Diamond file mod for Rebar
SteveC · 48 · 8557
on: July 21, 2016, 06:50:41 PM
Diamond file for the Rebar II.  proof of concept.
I've had this Wave file for a while and had been meaning to give this a go. What was holding me back was not knowing if I could drill through the file with the drill bit I had on hand. I remembered that I had a bit my brother had given me when I helped him remodel his kitchen. We burned up a bunch of my masonry bits trying to drill through the tiles on his floor to anchor the island cabinets. Anyway he found this bit for drilling through glass tiles and gave me one. I figured I would give it a try and to my surprise it cut through the file with no problem. I drilled it from both sides. I used my dremel with a cut off disk to cut and shape and notch the file. Cleaned up on my bench grinder.
drill bit like this
Drilled
DSC09250_zpsg34ifcst by SteveC, on Flickr
Marked for cutting
DSC09615_zpsyjgzuvs1 by SteveC, on Flickr
DSC09617_zpsprpangrr by SteveC, on Flickr
Cut and profiled
DSC09620_zpsofyfxtn9 by SteveC, on Flickr
Done
DSC09262_zpsubsxdi0b by SteveC, on Flickr
Unfortunately the regular side of this file is a bit worn out but I just wanted to see if this would work and it does. It rubs a little bit on the handle when opening and closing but not too bad.
« Last Edit: November 17, 2020, 10:29:00 PM by SteveC »
ca Offline Toolslinger
  • Thread Killer 2015
Re: Diamond file mod for Rebar
Reply #1 on: July 21, 2016, 07:17:32 PM
Words are failing to describe how awesome that is...
:drool: :drool: :drool: :drool: :drool:
:gimme:
Very nicely done Steve. :hatsoff:
Reply #2 on: July 21, 2016, 07:37:58 PM
OK now that is what the Rebar should have been :dd:
Great mod my friend :tu:
Now to find a nice Wave file to cut down to put in my rebar :think:
I am really aggravated that LM didn't put the diamond file in the Rebar now :poh: :D
Reply #3 on: July 21, 2016, 08:04:57 PM
Thanks guy's  :cheers:
loki might have some, I know he did a while back anyway.
Reply #4 on: July 21, 2016, 10:04:05 PM
Nice one Steve.   :cheers:   :cheers:
tr Offline ddogu
Reply #5 on: July 21, 2016, 10:07:46 PM
That's what Rebar needed. Kudos to you  :salute: :salute:
us Offline kaput
Reply #6 on: July 21, 2016, 10:53:55 PM
The diamond file just feels sooo nice and works beautifully. The diamond file is just yummy, I don't know how else to put it...  :D
fi Offline temo
Reply #7 on: July 22, 2016, 12:03:07 AM
Nice! Makes rebar special.
Reply #8 on: July 22, 2016, 03:43:30 AM
If only I had thought to ask when I made my last order :doh:
us Offline Monrogue
  • Wooooo!
Reply #9 on: July 22, 2016, 05:17:39 AM
Sweet mod Steve :tu:
K-Tibbs
Reply #10 on: July 22, 2016, 05:36:26 AM
Thanks guys  :cheers:
wales Offline hiraethus
  • I brake for cake
Reply #11 on: July 22, 2016, 10:16:38 AM
Nice work Steve. :tu:
Reply #12 on: July 22, 2016, 01:53:04 PM
That's what a lot of tools should have been.
Maybe it's time for a Rebar 2.0, or maybe 3.0, since there's a knifeless rebar around.
Reply #13 on: July 22, 2016, 03:04:23 PM
Yes that sounds like a capital idea Sir :cheers: :D
Re: Diamond file mod for Rebar : Update
Reply #14 on: July 30, 2016, 10:00:01 PM
For fun I decided to see how the PST II file would work in the Rebar.  The pivot size is the same as the Rebar. It fits and would only require slight widening of the notch for the lock although it did lock as is just not well. The other would be remove a little V section at the bottom to clear the locking bar ramp when closed. Again it works as is just sticks up a bit when closed.
I think if I was to do it again I would use the PST II file as it is much less fitting involved than the Wave file.
us Offline Aberdrew13
Reply #15 on: August 03, 2016, 09:23:56 PM
...and a fish hook sharpener....   :pok:
If my text is in blue, read it with sarcasm.  That is how it's meant!
us Offline Outback in Idaho
Reply #16 on: August 03, 2016, 09:34:42 PM
  Like any good steak, Well done sir! :hatsoff:
¬ Outback Idaho
us Offline sLaughterMed
Reply #17 on: August 03, 2016, 09:49:43 PM
:twak: Eating steaks well done... blasphemy!
Laughter is the best Medicine
Reply #18 on: August 03, 2016, 10:05:19 PM
The only way to eat a steak is well done  :D
Nice work Steve!
Reply #19 on: August 03, 2016, 10:14:52 PM
Medium well is as low as I will go as well :whistle: I like well done on most things though :D
Reply #20 on: August 03, 2016, 10:15:56 PM
Some of the latter PST II and Pulse files lacked the hook sharpener though ;)
But I agree it would be better with the groove :tu:
Reply #21 on: August 03, 2016, 10:24:48 PM
Obi1 asked me if I would mod a file and can / package opener for him. So he sent me a Wave file and a can opener . My drill bit sustained a chip in one of the blades drilling this one. It's some pretty hard steel
Rebar file and package opener
Reply #22 on: August 03, 2016, 10:25:31 PM
Nice work Steve!
us Offline Obi1shinobee
Reply #23 on: August 03, 2016, 11:03:25 PM
 :cheers: :cheers: :cheers: :cheers: :salute:
Reply #24 on: August 04, 2016, 01:09:06 AM
You got mad skills Steve 8) :tu:
us Offline Monrogue
  • Wooooo!
Reply #25 on: August 04, 2016, 03:29:12 AM
If you're willing Steve, I may have to commission you to mod my PST II file....
K-Tibbs
Reply #26 on: August 04, 2016, 06:47:50 PM
I would be willing M although it's very simple mod.  If you have a Dremel with a cut off disk it could be done in a matter of minutes.
I test fitted again today and took some pics this time.
Here is the PST II file next to the Rebar file.  Marked with black sharpy is material that would need to be removed.
DSC09622_zpsjbsejimp by SteveC, on Flickr
Here is how it fits with no mods. It actually doesn't lock like I thought but it does fit as is.
DSC09630_zps34macmvk by SteveC, on Flickr
DSC09623_zpsnda8aipv by SteveC, on Flickr
« Last Edit: November 17, 2020, 08:55:13 PM by SteveC »
Reply #27 on: August 04, 2016, 07:48:13 PM
That file looks more fitting to the Rebar chasis and the groove is the icing on the cake :D
If only the nailnick was on the other side :-\ but shouldn't be to hard to get out still :tu:
« Last Edit: November 17, 2020, 08:56:14 PM by SteveC »
us Offline Monrogue
  • Wooooo!
Reply #28 on: August 04, 2016, 07:54:52 PM
I do have a cheap dremel, but no experience with the cutting aspect.  I may use your pics to mark mine and give it a shot.  So you do have to remove some of the little notch for it to lock right?
« Last Edit: November 17, 2020, 08:56:38 PM by SteveC »
K-Tibbs
Reply #29 on: August 04, 2016, 08:04:06 PM
Yes, you will have to make the notch bigger for it to lock and also so it can open far enough to be inline with the handle. Take your time and I think you'll be fine. The best way to mark it is to lay the Rebar file on top and use it to mark with a fine tip Sharpie. You can use a drill bit to help line up the holes while you mark it.
Total Receipts: $135.65
PayPal Fees: $8.11
Net Balance: $127.54
Below Goal: $172.46
43%
