicer
151 - Etherealicer
152 - Etherealicer
153 - Etherealicer
154 - Etherealicer
155 - Etherealicer
156 - Etherealicer
157 - Etherealicer
158 - Etherealicer
159 - Etherealicer
160 - Etherealicer
161 - Etherealicer
162 - Etherealicer
163 - Etherealicer
164 - Etherealicer
165 - Etherealicer
166 - Etherealicer
167 - Etherealicer
168 - Etherealicer
169 - Etherealicer
170 - Etherealicer
171 - Etherealicer
172 - Etherealicer
173 - Etherealicer
174 - Etherealicer
175 - Etherealicer
176 - Etherealicer
177 - Etherealicer
178 - Etherealicer
179 - Etherealicer
180 - Etherealicer
181 - Etherealicer
182 - Etherealicer
183 - Etherealicer
184 - Etherealicer
185 - Etherealicer
186 - Etherealicer
187 - Etherealicer
188 - Etherealicer
189 - Etherealicer
190 - Etherealicer
191 - Etherealicer
192 - Etherealicer
193 - Etherealicer
194 - Etherealicer
195 - Etherealicer
196 - Etherealicer
197 - Etherealicer
198 - Etherealicer
199 - Etherealicer
200 - Etherealicer
201 - Etherealicer
202 - Etherealicer
203 - Etherealicer
204 - Etherealicer
205 - Etherealicer
206 - Etherealicer
207 - Etherealicer
208 - Etherealicer
209 - Etherealicer
210 - Etherealicer
211 - Etherealicer
212 - Etherealicer
213 - Etherealicer
214 - Etherealicer
215 - Etherealicer
216 - Etherealicer
217 - Etherealicer
218 - Etherealicer
219 - Etherealicer
220 - Etherealicer
221 - Etherealicer
222 - Etherealicer
223 - Etherealicer
224 - Etherealicer
225 - Etherealicer
226 - Etherealicer
227 - Etherealicer
228 - Etherealicer
229 - Etherealicer
230 - Etherealicer
231 - Etherealicer
232 - Etherealicer
233 - Etherealicer
234 - Etherealicer
235 - Etherealicer
236 - Etherealicer
237 - Etherealicer
238 - Etherealicer
239 - Etherealicer
240 - Etherealicer
241 - Etherealicer
242 - Etherealicer
243 - Etherealicer
244 - Etherealicer
245 - Etherealicer
246 - Etherealicer
247 - Etherealicer
248 - Etherealicer
249 - Etherealicer
250 - Etherealicer
251 - Etherealicer
252 - Etherealicer
253 - Etherealicer
254 - Etherealicer
255 - Etherealicer
256 - Etherealicer
257 - Etherealicer
258 - Etherealicer
259 - Etherealicer
260 - Etherealicer
261 - Etherealicer
262 - Etherealicer
263 - Etherealicer
264 - Etherealicer
265 - Etherealicer
266 - Etherealicer
267 - Etherealicer
268 - Etherealicer
269 - Etherealicer
270 - Etherealicer
271 - Etherealicer
272 - Etherealicer
273 - Etherealicer
274 - Etherealicer
275 - Etherealicer
276 - Etherealicer
277 - Etherealicer
278 - Etherealicer
279 - Etherealicer
280 - Etherealicer
281 - Etherealicer
282 - Etherealicer
283 - Etherealicer
284 - Etherealicer
285 - Etherealicer
286 - Etherealicer
287 - Etherealicer
288 - Etherealicer
289 - Etherealicer
290 - Etherealicer
291 - Etherealicer
292 - Etherealicer
293 - Etherealicer
294 - Etherealicer
295 - Etherealicer
296 - Etherealicer
297 - Etherealicer
298 - Etherealicer
299 - Etherealicer
300 - Etherealicer
301 - Etherealicer
302 - Etherealicer
303 - Etherealicer
304 - Etherealicer
305 - Etherealicer
306 - Etherealicer
307 - Etherealicer
308 - Etherealicer
309 - Etherealicer
310 - Etherealicer
311 - Etherealicer
312 - Etherealicer
313 - Etherealicer
314 - Etherealicer
315 - Etherealicer
316 - Etherealicer
317 - Etherealicer
318 - Etherealicer
319 - Etherealicer
320 - Etherealicer
321 - Etherealicer
322 - Etherealicer
323 - Etherealicer
324 - Etherealicer
325 - Etherealicer
326 - Etherealicer
327 - Etherealicer
328 - Etherealicer
329 - Etherealicer
330 - Etherealicer
331 - Etherealicer
332 - Etherealicer
333 - Etherealicer
334 - Etherealicer
335 - Etherealicer
336 - Etherealicer
337 - Etherealicer
338 - Etherealicer
339 - Etherealicer
340 - Etherealicer
341 - Etherealicer
342 - Etherealicer
343 - Etherealicer
344 - Etherealicer
345 - Etherealicer
346 - Etherealicer
347 - Etherealicer
348 - Etherealicer
349 - Etherealicer
350 - Etherealicer
351 - Etherealicer
352 - Etherealicer
353 - Etherealicer
354 - Etherealicer
355 - Etherealicer
356 - Etherealicer
357 - Etherealicer
358 - Etherealicer
359 - Etherealicer
360 - Etherealicer
361 - Etherealicer
362 - Etherealicer
363 - Etherealicer
364 - Etherealicer
365 - Etherealicer
366 - Etherealicer
367 - Etherealicer
368 - Etherealicer
369 - Etherealicer
370 - Etherealicer
371 - Etherealicer
372 - Etherealicer
373 - Etherealicer
374 - Etherealicer
375 - Etherealicer
376 - Etherealicer
377 - Etherealicer
378 - Etherealicer
379 - Etherealicer
380 - Etherealicer
381 - Etherealicer
382 - Etherealicer
383 - Etherealicer
384 - Etherealicer
385 - Etherealicer
386 - Etherealicer
387 - Etherealicer
388 - Etherealicer
389 - Etherealicer
390 - Etherealicer
391 - Etherealicer
392 - Etherealicer
393 - Etherealicer
394 - Etherealicer
395 - Etherealicer
396 - Etherealicer
397 - Etherealicer
398 - Etherealicer
399 - Etherealicer
400 - Etherealicer
401 - Etherealicer
402 - Etherealicer
403 - Etherealicer
404 - Etherealicer
405 - Etherealicer
406 - Etherealicer
407 - Etherealicer
408 - Etherealicer
409 - Etherealicer
410 - Etherealicer
411 - Etherealicer
412 - Etherealicer
413 - Etherealicer
414 - Etherealicer
415 - Etherealicer
416 - Etherealicer
417 - Etherealicer
418 - Etherealicer
419 - Etherealicer
420 - Etherealicer
421 - Etherealicer
422 - Etherealicer
423 - Etherealicer
424 - Etherealicer
425 - Etherealicer
426 - Etherealicer
427 - Etherealicer
428 - Etherealicer
429 - Etherealicer
430 - Etherealicer
431 - Etherealicer
432 - Etherealicer
433 - Etherealicer
434 - Etherealicer
435 - Etherealicer
436 - Etherealicer
437 - Etherealicer
438 - Etherealicer
439 - Etherealicer
440 - Etherealicer
441 - Etherealicer
442 - Etherealicer
443 - Etherealicer
444 - Etherealicer
445 - Etherealicer
446 - Etherealicer
447 - Etherealicer
448 - Etherealicer
449 - Etherealicer
450 - Etherealicer
451 - Etherealicer
452 - Etherealicer
453 - Etherealicer
454 - Etherealicer
455 - Etherealicer
456 - Etherealicer
457 - Etherealicer
458 - Etherealicer
459 - Etherealicer
460 - Etherealicer
461 - Etherealicer
462 - Etherealicer
463 - Etherealicer
464 - Etherealicer
465 - Etherealicer
466 - Etherealicer
467 - Etherealicer
468 - Etherealicer
469 - Etherealicer
470 - Etherealicer
471 - Etherealicer
472 - Etherealicer
473 - Etherealicer
474 - Etherealicer
475 - Etherealicer
476 - Etherealicer
477 - Etherealicer
478 - Etherealicer
479 - Etherealicer
480 - Etherealicer
481 - Etherealicer
482 - Etherealicer
483 - Etherealicer
484 - Etherealicer
485 - Etherealicer
486 - Etherealicer
487 - Etherealicer
488 - Etherealicer
489 - Etherealicer
490 - Etherealicer
491 - Etherealicer
492 - Etherealicer
493 - Etherealicer
494 - Etherealicer
495 - Etherealicer
496 - Etherealicer
497 - Etherealicer
498 - Etherealicer
499 - Etherealicer
500 - Etherealicer
501 - Etherealicer
502 - Etherealicer
503 - Etherealicer
504 - Etherealicer
505 - Etherealicer
506 - Etherealicer
507 - Etherealicer
508 - Etherealicer
509 - Etherealicer
510 - Etherealicer
511 - Etherealicer
512 - Etherealicer
513 - Etherealicer
514 - Etherealicer
515 - Etherealicer
516 - Etherealicer
517 - Etherealicer
518 - Etherealicer
519 - Etherealicer
520 - Etherealicer
521 - Etherealicer
522 - Etherealicer
523 - Etherealicer
524 - Etherealicer
525 - Etherealicer
526 - Etherealicer
527 - Etherealicer
528 - Etherealicer
529 - Etherealicer
530 - Etherealicer
531 - Etherealicer
532 - Etherealicer
533 - Etherealicer
534 - Etherealicer
535 - Etherealicer
536 - Etherealicer
537 - Etherealicer
538 - Etherealicer
539 - Etherealicer
540 - Etherealicer
541 - Etherealicer
542 - Etherealicer
543 - Etherealicer
544 - Etherealicer
545 - Etherealicer
546 - Etherealicer
547 - Etherealicer
548 - Etherealicer
549 - Etherealicer
550 - Etherealicer
551 - Etherealicer
552 - Etherealicer
553 - Etherealicer
554 - Etherealicer
555 - Etherealicer
556 - Etherealicer
557 - Etherealicer
558 - Etherealicer
559 - Etherealicer
560 - Etherealicer
561 - Etherealicer
562 - Etherealicer
563 - Etherealicer
564 - Etherealicer
565 - Etherealicer
566 - Etherealicer
567 - Etherealicer
568 - Etherealicer
569 - Etherealicer
570 - Etherealicer
571 - Etherealicer
572 - Etherealicer
573 - Etherealicer
574 - Etherealicer
575 - Etherealicer
576 - Etherealicer
577 - Etherealicer
578 - Etherealicer
579 - Etherealicer
580 - Etherealicer
581 - Etherealicer
582 - Etherealicer
583 - Etherealicer
584 - Etherealicer
585 - Etherealicer
586 - Etherealicer
587 - Etherealicer
588 - Etherealicer
589 - Etherealicer
590 - Etherealicer
591 - Etherealicer
592 - Etherealicer
593 - Etherealicer
594 - Etherealicer
595 - Etherealicer
596 - Etherealicer
597 - Etherealicer
598 - Etherealicer
599 - Etherealicer
600 - Etherealicer
601 - Etherealicer
602 - Etherealicer
603 - Etherealicer
604 - Etherealicer
605 - Etherealicer
606 - Etherealicer
607 - Etherealicer
608 - Etherealicer
609 - Etherealicer
610 - Etherealicer
611 - Etherealicer
612 - Etherealicer
613 - Etherealicer
614 - Etherealicer
615 - Etherealicer
616 - Etherealicer
617 - Etherealicer
618 - Etherealicer
619 - Etherealicer
620 - Etherealicer
621 - Etherealicer
622 - Etherealicer
623 - Etherealicer
624 - Etherealicer
625 - Etherealicer
626 - Etherealicer
627 - Etherealicer
628 - Etherealicer
629 - Etherealicer
630 - Etherealicer
631 - Etherealicer
632 - Etherealicer
633 - Etherealicer
634 - Etherealicer
635 - Etherealicer
636 - Etherealicer
637 - Etherealicer
638 - Etherealicer
639 - Etherealicer
640 - Etherealicer
641 - Etherealicer
642 - Etherealicer
643 - Etherealicer
644 - Etherealicer
645 - Etherealicer
646 - Etherealicer
647 - Etherealicer
648 - Etherealicer
649 - Etherealicer
650 - Etherealicer
651 - Etherealicer
652 - Etherealicer
653 - Etherealicer
654 - Etherealicer
655 - Etherealicer
656 - Etherealicer
657 - Etherealicer
658 - Etherealicer
659 - Etherealicer
660 - Etherealicer
661 - Etherealicer
662 - Etherealicer
663 - Etherealicer
664 - Etherealicer
665 - Etherealicer
666 - Etherealicer
667 - Etherealicer
668 - Etherealicer
669 - Etherealicer
670 - Etherealicer
671 - Etherealicer
672 - Etherealicer
673 - Etherealicer
674 - Etherealicer
675 - Etherealicer
676 - Etherealicer
677 - Etherealicer
678 - Etherealicer
679 - Etherealicer
680 - Etherealicer
681 - Etherealicer
682 - Etherealicer
683 - Etherealicer
684 - Etherealicer
685 - Etherealicer
686 - Etherealicer
687 - Etherealicer
688 - Etherealicer
689 - Etherealicer
690 - Etherealicer
691 - Etherealicer
692 - Etherealicer
693 - Etherealicer
694 - Etherealicer
695 - Etherealicer
696 - Etherealicer
697 - Etherealicer
698 - Etherealicer
699 - Etherealicer
700 - Etherealicer
701 - Etherealicer
702 - Etherealicer
703 - Etherealicer
704 - Etherealicer
705 - Etherealicer
706 - Etherealicer
707 - Etherealicer
708 - Etherealicer
709 - Etherealicer
710 - Etherealicer
711 - Etherealicer
712 - Etherealicer
713 - Etherealicer
714 - Etherealicer
715 - Etherealicer
716 - Etherealicer
717 - Etherealicer
718 - Etherealicer
719 - Etherealicer
720 - Etherealicer
721 - Etherealicer
722 - Etherealicer
723 - Etherealicer
724 - Etherealicer
725 - Etherealicer
726 - Etherealicer
727 - Etherealicer
728 - Etherealicer
729 - Etherealicer
730 - Etherealicer
731 - Etherealicer
732 - Etherealicer
733 - Etherealicer
734 - Etherealicer
735 - Etherealicer
736 - Etherealicer
737 - Etherealicer
738 - Etherealicer
739 - Etherealicer
740 - Etherealicer
741 - Etherealicer
742 - Etherealicer
743 - Etherealicer
744 - Etherealicer
745 - Etherealicer
746 - Etherealicer
747 - Etherealicer
748 - Etherealicer
749 - Etherealicer
750 - Etherealicer
751 - Etherealicer
752 - Etherealicer
753 - Etherealicer
754 - Etherealicer
755 - Etherealicer
756 - Etherealicer
757 - Etherealicer
758 - Etherealicer
759 - Etherealicer
760 - Etherealicer
761 - Etherealicer
762 - Etherealicer
763 - Etherealicer
764 - Etherealicer
765 - Etherealicer
766 - Etherealicer
767 - Etherealicer
768 - Etherealicer
769 - Etherealicer
770 - Etherealicer
771 - Etherealicer
772 - Etherealicer
773 - Etherealicer
774 - Etherealicer
775 - Etherealicer
776 - Etherealicer
777 - Etherealicer
778 - Etherealicer
779 - Etherealicer
780 - Etherealicer
781 - Etherealicer
782 - Etherealicer
783 - Etherealicer
784 - Etherealicer
785 - Etherealicer
786 - Etherealicer
787 - Etherealicer
788 - Etherealicer
789 - Etherealicer
790 - Etherealicer
791 - Etherealicer
792 - Etherealicer
793 - Etherealicer
794 - Etherealicer
795 - Etherealicer
796 - Etherealicer
797 - Etherealicer
798 - Etherealicer
799 - Etherealicer
800 - Etherealicer
801 - Etherealicer
802 - Etherealicer
803 - Etherealicer
804 - Etherealicer
805 - Etherealicer
806 - Etherealicer
807 - Etherealicer
808 - Etherealicer
809 - Etherealicer
810 - Etherealicer
811 - Etherealicer
812 - Etherealicer
813 - Etherealicer
814 - Etherealicer
815 - Etherealicer
816 - Etherealicer
817 - Etherealicer
818 - Etherealicer
819 - Etherealicer
820 - Etherealicer
821 - Etherealicer
822 - Etherealicer
823 - Etherealicer
824 - Etherealicer
825 - Etherealicer
826 - Etherealicer
827 - Etherealicer
828 - Etherealicer
829 - Etherealicer
830 - Etherealicer
831 - Etherealicer
832 - Etherealicer
833 - Etherealicer
834 - Etherealicer
835 - Etherealicer
836 - Etherealicer
837 - Etherealicer
838 - Etherealicer
839 - Etherealicer
840 - Etherealicer
841 - Etherealicer
842 - Etherealicer
843 - Etherealicer
844 - Etherealicer
845 - Etherealicer
846 - Etherealicer
847 - Etherealicer
848 - Etherealicer
849 - Etherealicer
850 - Etherealicer
851 - Etherealicer
852 - Etherealicer
853 - Etherealicer
854 - Etherealicer
855 - Etherealicer
856 - Etherealicer
857 - Etherealicer
858 - Etherealicer
859 - Etherealicer
860 - Etherealicer
861 - Etherealicer
862 - Etherealicer
863 - Etherealicer
864 - Etherealicer
865 - Etherealicer
866 - Etherealicer
867 - Etherealicer
868 - Etherealicer
869 - Etherealicer
870 - Etherealicer
871 - Etherealicer
872 - Etherealicer
873 - Etherealicer
874 - Etherealicer
875 - Etherealicer
876 - Etherealicer
877 - Etherealicer
878 - Etherealicer
879 - Etherealicer
880 - Etherealicer
881 - Etherealicer
882 - Etherealicer
883 - Etherealicer
884 - Etherealicer
885 - Etherealicer
886 - Etherealicer
887 - Etherealicer
888 - Etherealicer
889 - Etherealicer
890 - Etherealicer
891 - Etherealicer
892 - Etherealicer
893 - Etherealicer
894 - Etherealicer
895 - Etherealicer
896 - Etherealicer
897 - Etherealicer
898 - Etherealicer
899 - Etherealicer
900 - Etherealicer
901 - Etherealicer
902 - Etherealicer
903 - Etherealicer
904 - Etherealicer
905 - Etherealicer
906 - Etherealicer
907 - Etherealicer
908 - Etherealicer
909 - Etherealicer
910 - Etherealicer
911 - Etherealicer
912 - Etherealicer
913 - Etherealicer
914 - Etherealicer
915 - Etherealicer
916 - Etherealicer
917 - Etherealicer
918 - Etherealicer
919 - Etherealicer
920 - Etherealicer
921 - Etherealicer
922 - Etherealicer
923 - Etherealicer
924 - Etherealicer
925 - Etherealicer
926 - Etherealicer
927 - Etherealicer
928 - Etherealicer
929 - Etherealicer
930 - Etherealicer
931 - Etherealicer
932 - Etherealicer
933 - Etherealicer
934 - Etherealicer
935 - Etherealicer
936 - Etherealicer
937 - Etherealicer
938 - Etherealicer
939 - Etherealicer
940 - Etherealicer
941 - Etherealicer
942 - Etherealicer
943 - Etherealicer
944 - Etherealicer
945 - Etherealicer
946 - Etherealicer
947 - Etherealicer
948 - Etherealicer
949 - Etherealicer
950 - Etherealicer
951 - Etherealicer
952 - Etherealicer
953 - Etherealicer
954 - Etherealicer
955 - Etherealicer
956 - Etherealicer
957 - Etherealicer
958 - Etherealicer
959 - Etherealicer
960 - Etherealicer
961 - Etherealicer
962 - Etherealicer
963 - Etherealicer
964 - Etherealicer
965 - Etherealicer
966 - Etherealicer
967 - Etherealicer
968 - Etherealicer
969 - Etherealicer
970 - Etherealicer
971 - Etherealicer
972 - Etherealicer
973 - Etherealicer
974 - Etherealicer
975 - Etherealicer
976 - Etherealicer
977 - Etherealicer
978 - Etherealicer
979 - Etherealicer
980 - Etherealicer
981 - Etherealicer
982 - Etherealicer
983 - Etherealicer
984 - Etherealicer
985 - Etherealicer
986 - Etherealicer
987 - Etherealicer
988 - Etherealicer
989 - Etherealicer
990 - Etherealicer
991 - Etherealicer
992 - Etherealicer
993 - Etherealicer
994 - Etherealicer
995 - Etherealicer
996 - Etherealicer
997 - Etherealicer
998 - Etherealicer
999 - Etherealicer
Reply #26 on: July 20, 2016, 03:53:26 PM
 :o
Reply #27 on: July 20, 2016, 09:28:44 PM
Feel better now Eth :pok:
Reply #28 on: July 20, 2016, 09:34:36 PM
You know, that is only 3 lines of code :salute:
Reply #29 on: July 20, 2016, 10:32:12 PM
Nope ??? I lay brick for a living remember :pok: No clue about code :ahhh :D
